  1. Nov 18, 2022 at 5:36 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Personally I’d try to run a a750 with a 4runner ecu. Non vvti 4.7l 4runner had it. It can handle pretty good power, and the ratios should only help
  2. Nov 19, 2022 at 7:27 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    @Ghostly.- can't wait to see that build. I eventually wanna build a separate bottom end by Benson machining. If he's still around by then. Some head porting as well.
  3. Nov 19, 2022 at 7:54 AM
    Lextech
    Lextech New Member
    05 Double Cab
    Lower ball joint and needle bearing replacement day. Ecgs kit was awesome, tool slid right in and bearing came right out.
    Almost weird to not have my constant rhythmic vibration anymore.
    oscardog86, bmf4069, hammeron and 4 others like this.
  4. Nov 19, 2022 at 7:55 AM
    New axle seal too?
  5. Nov 19, 2022 at 8:02 AM
    Lextech
    Lextech New Member
    05 Double Cab
    For sure. Definitely wise to do while it's staring you in the face.
  6. Nov 19, 2022 at 8:24 AM
    Yep! Good call
    I’ve got that same tool somewhere
  7. Nov 19, 2022 at 8:29 AM
    Is it wise to use both the removal and install tools listed on the ECGS website?
    I see them listed for an 8” bushing, so I’m guessing that’s the same size used on our trucks.
  8. Nov 19, 2022 at 8:37 AM
    Got my downstream O2 sensors today from Rockauto. Looks like they might be going in next week before turkey day.
    shifty`, NUDRAT and FrenchToasty like this.
  9. Nov 19, 2022 at 8:38 AM
    Hopefully they have a revised or better install tool, but any seal install kit will do
  10. Nov 19, 2022 at 9:15 AM
    @daveeasa
    Sorry I didn’t respond earlier, 22mm for the flip bolts
    daveeasa likes this.
  11. Nov 19, 2022 at 9:34 AM
    daveeasa
    I was over the weight limit anyway so had to pare down. Damn $65 for 40 lbs is nutty. Flying on the cheap. Taking a griddle for my tenants which goes with the stove, movers boxed it up by mistake.
  12. Nov 19, 2022 at 10:35 AM
    Trimmed up the UBolts, only at 50miles since install but I’m doing a trail run next Saturday so might as well retorque everything. It was all good and tight excerpt the UBolts needed to be snuggled up some more. 3D0AB659-9948-4336-8FD5-029CDBC87033.jpg
    oscardog86, alb1k, bmf4069 and 3 others like this.
  13. Nov 19, 2022 at 9:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    bmf4069, txagg, shifty` and 2 others like this.
  14. Nov 19, 2022 at 9:29 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oh, also, just realized I didn't post on crackies thread, but looks like the lower bushings on my 5100s are wearing out... anyone had success with aftermarket bushings?
    I have no idea how old those 5100s are as they were on crackie with my purchase of him.
  15. Nov 20, 2022 at 12:16 AM
    empty_lord
    05 rollover special
    I still need to do the bushing in mine.. I hope it fixes my god awful vibration
  16. Nov 20, 2022 at 8:18 AM
    snoope
    snoope The Old Man
    My "Old Bucket of Bolts" pleasantly surprises me everyday..;)
    Driving through the "Heartland" for our trip north , this dam thing keeps me :D:D... actually tried to get 16 mpg :rolleyes: and that included passing a few "Large Cars" along 31 :burnrubber:..
    The seats are more comfy than the Lexus , being cloth instead of the leather BUT don't be fooled , it still handles like a 1/2 ton truck , cruising around the Lakes on those windy county roads you better be off the throttle entering then lite pedal through them.... Zoom zoom :cool:
    She got a Mini-detail Thursday before we left and the rain shield on the drivers door was completely removed; spider cracks finally gave up :(BUT proper attention to "Detail's" will wait until after we have moved , it is still in work truck mode :curls::curls:
    FrenchToasty and NUDRAT like this.
  17. Nov 20, 2022 at 3:46 PM
    ryderboy
    ryderboy New Member
    06 tundra sr5 double cab
    I did my favorite mod and cheapest to date. I used 1” backer rod I got from work and crammed it between the dash and windshield. It got rid of almost all the rattles and creeks. The truck sounds new and refined
    bmf4069, NUDRAT, txagg and 6 others like this.
  18. Nov 20, 2022 at 3:53 PM
    I need to do this with my front door window seals. There's a way to shove backer rod in there, apparently, and potentially quell that damn window rattle when partially open.
    ryderboy[QUOTED] likes this.
  19. Nov 20, 2022 at 4:00 PM
    ryderboy
    ryderboy New Member
    Omg yes for sure. Unfortunately I smoke so my window is down a little bit all the time
  20. Nov 20, 2022 at 5:19 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I need to take my dash apart cuz the backer rod didn't completely fix my rattles.
  21. Nov 20, 2022 at 5:26 PM
    Need to grease those pink phallic looking things?
  22. Nov 20, 2022 at 5:33 PM
    artsr2002
    'Yonder
    I believe so. I can put upward/forward pressure on the dash halfway between the ipc and stereo and the rattle goes away. Does anyone have a pic of those pink phallic things in the dash? Are they accessible by removing the ipc?
  23. Nov 20, 2022 at 7:24 PM
    There was a guy on here a while back that took pics of those things with his dash apart. I can’t remember who it was though.
  24. Nov 20, 2022 at 7:25 PM
  25. Nov 20, 2022 at 7:54 PM
    artsr2002
    'Yonder
    Damn, if I have to take the dash apart to get to that, I'll just suffer with the rattle. LOL
  26. Nov 20, 2022 at 8:06 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I only got the removal tool. I used a PVC pipe and a cap for the install but I don't recall the size off hand.
  27. Nov 21, 2022 at 4:26 AM
  28. Nov 21, 2022 at 4:35 AM
    2”
  29. Nov 21, 2022 at 7:48 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Fixed a "code". Came out to a check engine light when warming up to take the kid to g-mas.
    Got home realized I wasnt on EMPTY when I parked last night. Checked codes with OBD2 veakpeak.
    P0441,0455. Checked gas cap loose AF. Pretty sure someone siphoning gas last night. Hasn't popped back up. Will check canister hoses etc. Later. Man I have a feeling I have a reason to hate some people.
  30. Nov 21, 2022 at 7:50 AM
    Shitty part is, locking gas caps are not only a PITA at the pump, but these days, I've had a hard time finding one that will last w/o throwing more codes. The last Stant caps I've purchased lasted maybe a year or two?
    Hi06silver[QUOTED] likes this.
