Billet Oil Filter Cap by Jowett Performance
Discussion in '2nd Gen Tundras (2007-2013)' started by scotch, Jun 28, 2017.
  1. Jun 28, 2017 at 2:53 PM
    scotch
    scotch [OP] New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    Hey All, just saw this in the "other" board. He's got a sale going on so I ordered one. I'll post up a review when it shows up, if there's interest...
    Here's the info if anyone is interested:
    Hello XYZ Talk. I've just completed the second run of my billet oil filter cap. ........ This replaces all plastic and alloy versions of the stock cap with a heavy duty billet aluminum piece. A 2.5" six sided nut replaces the 14 flute 64.5mm stock design, which is prone to rounding off and occasionally cracking when overtightened. An optional Fumoto/EZ Drain Valve allows easy draining of the oil from the filter housing. The stock filter support tube and bypass valve are retained, so your oil system performs just as when it left the factory. Any questions? Please ask.
    You can purchase them here https://jowettperformance.com/produc...cap-for-filter
    Celebrate the 4 th of July with $20 off the fully optioned oil cap (includes drain valve and socket) Enter code "4th of July" at checkout.
    bulldog93 likes this.
  2. Jan 8, 2020 at 3:38 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    I know this is a long ago posting
    Does anybody have experience with this cap??
  3. Oct 6, 2023 at 12:55 PM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    I'll let you know soon....I just got mine this week and will install soon. I can tell you the craftsmanship is amazing!
  4. Oct 6, 2023 at 12:56 PM
    40man
    40man New Member
    They are awesome. I have them on my 200 Land Cruiser (5.7 V8) and my 2020 4Runner.
    Also put one on my FIL's Land Cruiser.
    I organized a group buy on these many years ago on Mud, TW and one of the other Tundra sites. Highly recommend Jowett Performance!
  5. Oct 6, 2023 at 2:58 PM
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    I have 2, one on the 2021 4Runner and one on the 2018 Tundra and they are built for sure! I have had zero issues and I have been running it on the 2018 for well over 4.5 years
  6. Oct 6, 2023 at 3:19 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White Tundra TRD Pro
    I have one on my 2020. Rock solid!
  7. Oct 6, 2023 at 4:18 PM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Can you get one with the extended nipple so you can put the hose on it when draining the one?
  8. Oct 6, 2023 at 6:27 PM
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    I’ve been running this system for years . One of the best upgrades to come by!
  9. Oct 6, 2023 at 8:26 PM
    bulldog93
    Jeff
    You can get the screw-on nipple on Amazon. Take it off after an oil change and put the plastic screw-on cap on.
    Damie Street[QUOTED] likes this.
  10. Oct 10, 2023 at 8:00 AM
    ProtoJ
    ProtoJ New Member
    Update, Jowett installed. Couldn't be any easier! No leaks, everything worked as expected. Next oil change should be much cleaner! Also, I changed it out mid oil change cycle....and you lose about 1/3 qt is all when you swap it out.
    PhotoNerd and bulldog93 like this.
  11. Oct 10, 2023 at 9:25 AM
    40man
    40man New Member
    He sells the screw on nipple for $8. With the RCI skid on my 4Runner and the Bud Built on my Land Cruiser, the hole lines up and the oil shoots straight down into my pan. I've never felt the need for a hose for the filter drain.
    On the engine oil drain, I definitely have a nipple and hose with a Fumoto. Makes a huge difference and don't have to remove skids.
