295/70/18 tire thread
Discussion in 'Wheels & Tires' started by Longtimecoming07, Sep 3, 2020.
  1. May 11, 2022 at 8:57 PM
    #211
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    Toyo ATIII's has my vote. No issues with alignment for me either after my Eibach lift.
  2. May 12, 2022 at 3:54 AM
    #212
    TexasTundra90
    TexasTundra90 New Member
    Aaron
    2022 Crew Max Army Green Tundra TRD Off-Road
    2022 Crew Max Army Green Tundra TRD Off-Road Mods so far: 295/70/18 Falken Wildpeaks ‘18 Battle Born wheels ‘1.75 Rough Country Leveling kit
    Very. Thicker side wall & more aggressive tread will lead to a bumpier ride.
    You can also expect your MPG to go down a bit as well.
  3. May 12, 2022 at 5:29 AM
    #213
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I have Cooper ST Maxx now...wearing well but incredibly loud on highway. Looking for a quieter alternative. I do fairly minimal off road but some for hunting.
  4. May 12, 2022 at 7:16 AM
    #214
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Access Tonneau,RCI skid,ADARAC M-Series,Fox 2.0,scratches
    You might check the air pressure to see what the shop set them at, quite a few like to put 50+ PSI in them because they're E-rated tires. Try dropping them to 40 PSI. If it's a repetitive bump-bump-bump, they might need to be rebalanced.
  5. May 12, 2022 at 7:59 AM
    #215
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Noticed your hood vinyl there. I have a silver sky as well and thinking about adding one. What do you think of it?
    Hotwire[QUOTED] and D4x4TRD like this.
  6. May 12, 2022 at 2:54 PM
    #216
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    imI’m glad I did it. Not only did it cover up quite a few rock chips but it helps to prevent new ones as well as cut down on some of the hood glare.
    D4x4TRD and Rgross2112[QUOTED] like this.
  7. Jun 6, 2022 at 4:48 PM
    #217
    J&ATundra
    J&ATundra |-|/-\\/\//-\| |
    Fort Worth, Texas but from Hawaii
    2018 Cement Toyota Tundra
    295/70r18 Falken Wildpeaks with 3.5 lift
    300BLK, JWest, FISHN43 and 1 other person like this.
  8. Jul 8, 2022 at 4:15 PM
    #218
    2020Turd
    2020Turd New Member
    2020 TRD 4x4 MGM
    Ok so here’s a long shot, anyone tried 295/70/18 on a TRD OF with the rough country 1.75 level kit?
  9. Jul 8, 2022 at 4:28 PM
    #219
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Stock Pro’s have about 1.9” lift and they fit fine. You should be ok with 1.75”.
  10. Jul 8, 2022 at 4:43 PM
    #220
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    You’re gonna rub. Somewhere.
    front mud flaps, sway bar, body mount, fender liners, skid plate. These are the rub spots. Some rub all some rub one or two. You’ll have to adjust one or more of those things.
  11. Jul 8, 2022 at 5:31 PM
    #221
    FISHN43
    FISHN43 New Member
    Ohio
    This is true. They’ll fit but might have some minor rubbing. When my Pro was stock with 295s I rubbed on the little flap thats mounted on the bumper. Only turning in reverse though. I just removed the flaps.
    PermaFrostTRD[QUOTED] likes this.
  12. Jul 8, 2022 at 6:19 PM
    #222
    2020Turd
    2020Turd New Member
    2020 TRD 4x4 MGM
    Appreciate the input! I'll report back once the Terra Grapplers get put on next Friday.
    FISHN43 likes this.
  13. Jul 11, 2022 at 12:47 PM
    #223
    Whateva
    Whateva New Member
    AZ Territory
    2013 Crewmax 5.7
    The short: 295/70r18 Nitto Recon GRAPPELATORS on 18x9 Icon Compression wheels. The wheel specs are +25 offset with 6" of back space.
    The long, because I know there's a shit ton of debate on 295's and I read damn near every 295 thread in this place: It had these grody Ultra 20's on it when I bought it 2yrs ago, it also had a spacer that looked to be about 1.5" so it sat pretty level. Rear was stock. It has about 130k on it now and obviously I'm a billionaire so I decided it needed new shocks and struts. I wanted the Icon stage 10 but my yacht needed a new helicopter so I went with the stage 1 (stage 8 coming later this year). The front adjustables sit at roughly the same height as the old struts with the spacer, so we'll call that between 1.5" and 2" of lift. After I got that done and took it in for an alignment, the tire dude noticed that the Wildpeak AT3's were cracked and separated all to F, which made perfect sense because on the freeway it felt like I was on a motocross track. In case I hadn't mentioned it before, I'm obviously a multi-billionaire so obviously it was time for new tires. They were not going on the curbed, gouged and frankly hideous 20" Ultra's. So, billionaires buy new wheels, too. While I was waiting for those I put 1" blocks in the rear because the new Icon's in the front aren't mush so it had developed a teeeeeeny bit of sag and we don't do that here. Stay away from Readylift kits on Amazon unless you like things that suck, and you like Tundra's so you probably don't. The front mudflaps were already gone and the liner things are close but no rub (I may update that with a stuff review later). A good inch of clearance on the UCA's. Didn't bother checking the skid plate or sway bar.
    The shorter: 1.5-2" in front, 1" garbage blocks in back. No rub. NO RUB.
  14. Jul 11, 2022 at 1:01 PM
    #224
    FISHN43
    FISHN43 New Member
    Ohio
    Well it looks really good! I wish I had your kind of money! :D
  15. Jul 11, 2022 at 1:07 PM
    #225
    PermaFrostTRD
    Northern NY
    Excellence in internetting. :hattip:
    also, nice truck !
  16. Jul 11, 2022 at 6:05 PM
    #226
    jaflynn738
    jaflynn738 New Member
    Virginia
    What width wheels and offset?
  17. Jul 11, 2022 at 7:58 PM
    #227
    JWest
    JWest New Member
    2019 Tundra Double Cab
    It looks like factory toyota rims. Same ones I have on my truck. So whatever the offset is on the factory wheels. You can run this setup without spacers but you'll be pretty darn close to the UCAs unless you add a spacer. I don't run a spacer on my setup and I'd say I have about a 1/2 to 3/4 inches of space between my UCA and tire.
    J&ATundra likes this.
  18. Jul 12, 2022 at 11:30 AM
    #228
    2020Turd
    2020Turd New Member
    2020 TRD 4x4 MGM
    stock suspension? Also, looks good!
  19. Jul 15, 2022 at 4:36 PM
    #229
    2020Turd
    2020Turd New Member
    2020 TRD 4x4 MGM
    I'll upload pics later, but I can confirm the 295/70/18 Terra Grapplers fit with no rubbing. 1.75 level
  20. Jul 15, 2022 at 9:23 PM
    #230
    jaflynn738
    Virginia
    Did you go with the 18x9 wheels? What offset?
  21. Jul 17, 2022 at 2:55 PM
    #231
    2020Turd
    2020Turd New Member
    2020 TRD 4x4 MGM
    They are the stock TRD OR wheels. 18x8
  22. Jul 28, 2022 at 2:55 PM
    #232
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    295/70r18 dick cepek trail country exp tires. I have 3.5” RC full strut in front and 2” rear block with bilstein shocks. Tires are around 34 1/2”. No rubbing. I did take the front mud flaps off and took the heat gun to the liner. Also tucked the front liner behind the bumper cap 3538A056-A8A1-4B44-9FF6-0B896143CF3C.jpg image.jpg bracket. They weren’t the tires I wanted. They were my 3rd choice because the other brands weren’t available. When these wear out I’m going to 35” or 37”.
  23. Sep 12, 2022 at 6:23 PM
    #233
    Geodude82
    Geodude82 New Member
    The truck looks great! I have a similar set up, 3/1 and am looking to go with those size tires and keep the stock wheels. Do you have any rubbing or had to do any trimming?
  24. Sep 12, 2022 at 6:38 PM
    #234
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    As you can see no wheel well trimming (without spacers). Trim the stock skid plate approx as shown.
    When I added spacers I had to take the heat gun and trim a little. Nothing crazy
  25. Sep 12, 2022 at 6:42 PM
    #235
    Geodude82
    Thanks! What spacers did you end up going with? I may just throw on a 1/4 shim.
  26. Sep 18, 2022 at 12:52 PM
    #236
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    I'm looking at going with this size tire in Falcon Wildpeaks on Fuel Vapor D560 18x9 and -12 offset. I am getting 5100s all around with the front at the middle setting. I also have the TRD Pro skid plate. Will I have any rubbing? Should I go with a different size?
  27. Sep 19, 2022 at 11:08 AM
    #237
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    With that poke, you're highly likely to rub front bumper when wheels are turned left or right, more so in reverse. Trimming the plastics might be enough, if not, a CB or other brand bumper shim kit should get you there. My +25 offset with 295 Cooper STT Maxx's rub there and no where else. I also have the pro skid plate.
    BamaMan44[QUOTED] likes this.
  28. Sep 19, 2022 at 5:37 PM
    #238
    BamaMan44
    Andre
    Tucson
    Copy and thanks for the response.
    The stock tires rubbed and they mudflaps were removed when they installed these rims with the stock tires on them. I also redid the front cover as well based on a guide on here. I do have Rokblokz mudflats now, but they are thinner than the stock ones. I'll into the shims as well. Thanks!
  29. Sep 27, 2022 at 5:17 PM
    #239
    Geodude82
    Hey, does this pic have the wheel spacers installed? If so, which ones did you end up going with? I'm not trying to go past the fender.
  30. Oct 15, 2022 at 2:24 PM
    #240
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    How was the clearance in the rear of the wheels wheel ? I have +40 mm which is 20mm further out than stock which is just shy of an 1” so it should be pretty similar situation. I have a CBI bumper so the front isn’t a problem. Thanks!
