Supercharger opinions/advice
Discussion in 'Performance and Tuning' started by TommyTundra, Feb 15, 2022.
  1. Feb 27, 2022 at 9:58 AM
    boomsling
    boomsling New Member
    ‘18 Barcelona Red 5.7 Double Cab 4x4
    Magnuson
    The blower makes it feel like a different truck. Cheaper than a new truck too. Looks cool too.
    Jcmf52, PNWTundra2021 and SoCalRandy like this.
  2. Feb 28, 2022 at 3:24 AM
    TommyTundra
    TommyTundra [OP] Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Just a side note. As soon as the weather breaks here in NY im going to spray the traction bars and all the brackets TRD red to match the tow hooks and TRD sway bars. 4ADF9338-3223-4C15-82DD-7F458E5FB5D3.jpg
    Jcmf52, 4firemandan and omgboost like this.
  3. Mar 1, 2022 at 11:15 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Not many new trucks going to be able to keep up, short of TRX or modded Gen 2 Raptors, even Gen 3 Raptors is a stretch.
    PNWTundra2021 and nobodyintexas like this.
  4. Mar 1, 2022 at 11:25 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Eibach pro 2.0s, toytec progressive mini AAL, ARE CX cap, Airlift bags, Harrop Supercharger, 650cc injectors, 77.5mm pulley, TRD Dual exhaust, J&L catchcan, Powertrax LSD, RRW RR7-H, 305/70r17 Toyo AT3s
    I’d love a shot at a TRX just for comparisons sake. They are a fair bit heavier than a doublecab tundra. I’m guessing they’re still quicker though. Plus if they did any mods at all, then there’s probably no chance. Even to hang with a stock one I think I’d need to regear.
  5. Mar 18, 2022 at 9:27 AM
    kos221
    kos221 New Member
    2007 4X4 DC
    Here is my experience. I don't have an ARF or boost gauge and don't know why some say it is a must have. I have a 2007 Tundra with the TRD (Magnuson) supercharger installed at a Toyota dealership in 2013 when the truck had 65,000 miles. It has the factory TRD tune. The truck now has 150,000+ miles and still runs great. I had issue with the cats on the left side throwing a code but drivability hasn't changed. I have always run 275/65r20 tires and aftermarket front shocks and springs. Everything else is stock. Maintenance on fluids as recommended. I have not had ANY issues with the powertrain ever. It is still as fast as today as it was 85,000 miles ago. By far it is one of the best mods you can do!
  6. Mar 18, 2022 at 7:30 PM
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    Has anyone measured before/after 0-60 or 1/4 mile times?
  7. Mar 18, 2022 at 9:51 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    Same reason as having an oil pressure or engine temp gauge. Your truck is an awesome testament to supercharged reliability!
    I've seen articles from when the tundra first came out, and I know a lot of people have logged their supercharged 0-60 times on the Harrop Stage 1 thread
    ViktorG and Silver17 like this.
  8. Mar 19, 2022 at 5:20 AM
    Terndrerrr
    Music City
    Dual 5.7s
    I searched and found a couple 0-60s over there. Seems the range is high 4s to mid 5s.
  9. Mar 19, 2022 at 9:27 AM
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    The TRD Tune is notoriously rich with included Cat Overtemp Protection from the factory. (That's probably what lead to the drivers cat degrading, mine did the same)
    It's awesome that your truck has been so solid.
    The reason for an afr gauge is to monitor the trucks ability to be in the right zone with fueling.
    Stock (while too rich technically) will probably be fine... But a lot of guys run other tunes and start adding pulleys etc. which can easily get into a lean condition that you won't know until it's too late if not watching the gauge.
    ViktorG and nobodyintexas like this.
  10. Mar 21, 2022 at 11:56 AM
    kos221
    kos221 New Member
    2007 4X4 DC
    4firemandan
    I certainly agree that if you are adding performance parts like a smaller pulley, headers, or changing the tune then there is a need for AFR monitoring. What did you do to fix your cats?
    Terndrerrr
    I only measured my 0-60 times after the blower. They have been pretty consistently around 5.3 for the better part of a decade. I use a Draggy for measurement. The launch style I find to be the fastest on regular surface streets is in 4WD high and Powerbrake to about 1200-1400 RPM. I don't know if I have ever gotten to 60 in under 6 seconds in 2WD. My tire just won't hook up no matter how gently I attempt to start. My truck weighs a bit more than stock because of the bumpers and other junk I keep in it so it is a bit slower than most.
    Terndrerrr likes this.
  11. Mar 22, 2022 at 11:42 AM
    4firemandan
    SWFL
    I had headers without cats in the mid pipes that I was procrastinating the install. Lol.
    So once my driver's front let go and was making noises I finally installed them.
    Word of caution though, no car causes significant drone increase. I finally got it under control will Dirty Deeds and some heavy interior insulation but ifi could do it again I would have got the cats included.
  12. Mar 23, 2022 at 11:23 AM
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    I'm about to go the same route. What type of insulation did you use?
  13. Mar 23, 2022 at 11:53 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I also have no "before" times but just got a Dragy thing. On Stage 1 Harrop, I was able to get 1 ok run in 2WD at 6.2 sec 0-60 and 1 run in 4WD at 5.4 sec 0-60. Mine is a crewmax with some extra weight (2 kid seats in back, snow plow mount, loaded bed tool box and bed rack, on 295/70-18 tires).
    dpast88 and nobodyintexas like this.
  14. Mar 23, 2022 at 3:28 PM
    4firemandan
    SWFL
    I forget the brand honestly but I just went with an Amazon peel and stick black butyl, followed by a foam peel and stick, and then the heavy matt for the majority of the flat floor.
    I did the firewall (as high up as I could reach) to and including the back wall.
    It cost a few hundred bucks even with the cheaper mid price range stuff.
    HonorNotInner[QUOTED] likes this.
  15. May 21, 2022 at 11:15 AM
    TonyNCo
    TonyNCo New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    2019 Pro as well, I am awaiting delivery at the dealer to have mine installed. In the mean time looking at adding a tranny cooler. The towing package tranny cooler is not the greatest. Between the mountains in Colorado and trips to Texas, some towing, I feel it would be a bad idea not to address.
    Any of you with a s/c added a tranny and engine oil cooler? I am thinking, although less seriously about an engine oil cooler as well.
  16. May 21, 2022 at 11:17 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    This kit is pretty good:
    https://www.tundras.com/threads/5-7l-transmission-cooler-kits.60550/
    Curious to see what other folks say about the engine oil cooling.
    omgboost and Terndrerrr like this.
  17. May 21, 2022 at 11:30 AM
    TonyNCo
    TonyNCo New Member
    Tony
    That is the tranny kit I am looking at. Kinda not sure about the oil cooler side.
    Anyone added an oil cooler?
  18. May 21, 2022 at 12:02 PM
    Silver17
    Eastern PA
    Saw this the other day. The tow package comes with an oil cooler built into the oil filter housing. Non tow package doesn’t have an integrated cooler. How great does it work compared to an aftermarket style, who knows.
    omgboost and Saltyhero13 like this.
  19. May 21, 2022 at 12:03 PM
    Saltyhero13
    Found this and cross posting it here:
    https://youtu.be/9EEmmccrT8M
    omgboost and Silver17[QUOTED] like this.
