‘87 Suburban family cruiser
Discussion in 'Other Builds' started by Mountun Goat, May 19, 2022.
  1. May 19, 2022 at 10:21 AM
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Hey gang.
    Here’s my next build project. (I tried going back to my old gm truck forum-and it suck’s compared to us!)
    Sold my bagged reg cab ls squarebody as it was too small for my family to fit in. So I picked up this fully loaded 87 burb for $800 in the fall from a buddy of mine.
    Needs some work to get it where I want it. First off, I replaced all the old leaky coolant hoses and a bunk fuel pump. Got it running and driving enough to call it for time being. It is running rich so have a few more things to check into before it’s road worthy for this summer. I’ve given it a tune up with new fluids, plugs (compression tested as well), fuel/air filters, o2 sensor, and a coolant temp sensor. Next on the tuning list is a tbi rebuild clean/inspection.
    Next, I’ve started a 6/6” static suspension drop on it. I replaced the ball joints and installed 3” lowering spindles, 3” drop coils up along with new shocks up front. The rear will be getting an axle flip and I’ll fab frame notches to make room with new shocks.
    For wheels I have 22” gm transports and 245/30r22 tires. The wheels will need to be painted the body white before installing tires.
    I have a set of 6-bolt conversion rotors for the front and a 2001 3.73 posi axle with discs I’ll slap under the rear. Should help out with the braking situation in a serious way. Once the truck is legit road worthy, I’ll start on body work. The truck is in really good shape other than the driver side must have been in an accident at one point and half-ass repaired. I’ll need a drivers front fender, door and rear quarter panel. It needs rocket panels and a passenger side rear barn door as it’s rusted. Luckily the interior on this truck is mint!
    The icing on the cake is the 5.3 ls and 4l80e I have sitting in the yard patently waiting. I’ll fab a turbo setup and install a cam before slapping this into the truck.
  2. May 19, 2022 at 10:32 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k Supercharged 2008
    :worthless:
    Agreed, all other forums suck. I have build threads on "relevant" forums for the buggy and the Hilux but they get absolutely zero attention there. Tundras is life.
  3. May 19, 2022 at 10:34 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha woo Tundra fam :fistbump:. My internet was being whack I had to restart it before I could upload pics haha! Here you are!
  4. May 20, 2022 at 3:02 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Finished the front drop last night. This is the ride height of the front. I’m stoked.
    I’m not fully done the front yet though.
    I’m going to drill the front rotors out to swap from 7/16” to 14mm studs so they match the rear axle. These wheels are designed for 14mm studs as well. Need to put brake pads back in too. I also have a poly sway bar bushing kit coming for it.
  5. May 20, 2022 at 3:33 PM
    Blueknights75
    Ron
    Clayton, NC
    Sweet!! I will be keeping up with this awesome build!
  6. May 20, 2022 at 3:36 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    As a tundra and bourbon owner @Mountun Goat I 112% approve of this!! Hell yeah, check out what I did in my thread in my sig with my 500$ suburban. LOL
    Sub'd!!!:yes:
    Mountun Goat[OP] likes this.
  7. May 20, 2022 at 4:48 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Wow haha that’s pretty close! :fistbump:
    I read your suburban thread a while back. I love what you did with it!
    papasmurf[QUOTED] likes this.
  8. May 21, 2022 at 5:42 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Ready for a coat of undercoat :cool:
    papasmurf likes this.
  9. May 21, 2022 at 6:43 PM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    That's going to be a skateboard!!! Noice!
  10. May 21, 2022 at 7:05 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha yes I guess it is. Never thought of it like that before haha
  11. May 22, 2022 at 4:07 AM
    My Tundra stock height 4WD, probably keep it there, but the project that'll outlive me is a '38 Chevy 4 door. I finished the frame and suspension before kids, then stopped for the higher priority. C-notched the frame and air bags...If I ever finish it, it'll be about 2" off the ground, slammed...I love that look!
  12. May 22, 2022 at 8:39 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Rad! I love lowriders-have ever since I’ve been able to breath haha. Here is a shot of my last (and first) build. Sold it in the fall for some more doors!
    PermaFrostTRD and papasmurf like this.
  13. May 22, 2022 at 10:53 AM
  14. May 22, 2022 at 1:39 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Easy part is done. Out with the garbage!
    I need a few parts for the rear end before I get ahead of myself and put it back under the truck. I need to get dust plates, calliper brackets and mount the brakes to it first.
    PermaFrostTRD likes this.
  15. May 22, 2022 at 3:35 PM
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    The low rider thing isn’t for me, but I appreciate what goes into them. Godspeed, @Mountun Goat - this looks fun
  16. May 22, 2022 at 3:37 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks :thumbsup:
    PermaFrostTRD[QUOTED] likes this.
  17. May 22, 2022 at 3:42 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    You are going the wrong way with it. Regardless that is a clean sub.
  18. May 22, 2022 at 5:24 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
