Raspberry Pi - Carputer Build
Discussion in 'Audio & Video' started by JRS, Feb 12, 2022.
  1. Feb 12, 2022 at 8:56 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Have a 2012 DCLB WT model and originally wanted to add a backup camera, nav, and hands-free. Things quickly snowballed. Searching shows that something like this hasn't been done on this forum so I'm letting you guys know of another HU option.
    Disclaimer - way more work than it looks. Much easier to use a suction cup with your phone or tablet.
    Open Dash (no longer Open Auto Pro) is a software for Raspberry Pi, not a new OS. You get all of the desired in-car features like Android Auto, BT, OBD-II, etc., but you still have a full-fledged Linux distro with a ton of GPIOs. The hardware and software side are really up to you and what you want to make of it.
    Basic rundown of my setup:
    Since I was already this deep, I swapped the gauge cluster and HVAC LEDs to white and made the needles red. Nothing new there, but I'll echo everyone else, really gives ya the fizz.
    There are a lot of specifics I could get into, so if you have any questions, just let me know.
  2. Feb 12, 2022 at 9:21 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Care to share the bulb size and difficulty of changing out the ugly orange dash bulbs?
  3. Feb 12, 2022 at 10:23 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    The cluster and HVAC are easy. They are well designed snap-fit assemblies and the boards are big. These take SMD 3528s. Buy (100) packs on Amazon of whatever color(s) you want to go with. Using a chisel tip on the solder gun and a pair of tweezers, you heat up one side and pry it upwards. Heat the other side and lift off. I put a small dab of new solder onto the PCB pads and reapplied the new LEDs.
    The 4WD knob takes SMD 3014 and those are a pain in the ass because they're so small. Same process as above, but I found that pre-applying solder to the LED before applying to the board worked better. You'll burn through a bunch of these learning the technique. Fortunately, they also come in (100) packs. I had some additional practice when making the encoder light pipes since I used the 3014s on those as well.
    Haven't taken apart all of the other controls yet. From past posts it looks like they're 5mm diodes. Not currently planning on swapping those because they're mostly out of sight and I'm tired of working on this project for now.
    All of the above assumes you have an actual solder station. The cheap, garbage guns won't cut it here.
  4. Mar 1, 2022 at 9:20 PM
    SRPoor
    SRPoor New Member
    Thanks for posting. This along with software like openpilot is exciting to see.
  5. Mar 4, 2022 at 6:07 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Hadn't heard of that project before and it looks great. Has me picturing encoded motors all over to overcome the lack of TSS.
  6. Mar 4, 2022 at 8:12 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    You missed my favorite part: I love the mic location to just above the steering wheel...it feels like that would be a good spot somewhat insulated from a lot of the potential cabin noises (vents, windows, etc.). Did you print the housing for that? What kind of mic is it?
  7. Mar 4, 2022 at 8:16 AM
    NoRcptn
    NorCal
    2017 Platinum
    Geezus. And I was worried about installing my drivers side grab handle. Your setup looks badass.
    Black@Blue19, JRS[OP] and FredB32 like this.
  8. Mar 4, 2022 at 8:19 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    That's exactly why I put it there, and the fact that there is a removable insert on top of the steering column shroud which gives a clean wire pass-through. It's a cheap lavalier mic from Amazon. Took a few iterations to get the print to function correctly. Here's a CAD shot to give you an idea:
    07 Tundie and texasrho83 like this.
  9. Mar 4, 2022 at 8:23 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Very nice. So, does the housing actually clip in place there with the tabs on the bottom? I'll have to take a look at mine later today, it might be something to consider.
    What is the reasoning for the holes in the side of the housing?
  10. Mar 4, 2022 at 8:28 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    If you take yours out you'll understand the clips and shroud base. This is now easy to squeeze and remove but stays locked in. Lavalier mics are omnidirectional. Side ports are for the radial mics. Not sure if they're necessary but my thought was if my wife was with we could both be talking even though she's in the passenger seat.
    DesertRoads likes this.
  11. Mar 4, 2022 at 8:33 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Ah...makes sense. I'll have to take a peek at my mic (Kenwood that came with the HU). I didn't notice anything other than the obvious input on the front...but I honestly haven't looked that closely!
  12. Mar 27, 2022 at 8:47 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Awesome project! Way more ambitious than I'd ever be for something like this, just wanted to give you props for figuring all of it out.
    JRS[OP] likes this.
  13. Mar 28, 2022 at 8:31 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Jeff_5_7 likes this.
  14. Mar 28, 2022 at 8:51 AM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    mad props john to your ambitious undertaking brother!
    JRS[OP] likes this.
  15. Mar 28, 2022 at 9:01 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Wow! Amazing congratulations!
    JRS[OP] likes this.
  16. Aug 24, 2022 at 4:51 PM
    JRS
    JRS [OP] New Member
    2012 DCLB
    *All of this work makes you better appreciate the features of newer vehicles*
    V02 is finally underway. The hand soldered proto-board couldn't quite survive in the cabin as a short eventually happened and the buttons'/encoders' illumination went down. Also, V01 was so big and clunky that it was nearly impossible to fit within the double DIN and dash 'pocket.' It served its purpose to show what was possible and how it needed to be improved. V02 will have a machined PCB with a miniaturized layout. This should make everything easy to access and way more robust. It'll still use the 7" touch screen and currently printed bezel. Couple things which are changing:
    • Going to try Open Dash in hopes of ditching Open Auto Pro
    • Make the backup cam automatic with reverse gear as well as the anytime button (this turned out to be extremely beneficial)
    • Implement the option for software control of the eventual front and rear auxiliary lighting (for instance - turn the front aux on with highs and turn rear aux on with reverse gear)
    • Make this board be a carrier for the dual channel CAN card with the four channel DPST relay built-in so wiring is easier
    You can check out the CAD, mock of PCB, and schematic. Already planning V03, but assuming this one works well, it'll be quite a while before I get started on it.
  17. Aug 24, 2022 at 4:56 PM
    e30cabrio
  18. Sep 2, 2022 at 6:23 PM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Made the board...and it didn't work. Learned an important lesson: hand soldered components NEED thermal relief around their pads. Redid the layout with some optimization and copper pours. Currently making this next rev.
    Yzed608, texasrho83 and e30cabrio like this.
  19. Sep 2, 2022 at 6:35 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Can you give more specifics on the cluster gauge swap.. not a fan of the orange myself
  20. Sep 2, 2022 at 6:48 PM
    JRS
    JRS [OP] New Member
    2012 DCLB
    There's another thread here about putting in the Optitron gauges if that's what you're asking. I used my original cluster and swapped the LEDs. Post #3 was my summary on needed components and general how-to. Hope that helps.
    ACDC2ZZTop likes this.
  21. Sep 2, 2022 at 6:49 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Oof.
    You'll get it man! Too damn cool.
    JRS[QUOTED][OP] likes this.
  22. Sep 7, 2022 at 8:26 PM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Dang near artwork.
    Another lesson learned: follow the instructions on the side of the bottle. Electroless tin plating really needs 7+mins. Had to take everything off of this board because the solder still wouldn't suck down. Super relieved to say this board is working exactly as it should. Next up is swapping software.
    e30cabrio and Yzed608 like this.
  23. Sep 7, 2022 at 8:52 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Is that a stick of RAM I see?
  24. Sep 7, 2022 at 9:10 PM
    JRS
    JRS [OP] New Member
    2012 DCLB
    texasrho83 likes this.
  25. Sep 7, 2022 at 9:33 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  26. Sep 7, 2022 at 9:45 PM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Smallest I could get - 128GB. Really just wanted those fast IO speeds. At that time I didn't have the quad DPST relay IC, so was a bit hellbent on improving boot time (it didn't improve it).
    Also, I don't store anything locally on any device. All files/media live on the NAS. If out, I grab through VPN/Plex, or we'll just stream.
  27. Feb 3, 2025 at 7:50 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    v3 is well underway. There were issues with v2 and I'm adding a lot more functionality, and modularity, into this go-round. I'll be overlaying a separate RS-485 network for my external stuff. This means I can add microcontroller modules wherever they're needed. The first module will be to interface with a TST TPMS system for our camper and grabbing rear diff temps.
    Here is the main IO v3 board. Fused input, LM555 timer for 5V output, a separate relay for RPi power, plug for three expansion modules, plug for four camera feeds, two plugs for truck params and CAN interception, and some 12V and 5V power supplies. The output has the 24p plug for feeding the RPi and a 6p for the dash insert module.
  28. Feb 13, 2025 at 8:36 PM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Really stoked on how the new dash insert is looking. Put the screen at 5deg towards the driver and recessed it 15mm to hopefully minimize sun glare. Also offset the light pipes to the outside because it looks cool and will be a lot easier to setup the surface mount diodes on the PCB. This arrangement will remove all of the buttons which are next to the cluster and below the HVAC controls.
  29. Feb 26, 2025 at 7:21 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Learned a lesson: when messing with the CAN bus use OEM contacts. They're likely TE AMP 025/040.
    DO NOT USE DUPONT
    Have always had an intermittent CEL where I'd drop comm with the cluster for a fraction of a second. My assumption was the RPi couldn't keep up with the multi-threaded script while performing other tasks. When I removed the RPi and it happened again, I figured my "perfectly calibrated 120ohm wire pairs" (AKA just randomly twisted 24AWG stuck in loom) was the culprit as I had left that hanging out of the dash for a week. Was completely shocked when I removed everything, plugged the Dupont connectors back in, heat shrunk them, and got the CEL again.
    Turns out Duponts can't support anything greater than a few hundred KHz. There are different baud rates for CAN but the one my truck runs at is 500KHz. Patched this point up and haven't had the CEL return.
  30. Apr 28, 2025 at 6:12 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Had to redo the insert CAD and finally got the nested board completed. It's just a fancy controller for the RPi and an upcoming power distribution relay setup.01.jpg
    HulkSmurf14 and reywcms like this.
