GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Jul 3, 2022 at 8:26 PM
    #991
    Que2
    Que2 New Member
    Georgia
    2022 Tundra Platinum (MGM)
    Tinted Windshield (50%), OEM Black Exhaust Tip, OEM Tonneau cover, 14" Screen Protector, OEM Bed Extender, Binize Box, Center Console Organizer Tray, OEM Bed Mat
    Which one you think? 285/65/20 or 285/60/20?
  2. Jul 3, 2022 at 8:51 PM
    #992
    Que2
    Que2 New Member
    Georgia
    Hey all. Trying to figure out which is the tallest safest size tire I can fit on my 22 Platinum stock wheels to fill up the wheel well? Trying to avoid rubbing, wheel poke and I probably will install mudflaps. I will probably go with the BFGoodrich KO2s because I like the look but I am stuck on which size to go with.
    295/60/20
    285/65/20
    or
    275/65/20
    Any advice and/or pictures would be super helpful. Thank you.
  3. Jul 3, 2022 at 9:06 PM
    #993
    bcj001
    bcj001 New Member
    Brad
    Oregon
    22' Tundra Limited
    35x11.5R20 fit great on the factory TRD wheels (I have a limited, so not 100% sure if the Platinum has the same wheels or?.... no level / lift, no poke, no rubbing, didn't have to pin the liner, and have mudflaps.... found this size cheaper than the metric equivalent as well. I had K02's on my last rig, and they got annoying loud after about 20k miles (similar size).. I went with the Nitto Recon Grapplers, and love them so far... only got about 3k miles on them... but so far so good... and I like the aggressive sidewall.. I have some pics if you click on my member name
    TheSS712 and TK1979 like this.
  4. Jul 3, 2022 at 10:33 PM
    #994
    TJCooke
    TJCooke New Member
    Tayler
    Did you need hub rings for your rims? I have the same ones and patiently awaiting for my truck to arrive
  5. Jul 6, 2022 at 8:59 AM
    #995
    nrm91
    nrm91 New Member
    Boise, ID
    2022 Platinum CrewMax Magnetic Grey
    35/11.5/20 Toyo AT III's
    Would the Falken Wildpeak LT295/70R18 fit on my Platinum factory wheels without any issue? What if I get a leveling kit for the front?
  6. Jul 6, 2022 at 9:21 AM
    #996
    Jagator
    Jagator New Member
    2022 Blueprint Tundra Platinum 4x4
    The Platinum wheels are 20", not 18", so those tires aren't the right size.
    I have heard of folks installing 35" (or close) tires on stock Platinum wheels successfully with just a 2" front leveling kit. Without that you may have to do some trimming. I'm planning to use my stock Platinum wheels as well and just a front level to get close to 35" tires, like someone in this thread did: https://www.tundras.com/threads/35s-on-oem-rims.107959/#post-2826807
    There are multiple posts in this thread about larger tires on factory Platinum wheels with just an Amazon front level and manual rear AVS adjustment, looks sharp: https://www.tundras.com/threads/leveling-22-platinum-with-avs-air.99893/page-2
  7. Jul 6, 2022 at 9:38 AM
    #997
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Plenty of 2.5 gen people running 295/60s on the factory 20x8" wheels. Follow the above post too for good links. ^^
  8. Jul 7, 2022 at 12:32 PM
    #998
    Que2
    Que2 New Member
    Georgia
    Thanks!
  9. Jul 7, 2022 at 4:59 PM
    #999
    jlucrob
    jlucrob New Member
    2022 Tundra SR5
    Hey guys! First of all, thanks to everyone that posted pictures of their wheels/tires setup, it helped me a lot to make my selection.
    I went with Toyo Open Country AT3 275/70R18 with Fuel Rush 18x9 +20
    IMG_20220707_152809198_HDR.jpg IMG_20220707_152757240_HDR.jpg IMG_20220707_152712921_HDR.jpg IMG_20220707_152651145_HDR.jpg
    arrampico, FortyNorth, Helo and 5 others like this.
  10. Jul 7, 2022 at 5:40 PM
    #1000
    DoubleDuece
    DoubleDuece New Member
    Very nice truck . My new tundra will be picked up tomorrow after they put Toyo 295 60 R20 and ReadyLift 2,5 “ leveling kit
    Enjoy
  11. Jul 7, 2022 at 8:27 PM
    #1001
    nrm91
    nrm91 New Member
    Boise, ID
    Out of curiosity what made you get that leveling kit vs a cheaper one on Amazon? I plan on getting a cheaper one, then the Toyo A/T III's 35/11.5/R20's. Also, if you don't mind me asking, what was the cost to get the leveling kit installed?
  12. Jul 8, 2022 at 6:00 AM
    #1002
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    get the cheap level first to get the look and fit bigger wheels then once a full setup is readily available change it out. That’s what I’ve done and you don’t want to spend too much on a level just to pull it out.
  13. Jul 8, 2022 at 6:31 AM
    #1003
    nrm91
    nrm91 New Member
    Boise, ID
    Wait, so you got a 2.5" lift for both, or just a level? Isn't the level just 1.75" for the front?
  14. Jul 8, 2022 at 6:49 AM
    #1004
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    2” level in the front, zero in the back right now. I want the TRD 3” lift and I’ll wait for that, the 3-1 westcott level is too much money to spend just to take it out later on. The 1.75” level is from RC, still too much money just to pull out again. :spending:
  15. Jul 8, 2022 at 6:51 AM
    #1005
    nrm91
    nrm91 New Member
    Boise, ID
    I thought you were the OP I had quoted, my bad. Yeah I am planning to get the cheap leveling kit and the 35/11.5/R20 Toyo A/T III's. Then if I ever decide to put a bigger lift on, I'll get something like the TRD Pro one.
    Yaboy[QUOTED] likes this.
  16. Jul 8, 2022 at 7:22 AM
    #1006
    DoubleDuece
    They putting on tires and front leveling kit right now . Will pick up in few hours and send pics. I’ve been using ready lift on other tundras and been satisfied. Use trucks a lot on farm roads. Not sure how much installation is . I’ll let you know later today. Thanks
  17. Jul 8, 2022 at 7:26 AM
    #1007
    nrm91
    nrm91 New Member
    Boise, ID
    Sounds good! Hope everything goes smoothly.
  18. Jul 8, 2022 at 3:28 PM
    #1008
    DoubleDuece
    Brought Pearl home today after adding Toyo AT 3 295 60R 20 and a ReadyLift 2” front leveling kit.
    dragokvm, Hike5, TK1979 and 8 others like this.
  19. Jul 8, 2022 at 3:30 PM
    #1009
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    Finally someone with oem wheels with a nice set of tires :) thank you. So the 295’s do fit on the 20x8’s :)
    TK1979 likes this.
  20. Jul 8, 2022 at 3:35 PM
    #1010
    nrm91
    nrm91 New Member
    Boise, ID
    I plan on getting a front leveling kit and the Toyo AT3's as well, but I was going to get them in 35/11.5/R20. Any reason you went with that size? From what I understand the 35's will fit just fine and will be a little bigger
  21. Jul 8, 2022 at 4:04 PM
    #1011
    DoubleDuece
    Found out today and wanted to share that anything above a 2” leveling front kit , the front sensors would need to be calibrated. Could be bit pricey . My kit was 2” so I’m good.
  22. Jul 8, 2022 at 4:08 PM
    #1012
    DoubleDuece
    Another Pic. Certain light has a silver metallic look and other light can look much more white
    dragokvm and 17TundraDCEd like this.
  23. Jul 8, 2022 at 4:23 PM
    #1013
    DoubleDuece
    Little to large of a tire for my needs. Not sure how either will affect gas mileage. I’ll post something when I can .
  24. Jul 8, 2022 at 4:24 PM
    #1014
    DoubleDuece
    Yes , the 35”s should fit good .
  25. Jul 8, 2022 at 4:55 PM
    #1015
    motojunkie
    motojunkie New Member
    South Florida
    2022 Tundra TRD OR 2023 Supra GR
    Westcott leveling kit
    Method 316 18x9 +18
    Nitto Terra Grappler 295/70r18
    47E15DA1-B763-46D7-BF04-F55492133555.jpg 750D5EA7-40FB-4233-A022-43790023E4DF.jpg
    jchaps, Cp1, a_double and 10 others like this.
  26. Jul 9, 2022 at 4:11 AM
    #1016
    Joshuak175
    Joshuak175 New Member
    Any issues at all with these wheels? I’m about to order them as well.
  27. Jul 9, 2022 at 5:14 AM
    #1017
    DoubleDuece
    No issues at all.
    Good luck.
  28. Jul 9, 2022 at 6:23 AM
    #1018
    DoubleDuece
    With my ReadyLift 2” front leveling, front is 39 1/4” and rear is 39 3/4” .
  29. Jul 9, 2022 at 1:29 PM
    #1019
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Already had them from my 19 build
    No one has to my knowledge and my truck runs fine with 3in
    love them, zero issues and get lots of compliments. Tuners think they are Volk te37’s
  30. Jul 9, 2022 at 1:43 PM
    #1020
    DoubleDuece
    It’s the owners call as to get the sensors checked. Toyota will not do it . What I’m saying is that if an owner wants to be exact and match factory settings for safety etc , then they should get anything over 2” get alignment check .
    Just saying….
