looking for drain bolt, oil filter torque spec
Discussion in '2.5 Gen Tundras (2014-2021)' started by CanTundra, Jun 4, 2022.
  1. Jun 4, 2022 at 6:35 PM
    CanTundra
    CanTundra [OP] New Member
    2021 Tundra TRD Off Road
    I was able to search online but hear different options.
    2021 5.7 tundra
    thanks guys
  2. Jun 4, 2022 at 6:37 PM
    Retroboy1989
    Northern Utah
    2012 DC 4x4 5.7 SR5 TRD OR Barcelona
    Snug top 20" TRD Sport wheels 275/60R20 Tires Additional Trans Cooler
    Toyota has a lot of consistency from model to model. Here are my oil change notes:
  3. Jun 4, 2022 at 6:44 PM
    CanTundra
    thanks yeah I was finding 30 as well.
  4. Jun 4, 2022 at 7:41 PM
    Big_Ed
    Big_Ed New Member
    Spring, Tx
    2016 Tundra
    Drain bolt: snug it down a little. If a drip forms later, then snug it a little tighter. The key is to not over tighten it.
    Filter: It uses an o-ring. It won't increase the seal by making it tighter. So over tightening does nothing but make it harder to remove later.
    Ely010606 and stevesgraytundra like this.
  5. Jun 4, 2022 at 9:13 PM
    Retroboy1989
    Northern Utah
  6. Jun 4, 2022 at 9:18 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Fumoto valve!
    AZBoatHauler likes this.
  7. Jun 4, 2022 at 9:22 PM
    Retroboy1989
    Northern Utah
    Eh, I don't daily drive the tundra so my OCI is 1x per year.
  8. Jun 4, 2022 at 10:53 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Drain bolt just snug it, you can pretty much tell where its supposed to be. Been doing oil changes since I was 17 and never use a torque wrench on one. The oil filter there is a metal tab that helps make sure it doesnt loosen, you can see the notch where its meant to lock in, so just tighten til it gets there.
    WILLINH likes this.
  9. Jun 7, 2022 at 2:44 PM
    kevine0001
    kevine0001 New Member
    Kevin
    it's 30 foot pounds, but i put it on hand tight, then a quarter or less turn with socket. been working for me on five different toyotas for past 10 years.
    Joe333x and NewImprovedRon like this.
  10. Jun 7, 2022 at 3:51 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I’ve just gone gutentight on my Tundras for the last 14 years with zero issue… I know it’s a German spec but still…
  11. Jun 7, 2022 at 3:57 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    Is that the same torque spec of a 1/4 turn before it strips?
  12. Jun 7, 2022 at 5:26 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Never put a torque wrench on those items and never will.
  13. Jun 7, 2022 at 11:10 PM
    Joe333x
    Joe333x Member
    Boston
    Im ashamed to admit I don't even own a toque wrench. I've been meaning to get one but have yet to come to a regular maintenance scenario where I actually need one. I'm sure there are actual scenarios to need one but oil chances, tire rotations, brakes, ect I've never seen the need, if anyone thinks a mechanic is grabbing a torque wrench and looking up the correct torque for each job you're grossly mistaken. Im sure there are those guys out there and I commend them but in all reality the biggest issue is shops putting things on with air guns. If you hand tighten everything and are not a psychopath you won't have an issue figuring out when to stop.
    kevine0001 likes this.
  14. Jun 8, 2022 at 6:24 AM
    Retroboy1989
    Northern Utah
    May I make a recommendation?
    https://www.amazon.com/dp/B07MKSJ4SG?_encoding=UTF8
  15. Jun 8, 2022 at 8:18 AM
    kevine0001
    Kevin
    Joe, I agree with you, however, I did pick up a torque wrench several years ago. I do use it for lug nuts, and I just put in new Powerstop front brakes last night (6/7/22), so I used it for the two 19mm bolts holding the calipers on. It not only works as an expensive 1/2" breaker bar, but if your truck is under warranty and dealer finds you over or under tightened something (hard to prove), they could use that as an excuse to not cover something. I did also use it for putting the drain plugs back into both diffs and transfer case. I know, overkill, but I guess it was just peace of mind for me on those things. But I don't use it on the oil drain plug...probably because I've done it so many times that I know by feel what works. Haven't had one drop out on me yet, and haven't had one stuck....except on the rare occasions I've had the dealer do work. Jeez they put shit on way too tight!
  16. Jun 8, 2022 at 8:18 AM
    kevine0001
    Kevin
  17. Jun 8, 2022 at 3:56 PM
    ninjajay
    Spoolston, TX
    no, that’s the dealer tech putting the oil filter housing back on with their impact gun
  18. Jun 8, 2022 at 4:22 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I own a 3/8" and a 1/2". I always torque front end parts and lug nuts. Heads are critical to torque but have not needed to pull a head for quite a while. On boat motors they should be retorqued at X hours.
    Retroboy1989 likes this.
