Speedo correction
Discussion in 'Performance and Tuning' started by MikeyMTBs, Jun 19, 2017.
  1. Jun 19, 2017 at 11:15 AM
    MikeyMTBs
    MikeyMTBs [OP] New Member
    With install of taller tires, can y'all recommend any plug n play unit for speedo/ mpg correction? Or can dealer use Tech stream to set the tire size?
  2. Jun 19, 2017 at 11:16 AM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Look at the Hypertech. Some folks here have them and you can adjust the tire size yourself anytime you change tires.
    Look at this thread
    1UPPER and T-Rex266 like this.
  3. Jun 19, 2017 at 11:31 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    What size tires are you running. I run 34.5 inch tire and have not installed a calibrator yet.
  4. Jun 19, 2017 at 12:10 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    With the title of this thread I was afraid to open and read it, was expecting this!
  5. Jun 19, 2017 at 12:10 PM
    MikeyMTBs
    I'm running a slightly taller tire, 275/70/18 vs 275/65/18. It's not a huge difference but, 2-3% over 100k Miles adds up.
    Thanks... read that thread all the way through. I'm not really looking for a tuner. Jeez, with the tow/haul button activated, this 5.7 really changes personality and hauls ass!
  6. Jun 19, 2017 at 12:17 PM
    Hypertech Calibrator
    JC303 likes this.
  7. Jun 19, 2017 at 12:26 PM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    give a call. I can send out a speedo calibrator with great pricing. 760-877-4234
  8. Jun 19, 2017 at 12:27 PM
    MikeyMTBs
    Looks like what I want is part #730119, speedometer calibrator.
    JC303 likes this.
  9. Jun 19, 2017 at 12:27 PM
    MikeyMTBs
    Awesome.
  10. Jun 19, 2017 at 3:33 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Yeah. The Hypertech is the way to go.
    local-knowledge: When you install it, leave the USB cord attached, and dangle it down where you can reach it. That way if you need to tweak it later, or change to different size tires, you don't have to tear your dash apart again.
  11. Jun 19, 2017 at 4:08 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    2019 Silver Sky Platinum Crew Max
    Bed Rug, Tonneau cover, Window visors, Console organizer, Weather Tech's
    Bingo Bob beat me to it. I had Toyota do mine since they did the lift before I bought it. When I told the guy I wanted the cord left in there in case I needed to make adjustments he was like.... I have done dozens of these and have never thought of that what a good idea....Truth be told I think that idea came from here in a thread I read before I was a member.
    Also if you haven't purchased it yet give Keith @dirtydeeds a call. He's a great guy to work with.
  12. Jun 19, 2017 at 4:15 PM
    dirtydeeds
    Keith
    USA
    X3 on leaving it hangin'.
  13. Jun 19, 2017 at 4:16 PM
    chphilo
    Western PA
    If you check with the GPS speed, you will find that your speedometer matches it better than before. Stock Tundra's speedometer gives higher value than the actual speed.
  14. Jun 19, 2017 at 6:49 PM
    MikeyMTBs
    Well shit. I'll check it out.
    All great suggestions. Thanks.
    T-Rex266 likes this.
  15. Jun 20, 2017 at 5:17 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    It's ALWAYS better to leave it hanging...
  16. Jun 20, 2017 at 5:22 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    That's what I tell my wife all the time. Lol
  17. Jun 20, 2017 at 7:14 AM
    PNW-Tundra
    PNW-Tundra New Member
    Brent
    Washington
    2017 Crew Max SR5 TRD
    This caused me to check my speedometer with a GPS this morning because I plan to Instal the Hypertech this week to adjust for the 295/70/18 I will be putting in the truck this weekend. My truck is a TRD with the 275/65/18, and in stock form, the speedometer was exactly on with the GPS.
  18. Jun 20, 2017 at 10:35 AM
    chphilo
    Western PA
    This is an interesting read. https://www.theglobeandmail.com/glo...te-the-cars-speedo-or-the-gps/article4348596/
    "Typically, speedometers display readings that are slightly high. "If you thought you were going at the speed limit but were actually exceeding it - that would open car manufacturers to lawsuits. From what I've seen in reports, over 95 per cent of vehicles read high a few kilometres per hour," Langley says."
    (Richard Langley, professor of geodesy and precision navigation at the University of New Brunswick)
  19. Jun 20, 2017 at 11:35 AM
    Bear
    Bear
    Custer, SD
    My truck did. With the stock set up, 60mph indicated was actually 57.5-58
  20. May 19, 2019 at 9:07 AM
    Toyman42
    Toyman42 New Member
    Cody
    2018 4runner
    I am wondering if on my 2006 gen 1 if the tire height adjustment would help to stop my slip control from activating on turns. Toyota seems to think its being caused by the new tire height. I have done all kinds of re-cals and zero reset and steering angle resets, and yaw rate sensor shims/no shims, alignments, front bearings, and drive axle replacements, so far nothing has changed anything...
  21. May 25, 2019 at 5:09 PM
    flyfisher
    flyfisher Member
    Sunnyvale, CA
    2005 Tundra SR5 Double Cab 4x4
    Exact same issue on my '05 DC. Interested in what guys have to say here.
  22. May 25, 2019 at 8:59 PM
    Toyman42
    Toyman42 New Member
    Cody
    2018 4runner
    I replaced the yaw rate sensor also and I got the exact same results still the same. It is funny how many of the Double cabs in 2006/05 have these issues. Toyota should have to fix these issues since this is a safety related item! I know a guy that his truck is stock and even started doing it. One guy I talked to never had any problems until he had his steering rack replaced then it started having problems. With the same tires before and after.
  23. May 25, 2019 at 9:08 PM
    Toyman42
    Toyman42 New Member
    Cody
    2018 4runner
    I am trying to figure out how to tap in a toggle switch to the vsc circuit. Since the 4WD button turns off VSC is it a open or closed circuit? I need to figure out signal from the 4WD diff back to the ecu that creates the open/closed circuit to signal the vsc off. If anyone has a wiring diagram that could help that would be great.
  24. May 25, 2019 at 9:23 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Wouldn’t that be amazing. I would never have it activated cause every time I try to pull out into traffic from a gravel spot it activates and I gotta wait 5seconds till the throttle kicks back in and gives me juice again before I get rear ended! Also sucks driving freeway corners at speed, truck starts to beep, and then it slams on the brakes automatically....bastards
