2001 Tundra grill hood latch doesnt work
Discussion in '1st Gen Tundras (2000-2006)' started by 2001tundra, Jan 5, 2023.
  1. Jan 5, 2023 at 7:25 PM
    2001tundra
    2001tundra [OP] New Member
    I have a 2001 tundra with a dead battery and i can't open the hood. The latch in the cab works but the second under the grill doesn't. Any ideas?
  2. Jan 5, 2023 at 7:29 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    If the hood gives you some relief with the cab latch, can you jimmy the hood latch back for release?
  3. Jan 5, 2023 at 7:31 PM
    alb1k
    Left Coast
    It's good
    Meaning, a slim shim between the hood and grille, push the latch back toward the cab
  4. Jan 5, 2023 at 7:35 PM
    alb1k
    Left Coast
    It's good
    or the coat hanger, the hood latch may need to come forward. I can't remember, I'll go try.
  5. Jan 5, 2023 at 7:35 PM
    2001tundra
    I don't know how the mechanism looks or operates or how i could force it manually and there are no good videos that i have seen that help.
  6. Jan 5, 2023 at 7:42 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Latched
    Unlatched
    The rod needs to be pushed up for release.
    NewImprovedRon, Schcoman and shifty` like this.
  7. Jan 5, 2023 at 7:52 PM
    2001tundra
    I can see the rod and move it with my fingers. Tomorrow, when i can see better, ill try to grab it with pliers and maybe try to manually pull the hook up. Thanks for your help and especially the photos!
    NewImprovedRon and Schcoman like this.
  8. Jan 5, 2023 at 7:54 PM
    alb1k
    Left Coast
    It's good
    Mc bee is right, but shine a light in there to the right of the toy logo. Latch pulls easy with wire. As long as you can get some relief from cab latch.
    shifty` and Mr.bee like this.
  9. Jan 5, 2023 at 7:56 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Grab the bottom of the hook with needlenose and pull it forwards. I dont know about the '01 grille, but i could reach the hook theough my '02 grille.
    shifty` and alb1k like this.
  10. Jan 5, 2023 at 7:57 PM
    alb1k
    Left Coast
    It's good
    Good photo, pretty easy once you know where it is.
  11. Jan 5, 2023 at 8:01 PM
    2001tundra
    I'll have bright sun in the morning to see. Tonight, i couldn't see anything but the rod but now that i have photos i have something to work with. Thank you very much. Thank you all. will post more when i know more.
    Schcoman and Mr.bee like this.
  12. Jan 6, 2023 at 12:36 PM
    2001tundra
    Got the hood up and battery is charging. guessing there should be a clip holding the rod to the latch.
    I'll try to find one. Thanks again for all your help!!!
    alb1k likes this.
  13. Jan 6, 2023 at 12:42 PM
    Dorman makes an assortment pack you can pick up at most local auto parts stores. Dorman part number 75450, info/part pics here.
    The OEM clip you have pictured there is Toyota p/n 69759-0C010 but there are a couple other clips used in the assembly, I can't tell what you're missing from the pics.
    You may also check this thread, in case it helps with other ideas: https://www.tundras.com/threads/any...s-with-their-hood-catch-release-handle.86288/
    Schcoman and FirstGenVol like this.
  14. Jan 6, 2023 at 12:43 PM
    PS - any idea what caused the battery to die @2001tundra ?
  15. Jan 6, 2023 at 2:31 PM
    2001tundra
    Wish i'd known about the pack of clips at the auto parts store. I just got back from toyota of orange and bought 1 for $5.06.
    To Shifty: battery died from lack of use.
  16. Jan 6, 2023 at 3:00 PM
    I'd rather have OEM than the Dorman, to be honest.
    That Dorman pack is, like, they never quite fit right. It's either slightly too big on one or both ends, or too long, or too skinny, those are meant more as a 'tide you over'.
  17. Jan 6, 2023 at 3:14 PM
    2001tundra
    New clip is in. I had to insert the clip using a lubricant then insert the rod and lift the clip to lock on.
    Jack McCarthy, Schcoman and shifty` like this.
  18. Jan 8, 2023 at 6:07 AM
    Richid
    Richid New Member
    Highly recommend you buy a replacement release handle as they are no longer available from Toyota. Shop that inspects my truck broke the release handle - they are brittle, but jeez. There is a guy selling them on ebay (they are also a Lexus part).
    When the previous owner had mine, they went through a few batteries. Never could find a large parasitic draw, but I saw a recommendation here to always turn off the headlight switch instead of relying on the relays and haven't had a problem since.
  19. Jan 8, 2023 at 10:40 AM
    2001tundra
    I'll inspect the handle, thanks. My battery problem is lack of use, battery is only 2 years old. Also i always turn off my headlights as a habit from driving older vehicles.
