Welcome to the Official SoCal BS/ Shenanigans, Tundras and What’s Happening Thread
Discussion in 'California' started by Sunnier, Dec 21, 2017.
  1. Jul 8, 2022 at 4:04 PM
    Sunnier
    Sunnier [OP] Pity the warrior that slays all his foes
    Sunny
    San Diego, CA
    More of us would jump on this, if we do. I’ve already got what-if side texts flying back and forth.
  2. Jul 8, 2022 at 4:42 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Let’s do it. I’ll bring beer and my chair haha
  3. Jul 8, 2022 at 4:42 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    I haven’t gotten any texts :(
    tundra_20 and eccracer104 like this.
  4. Jul 8, 2022 at 5:32 PM
    Sunnier
    Sunny
    San Diego, CA
    You in if it happens? Bbq, beer, then after you’ve watched others, you’ll try it yourself? #rules
    I’m looking for your number. I’ll text you.
  5. Jul 8, 2022 at 6:04 PM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    @fisherman951 do you already have a set or are you getting in on this GB?
    tundra_20 likes this.
  6. Jul 11, 2022 at 8:30 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Has any one had the dash board light up like a Christmas tree and also the trailer parking error stating to pull over immediately? I turned off the truck and started it back up and everything went away.
    im wondering does that throw a code that’s probably stored in the computer? Drove it and everything was fine. But had me worried at first.
  7. Jul 12, 2022 at 6:00 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    It happened to me once on my way home from San Diego. I did the same thing. Pulled over, turned off the truck, waited a few minutes and restarted. It has not happened since.
  8. Jul 12, 2022 at 6:31 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    I was just starting the truck. It does sit for weeks at a time and some one else mentioned my battery. Gotta keep an eye out and put a trickle charger make sure it’s good
  9. Jul 12, 2022 at 6:38 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    The battery is a possibility. My truck also
    sits for a week or so at a time. Hopefully you get lucky and it never happens again. If is does, at least you know how to deal with the issue. I have heard a bunch of crazy reasons why this may happen. Everything from the TSS sensor being dirty, battery, to just a random quirk. :notsure:
  10. Jul 12, 2022 at 7:23 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Mine doesn’t have all those sensors. It’s a 2017 SR5 lol but yes hopefully it doesn’t happen again. Still has a couple years of warranty but we will see
  11. Jul 15, 2022 at 3:37 PM
    shawn3210
    shawn3210 New Member
    Southern California
    Anyone got a recommendation for a communication system? New to off-roading but want to be able to communicate with other people when on the trails. I’m pretty new to the scene so trying to figure out what everyone using
  12. Jul 15, 2022 at 3:54 PM
    eccracer104
    San Diego, CA
    Ham radios are the most common way to communicate on the trail.
    Most run a simple radio like this -
    https://www.amazon.com/Baofeng-UV-5...5r&qid=1657925298&sprefix=bao,aps,1216&sr=8-4
    But it has very short range.
    There are radios that are a bit bigger and better while remaining handheld, but most commonly for an upgrade in quality and longer range reception you’d be looking into a “hard mounted” radio. Like this one -
    https://www.amazon.com/Icom-Original-IC-2730A-Amateur-Transceiver/dp/B00QOR05EY?crid=2SF08JCOT7MB0&keywords=kenwood+ham+radio&qid=1657925456&sprefix=kenwood+ham%2Caps%2C374&sr=8-8
  13. Jul 15, 2022 at 4:01 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    @shawn3210 the Baofeng that @eccracer104 linked above is adequate for most. We usually off-road in groups and it works just fine. You can always upgrade down the road if needed.
    eccracer104 likes this.
  14. Jul 15, 2022 at 4:35 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    *Legal Disclosure - Use of a HAM radio without a license is prohibited and can result in a fine of $10,000
    That being said, using a low wattage radio while moving on a "trail" is going to be nearly impossible to bust. Someone would have to be within range to hear you, have the directional radio antenna to track you, care enough to find you AND be able to go fast enough to catch up to you.
    On the flip side, getting a license is pretty damn easy. Find a free "cram" course near you, sit there for a few hours to learn, take a few practice tests online, take a REAL test for $15 (and pass) and you are completely legit.
  15. Jul 15, 2022 at 4:41 PM
    eccracer104
    San Diego, CA
    Once one upgrades, the little uv5r works great as a loaner too :thumbsup:
    True that!
    For what it’s worth I’m 99% sure un-licensed can use MURS channels without issue. Oh and not using repeaters. Lol.
    brownmike, Drainbung and shawn3210 like this.
  16. Jul 15, 2022 at 4:56 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    Either way it is a good radio to have anyway. Natural disasters, zombie apocalypse etc…..
    Drainbung and eccracer104 like this.
  17. Jul 16, 2022 at 6:29 AM
    DividedSky
    Jeff
    That is correct...
    "MURS is licensed by rule. This means an individual license is not required for an entity to operate a MURS transmitter if it is not a representative of a foreign government and if it uses the transmitter in accordance with the MURS rules outlined in 47 C.F.R. Part 95 Subpart J. There is no age restriction regarding who may operate an MURS transmitter"
  18. Jul 16, 2022 at 1:37 PM
    shawn3210
    Southern California
    Thanks everyone! Gonna look up classes so I don’t have any worries lol.
    Sunnier[OP] and eccracer104 like this.
  19. Jul 16, 2022 at 2:05 PM
    Sunnier
    Sunny
    San Diego, CA
    PM me if you want company. It’s been on my To Do list too long already. And it’s too hot to off-road the next couple of months anyway….
    Hmmn, who else has been ‘meaning to’…? @nishibot did you do this yet? Let’s hang out and get it done with Shawn.*
    *Shawn wonders how the hell this turned into a SoCal Shenanigans meet event.
    fisherman951, porkitt and eccracer104 like this.
  20. Jul 16, 2022 at 4:28 PM
    shawn3210
    Southern California
    I started googling and saw they have online class. Not sure how legit they are but gotta look into it more haha, which license do you guys recommend? I'm trying to convince my wife to let me buy a water port as well lol.
    Sunnier[OP] likes this.
  21. Jul 16, 2022 at 4:36 PM
    Sunnier
    Sunny
    San Diego, CA
    Where in SoCal are you? I might sell you a water port I never used for what I paid for it 3 years ago (I’m sure it’s way less than they go for now) and deliver it to you at the class you research and find so I don’t have to. Lol!
    There are 2 classes. One is ham operator and the other is… something else. But we’re randomly talking about radio licensing, so @DividedSky will likely mosey through here with the answer we need.
  22. Jul 16, 2022 at 4:37 PM
    shawn3210
    Southern California
    Im in grand terrace, between San Bernardino and riverside area. Yeah they shot up a lot, I remember when I had my taco they were a little over 100 on sale from costco.
    Sunnier[QUOTED][OP] likes this.
  23. Jul 16, 2022 at 4:40 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
  24. Jul 17, 2022 at 1:43 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    Um ya about that:anonymous:
    Keep forgetting about it
    des2mtn likes this.
  25. Jul 17, 2022 at 4:18 PM
    DividedSky
    Jeff
    3 classes actually...
    "The Federal Communications Commission licenses new hams in one of three classes: Technician, General and Extra. The Technician class is entry level, while General is the next step up. As you can guess, the Extra class license is the top shelf!"
    For the general stuff we do, all you need is the Technician class.
    The only benefit (as I see it) of using one of the higher classes is the ability to send out data messages (emails and such) via radio. Or if you want to talk to someone in Australia, China, South Africa etc. :thumbsup:
  26. Jul 18, 2022 at 12:02 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Come join us this weekend. It’s for a good cause.. 30C16500-11A7-4010-987C-F6AAAE53229D.jpg
    fisherman951 and Porschetech29 like this.
  27. Jul 18, 2022 at 12:02 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    fisherman951 likes this.
  28. Jul 18, 2022 at 12:29 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Stop stalking me!!! I’ll be in Baja broskies!!! YOU ain’t down….
    vq35721[QUOTED] likes this.
  29. Jul 18, 2022 at 12:29 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Great event go check it out guys! Lots of tundras for sure.
  30. Jul 18, 2022 at 12:31 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    I told you my situation, I ain’t brown enough lol.. Heading there in 6 months :)
    fisherman951[QUOTED] likes this.
