Magnuson S/C and hidden winch mount?
Discussion in 'Performance and Tuning' started by TonyNCo, May 21, 2022.
  1. May 21, 2022 at 10:59 PM
    TonyNCo
    TonyNCo [OP] New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    Does anyone know if the hidden winch mount is still a viable option with a Magnuson S/C?
  2. May 23, 2022 at 10:37 AM
    TonyNCo
    Tony
    Anyone?
  3. May 23, 2022 at 10:41 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    There are several winches on the market. Which winch are you looking at? Are you worried about interference with the inter-cooler?
  4. May 23, 2022 at 11:23 AM
    TonyNCo
    Tony
    Hello, I am mostly concerned about the SDHQ hidden winch mount working. It is nearby the S/C cooler mount. I might end up with a Warn winch or I might go with the similar highly rated Harbor Freight one... I figure if the mount works, the winch should sit slightly forward of the cooler area. Although, that is an assumption.
    I am actually on the fence about the winch to begin with. Thus why I might go for it, yet get the less expensive HFreight one.
  5. May 23, 2022 at 11:57 AM
    Saltyhero13
    I recommend reaching out to SDHQ regarding their winch and the intercooler. They reply very quickly and they run several blown offroad Tundras. They will be able to tell you if the physical envelop allows for both installations.
  6. May 25, 2022 at 3:37 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Had one on the Taco. All I needed to do was flip the bracket for the intercooler pump(?) And it made room for the winch.
    HulkSmurf14 likes this.
