Dash Squeak Diagnosis
Discussion in '1st Gen Tundras (2000-2006)' started by JonnyC, Aug 15, 2021.
  1. Aug 15, 2021 at 7:31 PM
    JonnyC
    JonnyC [OP] New Member
    2000 Tundra Limited 2WD
    Hey guys! I recently purchased a 2000 Limited 2WD Access Cab with 175,000 miles on it. I have it torn apart for installing a new head unit and wiring up a rear camera, but while I'm at it I decided to try and tackle this really annoying and loud squeak from the upper part of the dash by the windshield.
    I know the typical fix has been to add a foam backer rod between the windshield and the dash, but I wanted to see what's actually making the noise. I've searched like crazy but haven't found too much information.
    There are a few things I see:
    1. Felt missing between the air vent and the dash, where you can see that the adhesive let go (hard to see in the picture, but there's only one still attached)
    2. A poorly designed clip for mounting the dash against the firewall
    3. Phalic post design - I mean did they really have to make them pink?
    I really think the noise is coming from those clips. Does anyone have any information on these? Was there a TSB for this ever, or a redesign of these clips? The odd thing is, the ball of the pink post on the dash doesn't bottom out in the socket of the clip, so you can see where the two thin tabs on each side have been wearing down on the far left and right side. On the three middle ones there is no wear, but you can also see some felt wrapped around a couple of them, and the one tab almost seems to be melted, which makes me think someone was in there trying to fix this.
    I'm going to stop over at the local Toyota dealer to have them look up the parts since I can't find any fiche detailed enough online and go from there. I might try to repair those tabs too, or cut down the other ones and add some Super Lube to the clips when I re-install.
    If anyone has solved this issue before, let me know, thanks!
    EDIT: My solution in post #13
    PXL_20210816_012634437.MP (Large).jpg PXL_20210816_002004184.MP (Large).jpg PXL_20210816_002013523.MP (Large).jpg PXL_20210816_002019644.MP (Large).jpg PXL_20210816_012847882.MP (Large).jpg
    DJenerated and bmf4069 like this.
  2. Aug 15, 2021 at 7:36 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    The issue is with the rubbing of those plastic clips against the firewall from what I was told. Wouldn’t you have to tear apart the dash to get to all of them? Not worth it IMO. Solution for me is the following…
    https://youtu.be/j8CcTYsMHYU
    Looks like you have the dash torn apart, so might as well throw some thick grease on them and be done with it.
    DJenerated, bmf4069 and FrenchToasty like this.
  3. Aug 15, 2021 at 7:47 PM
    JonnyC
    Haha. Yup, dash has to be torn out. Took a while, but I love these older vehicles in how straight forward they are to work on. Now if I remember where all of the screws and bolts go...
  4. Aug 15, 2021 at 7:53 PM
    Jack McCarthy
    Bill
    North of Boston
    So how many dash clips are there? Are they just right across the top of the dash or do they go deep into it?
    FrenchToasty likes this.
  5. Aug 15, 2021 at 7:55 PM
    JonnyC
    Just right across the dash. There are 5 total. The left and right two are orange, the middle is white and the post design on the dash is different there.
  6. Aug 15, 2021 at 8:24 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I suspect those tiny penises are the cause of all your problems, but I'm not 1st Gen qualified to say for sure. ;)
  7. Aug 16, 2021 at 3:21 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Most of us fixed the dash squeak by stuffing backer rod between the glass and dash. It worked for me and I only get the occasional noise now.
    Wilson2000t and DJenerated like this.
  8. Aug 16, 2021 at 5:15 AM
    shifty` We call it “riding the gravy train”
    Glad I'm not the only one who sees little dicks. Also glad mine doesn't seem to make said noises. Is this strictly an earlier-model issue?
  9. Aug 16, 2021 at 5:29 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Ive got tactical card stock wedged into the gaps to quell the squeaking in the sequoia.
    DJenerated and FrenchToasty like this.
  10. Aug 21, 2021 at 4:53 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Ga
    2006 Tundra 4X4 Limited Dbl Cab
    My '06 had the rattle as well. Backer Rod cleared it up 95% of the time
  11. Aug 21, 2021 at 8:34 PM
    I feel like there should be a dedicated thread about this!
  12. Aug 21, 2021 at 9:45 PM
    Jcross0304
    Jcross0304 New Member
    Johnathan
    2006 Tundra SR5 DC 4wd
    What size backer rod did you use?
  13. Aug 31, 2021 at 9:31 PM
    JonnyC
    Alright, so far this has been a complete success. Absolutely no noise from the dash, only noises now are from the trim on the rear access cab doors.
    I used Tesa 51036 cloth electrical tape in various areas as shown, and hopefully it holds up. I put it under the clips, on the places the dash interfaces with those clips, on some other plastic that seems like it would contact the dash, around the center instrument panel edges (not pictured), and added some silicone to the pegs on the dash.
    PXL_20210817_052149957.MP (Large).jpg PXL_20210817_052207457.MP (Large).jpg PXL_20210817_054155311.PORTRAIT (Large).jpg PXL_20210817_054150262.PORTRAIT (Large).jpg PXL_20210817_051540634.MP (Large).jpg
  14. Dec 12, 2021 at 5:26 PM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Glad I found this thread. Going to try this tomorrow on my ‘06 dc.
  15. Dec 12, 2021 at 9:37 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I have the rattle and it’s pretty annoying when idling.
    I’m not sure I’m ready to tear the dash out though.
    I’m going to bookmark this in case I go nuts one day and tear into it.
    Jack McCarthy likes this.
  16. Dec 13, 2021 at 6:16 AM
    Consider this fix in the meantime, no teardown required.
    Diablo169[QUOTED] likes this.
  17. Dec 16, 2021 at 10:10 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    1/2" is what I used.
  18. Feb 18, 2024 at 11:46 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I’m getting noise under the passenger airbag on the dash. If I put my hand on it while driving the noise goes away. If I push on it it makes the noise
  19. Feb 19, 2024 at 5:03 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Have you already tried the backer rod trick?
  20. Feb 19, 2024 at 5:32 AM
    There is a fastener that holds the bottom of the airbag. I’m assuming yours is loose or the dealership tech didn’t reinstall it after finishing the recall.
    @daveeasa can post pictures of this maybe; he has some, somewhere here on the forum, from when he was working on his.
  21. Feb 19, 2024 at 7:01 AM
    daveeasa
    David
  22. Feb 19, 2024 at 7:58 AM
    I recall - I think it was you - complaining about one bolt or fastener that was a PITA to get to. I swore you posted pictures of the one that was a problem, from your truck. Killing me I can’t find it now…
  23. Feb 19, 2024 at 8:18 AM
    daveeasa
    David
    I don’t think I got a good photo. There was one which required two finger mobility to remove and replace. But the wrench worked, just that once it was loose the wrench is/was not helpful due to lack of friction. So, to just tighten, a wrench per the diagram should work.
    shifty`[QUOTED] likes this.
  24. Feb 19, 2024 at 8:29 AM
    daveeasa
    David
  25. Feb 19, 2024 at 4:58 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Thank you all for the help, ended up finding an old pair of cheap sunglasses that were sandwiched between the back of the glove box and the plastic cover behind it. That plastic on plastic would rattle so much. I tightened all the bolts.
    It is so much quieter.
    bmf4069, daveeasa and shifty` like this.
  26. Feb 19, 2024 at 9:11 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I have some squeaks cropping up on mine. Sounds like front end suspension squeak and also the dash is rattling above the glove box. May need to try this backer rod fix again. Last time I think I used 3/8" and it didn't do much to solve the rattle. Will try 1/2" backer rod.
