  1. Jan 8, 2023 at 9:55 AM
    centex
    centex New Member
    Got my reverse lights wired in. The PO must have been ridiculously lazy. These lights came preinstalled in the bumper with a switch for the cab. He never wired in the lights and he installed the plug. I pulled the plug out to wire to it and it's got a proprietary connector in it and I of course don't have the harness. So for now it's just tied straight to the reverse lights.
  2. Jan 8, 2023 at 10:11 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Nice truck, and welcome to the forum. It seems that all recently produced vehicles have extremely thin paint jobs. You know, for that extra 0.001 MPG o_O
  3. Jan 8, 2023 at 10:36 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    :fistbump:
    RobertD[QUOTED] likes this.
  4. Jan 8, 2023 at 11:27 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I didn’t want to shell shock him that bad!
    Patch999, AGTundra, RegGex and 4 others like this.
  5. Jan 8, 2023 at 11:31 AM
    JC21Tundra
    JC21Tundra If I'm not here, I'm somewhere else...
    Jeff
    St L Missouri
    2021 MGM Tundra Crew Cab TRD Sport 4x4
    Installed a Garmin Mini 2 dash cam with obdII power adapter, I like how small it is, not noticeable at all.20230107_164520.jpg 20230107_164539.jpg
  6. Jan 8, 2023 at 11:32 AM
    RainMan_PNW
    Casey
    Clark County, WA
    One step at a time
    I honestly thought I wouldn’t do anything but a roll up tonneau cover like my first truck.
    French Avocado, RobertD and reywcms like this.
  7. Jan 8, 2023 at 11:34 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    ssmokedz, bulldog93, Patch999 and 6 others like this.
  8. Jan 8, 2023 at 11:35 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Come say hi in the Lunar Rock Club too
    https://www.tundras.com/threads/lunar-rock-club.77656/
  9. Jan 8, 2023 at 11:35 AM
    Cue_32
    Cue_32 New Member
    Don
    TRD Off Road
    Painted tow hooks. Cheap mod but now the tow hooks are visible. I never knew I had those there for the 1st year of ownership
    GAknight, rocsteady, kbark and 9 others like this.
  10. Jan 8, 2023 at 11:37 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Power fold
  11. Jan 8, 2023 at 11:37 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Got the same one, why didn't you get a dongar adapter? https://dongar.tech/collections/toyota/tundra
    bulldog93 likes this.
  12. Jan 8, 2023 at 11:38 AM
    RainMan_PNW
    Casey
    Clark County, WA
    One good thing is that the mirror caps are separated from the rest of the truck - if the match isn’t perfect it is less noticeable.
    Patch999[QUOTED] likes this.
  13. Jan 8, 2023 at 11:39 AM
    RobertD
    Robert
    DFW, Texas
    Yep! Painted mine blue and just loved the pop of color they added to the front!
  14. Jan 8, 2023 at 11:41 AM
    RainMan_PNW
    Casey
    Clark County, WA
    That’s how I ran mine anyway, but with a break out/vampire harness to avoid tapping any wires
    RobertD likes this.
  15. Jan 8, 2023 at 11:43 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Hmm
    I’ll have to think about that while looking at my list and give you a more thorough answer
  16. Jan 8, 2023 at 11:57 AM
    Droptarotter
    Droptarotter New Member
    2020 Tundra TRD Off Road, Double Cab
    It still might be worth your while to contact them as it sounded like they had quite a few different years???
    Cheers
    the red[QUOTED] likes this.
  17. Jan 8, 2023 at 12:07 PM
    JC21Tundra
    Jeff
    St L Missouri
  18. Jan 8, 2023 at 12:09 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Got a link to that breakout harness? I've been looking for one to connect a rear LED brake/turn strip to
  19. Jan 8, 2023 at 12:15 PM
    RobertD
    Robert
    DFW, Texas
  20. Jan 8, 2023 at 12:29 PM
    French Avocado
    Utah / Wyo
    Adding the FRAC I think is invaluable
  21. Jan 8, 2023 at 12:31 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Install led bulbs
  22. Jan 8, 2023 at 12:47 PM
    RainMan_PNW
    Casey
    Clark County, WA
    welshmike, bulldog93 and RobertD like this.
  23. Jan 8, 2023 at 1:03 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Do you have a link to that power adapter? Mine has the dongar mirror adapter so can't use parking mode.
  24. Jan 8, 2023 at 1:07 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    I took advantage of our spectacular weather today and gave her a badly needed bath.
  25. Jan 8, 2023 at 1:18 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    I drove my truck while pulling my trailer for about 1.5 hours today and the alarm never came up and cruise control worked fine. When I got home I unhooked trailer and was heading back out and the alarm popped back up after hitting the bumps in my driveway. I turned truck off to restart it to see if alarm would clear. My truck wouldn’t even crank and dash lit up with codes. Truck would just turn over but wouldn’t crank. I dragged it back to house and headed to town for lunch in a spare vehicle. When I got back home my truck cranked. Can’t remember if the pre collision alarm was back or not. I looked in fuse panel and I saw that one of the add a fuse holder I had going to ignition fuse had popped out. It was just laying on contacts. I moved my add a fuse to a different slot to see if that fixes problem. So far so good. I did pull fuse while truck was running and it threw up all the same alarm as it did when truck would not crank. Hopefully I just had a loose fuse. Makes sense since I got alarm after breaking really hard and also when I hit some bumps in driveway. I figured I’d pass on the info to you incase that could possibly be the problem we are having. It could be that I had two problems at the same time but it’s worth checking out. I had a add a fuse on the 10amp fuse in picture with arrow. You may want to check yours just incase yours is loose also.
  26. Jan 8, 2023 at 1:28 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    New OEM LED fogs and TRD Pro headlights
  27. Jan 8, 2023 at 1:34 PM
    PlaysARobin
    PlaysARobin New Member
    Thomas
    East Houston - Texas
    2021 TRD Pro Super White
    (2021 TRD Pro) AMP Steps, Ceramic Tint 5/20/70 windshield, Kilmat floor, doors and rear with Audiofrog/Arc audio/JL speaker upgrades and factory HU. AJT blackout. Ironmax4x4 Raid bumper with 10w amber work lights and 32" light bar. Rago dash setup with Bulletproof phone mounts. VLEDs interior kit with front and rear footwell lighting. X2Power AMG 27F.
    Made some more progress on the (.......parts i've had on hand for way too long and....) dash dechrome/desilver!
    Pulling the dash apart is quite jarring when you take a step back and as yourself "What have I done...." but its really not that bad. Just falls under the category of things that feel like they shouldn't be done.
    Disassembled. pulled the horizontal and center silver ugly stereo surround. Prep'd them both with plastic primer after an alcohol wipe down then sprayed them all with 5 coats of SE Trim MGM spray paint. At first I thought things went really well, but in the sunlight there was a LOT of blushing which changed based on angle. Ended up doing an additional 2 really heavy coats and it seemed to work great on the main center piece, which was a relief. The horizontal pieces (the 16th variation of silver Toyota seemed to want to use) however, I could not get the blush to go away. At the right angles they look like they're old sun faded plastic bits, so I may do something else later. For now, I don't care. It looks a billion times better, even if imperfect.
    I was SUPER careful putting things back together, but had an issue and knicked the main piece in 2 very small spots. not a huge deal, but the side I actually scratched it good when I was putting another piece on. had no idea I was even making contact. C'est las vis!
    Did the Red TRD button, AJT 4x4 knob, AC vents, and start button chrome deletes which wrapped up all my AJT items.
    Interior, all that remains is rear door killlmat and speaker swap, VLED interior kit and footwell lights. If I find a product I like, I'll get rid of the stupid silver on the doors. I'll probably buy the AJT pieces for the steering wheel, even though I would really prefer them to be MGM. I don't think the spray paint option is going to hold up well to the steering wheel usage. Oh, and a black TRD shifter knob with red thread. Just can't bring myself to pay $100+ for the Toyota one, so that'll have to wait for a 2nd hand deal to pop up.
    For now.....
  28. Jan 8, 2023 at 1:41 PM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    Never thought of that - I’ll check it out when I get back home. Thanks!
  29. Jan 8, 2023 at 1:47 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    Let there be light!
  30. Jan 8, 2023 at 2:01 PM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    Got the leather wrap done. It’s not perfect, there’s a couple of weird spots and the backside behind the wheel and on top of the airbag didn’t have quite enough material (im sure my lack of experience had something to do with that), but i am very happy with it. It’s perfect for me and feels so much better than the Amazon cover I had in it. Went ahead and painted the trim pieces while I was at it.
    Loving the way the interior is shaping up. Gonna start thinking about some Katskinz. 128A62BC-1AE3-4337-8EE5-7B6AC6B47D61.jpg A47880DC-019D-440E-9BC4-552EEBE2EB35.jpg
