Eibach PRO-TRUCK COILOVER STAGE 2 On Sale. Edit-Sale is OVER.
Discussion in 'Deals & Group Buys' started by Tundra14Platinum, Apr 2, 2021.
  1. Feb 15, 2022 at 8:15 AM
    #241
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    SECONDED.
    Pics or it didn't happen!
  2. Feb 15, 2022 at 9:46 AM
    #242
    SHAKA U F4KA
    SHAKA U F4KA New Member
    HONOLULU
    Factory preset with 1/2” Coachbuilder shim on drivers side, 1/4” Coachbuilder shim on passenger side.
    The Dude and cran2 like this.
  3. Feb 15, 2022 at 11:44 AM
    #243
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    sweet, they were set at 2 inches lift out of the box?
  4. Feb 15, 2022 at 3:25 PM
    #244
    SHAKA U F4KA
    HONOLULU
    Not sure, I believe they were preset to TRD pro height settings maybe 2.5”? like mentioned somewhere.
    My stock struts felt pretty worn out.
    These are some measurements I took real quickly center of wheel to bottom of fender.
    Stock front height measurements:
    Drivers side: 21-5/8”
    Passenger side: 22”
    After lift:
    Drivers side: 24-3/4”
    Passenger side: 24-3/4”
    hope this helps.
    Tundra14Platinum[OP] likes this.
  5. Feb 15, 2022 at 3:35 PM
    #245
    frichco228
    Frank
    Virginia
    It does, thanks. I measured mine before dropping it off, 22 inches both sides in front, center hub to bottom of fender. I will find out the new ride height tomorrow!!
    SHAKA U F4KA[QUOTED] likes this.
  6. Feb 16, 2022 at 8:43 AM
    #246
    frichco228
    Frank
    Virginia
    As promised, picked her up before work today. Looks great I think with my 33.4 tall tires! I will do a review once I have some seat time. Set at 2 inches. I filled up the gas tank (38 gallon) before dropping it off and the driver side is a little lower than passenger. So, I will run it as is for a little bit, allow the coilovers to break in and do any settling and when I install RAS for the rear I may adjust the fronts a bit to even them out or add some lift depending on how high RAS raises the rear. Drive from the shop to work was good. They feel very similar to the OR package shocks, dont nose dive with braking, firm but my OR shocks were too, ran smooth on the highway. Pics are not great, sun was at an odd angle and very bright, I will have better pics for the review.20220216_104946.jpg 20220216_095937.jpg 20220216_100008.jpg 20220216_095924.jpg
  7. Feb 21, 2022 at 9:50 AM
    #247
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    2019 Silver Sky Limited Crewmax
    Diamondback SE RCI skid plate Husky Mats WeatherTech bed-liner SCS Ray10's Eibach Stage 2 coilovers Toyo AT3 275/70/18 RAS HD Tuffy console safe
    Finally getting kit put on next week...
    Install quote seems a bit expensive but at this point want to have it done!
    $1400 to install front and rears shocks/coilovers, mount balance and alignment. Transfer TPMS from TRD wheels to SCS Ray10's with new Toyo AT3 275/75/18. I originally wanted 295/70/18's but would have needed SPC control arms. I'm hoping I'm happy with those tires. I'll post pics when it's done.
    SHAKA U F4KA likes this.
  8. Feb 22, 2022 at 11:24 AM
    #248
    frichco228
    Frank
    Virginia
    That is high. My install was $730 which included coilovers and rear shocks install and alignment.
  9. Feb 25, 2022 at 2:51 PM
    #249
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co., TX
    ‘17 CM TRDOR
    Not much…yet.
    For those wondering, I called Eibach and was told the included springs are 16” 650 lb, and they will accept any spring rate in the catalog.
  10. Feb 25, 2022 at 3:56 PM
    #250
    skip1980
    skip1980 New Member
    Columbia, Missouri
    Wow! That is high. Just put mine on over the weekend. Rears take 30 min and fronts took an hour a side. How many hours labor are they quoting you?
  11. Feb 25, 2022 at 3:57 PM
    #251
    skip1980
    skip1980 New Member
    Columbia, Missouri
    That's high also.
  12. Feb 26, 2022 at 6:40 AM
    #252
    frichco228
    Frank
    Virginia
    I was fine with the price. Trying to find a shop locally that would install customer parts vs parts ordered from them was a nightmare. Happy to spend 100-200 more and get it done vs waiting a few months until warmer weather and trying to install myself.
  13. Feb 26, 2022 at 10:42 AM
    #253
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    I'm in Northern VA everything is high!
  14. Feb 26, 2022 at 12:29 PM
    #254
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2, SmartCap, Ride Rite, Bora spacers, 35” rugged ridge tires.
    i did UCA’s also and it took a while to complete. I also did air bags in the back. I learned some tricks along the way I wish I knew ahead of time. Like when my cv shaft spit out and I had to pull the boot reinstall, grease and reband. Luckily I had the tools and the knowledge. Then I learned to only unhooks the LCA. Made the passenger side a breeze.
    The Dude likes this.
  15. Mar 1, 2022 at 2:20 PM
    #255
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    Finally done I'm happy with the ride! Just need to give it a bath. Gonna apply Dr. Beastly matte wheel coating tomorrow.
  16. Mar 1, 2022 at 4:39 PM
    #256
    skip1980
    skip1980 New Member
    Columbia, Missouri
    Just curious why you thought you needed spc control arms with 295/70/18's. That's the size I put on and not even close to rubbing control arms. What's your wheel offset. Mine are 18x9 with a +18.
  17. Mar 16, 2022 at 7:52 AM
    #257
    frichco228
    Frank
    Virginia
    Question- does anyone know the motion ratio for the Tundra? I need to adjust the diver side up about a half inch to compensate for the 38gallon tank weight to match the passenger side. I am going to guess I would raise .25( show .25 more of the coilover threads) to increase ride height a half inch. Can anyone confirm?
    And here she is with RAS HD installed, added an inch of rake back, so effectively a 2/1 lift.
  18. Mar 16, 2022 at 8:02 AM
    #258
    Elduder
    Elduder New Member
  19. Mar 16, 2022 at 8:06 AM
    #259
    ScenicRoute
  20. Mar 16, 2022 at 8:13 AM
    #260
    frichco228
    Frank
    Virginia
    Thanks! Eibach just responded as well and they said it was technically .63 to 1. So I should be good to go raising the driver side just under 1/4 inch to gain a half inch height.
  21. Mar 31, 2022 at 4:24 PM
    #261
    DiamondW
    Kent
    Gonzales Co., TX
    ‘17 CM TRDOR
    Not much…yet.
    Anyone heard when the rear resi shocks are gonna drop?
  22. Mar 31, 2022 at 5:25 PM
    #262
    memario1214
    Colton
    Missoula, MT
    RobertD and DiamondW[QUOTED] like this.
  23. Mar 31, 2022 at 6:12 PM
    #263
    DiamondW
    Kent
    Gonzales Co., TX
    ‘17 CM TRDOR
    Not much…yet.
  24. Apr 2, 2022 at 3:00 PM
    #264
    Smokingloon
    Smokingloon New Member
    I am almost certain I will order a set once it drops.
    When I called eibach a week ago asking when the front covers will be back in stock. They told me around April 15th time frame. Hopefully the rears show up around the same time.
    DiamondW likes this.
  25. Apr 4, 2022 at 4:42 PM
    #265
    Elduder
    Elduder New Member
    Eibach is running a 10% off right now.
    SHAKA U F4KA and DiamondW like this.
  26. Apr 8, 2022 at 4:34 PM
    #266
    DiamondW
    Kent
    Gonzales Co., TX
    ‘17 CM TRDOR
    Not much…yet.
    Saw this comment from Eibach on YouTube. Hopefully more accurate than their last target lol.
  27. Apr 8, 2022 at 7:02 PM
    #267
    Sc00ter
    Sc00ter New Member
    AZ
    Total noob question, but I installed the fronts and am getting an alignment, if I install the the rears later am I going to have to get another alignment? My gut is telling me no, but I want to know for sure since I couldn’t really find anything online/on the forum
  28. Apr 8, 2022 at 7:04 PM
    #268
    Elduder
    Elduder New Member
    No alignment needed for the rear.
    Sc00ter[QUOTED] likes this.
  29. Oct 27, 2022 at 2:17 PM
    #269
    JohnnyMoxon69
    JohnnyMoxon69 New Member
    2011 Tundra Limited Crewmax
    Truck looks great! I'm leaning towards the same setup. Which shim did you get from Coachbuilder? I see three different ones on the site .25", .50" and 1.00". Did you need to buy replacement bolts to use the one shim?
    Thanks!
  30. Dec 20, 2022 at 3:49 PM
    #270
    RobertD
    Robert
    DFW, Texas
    I will say, I do not own Eibach shocks and Memario has always been amazing with his communications. I reached out to Eibach with some pretty generic questions and I'm going on over 3 months of them looking like complete idiots and they still haven't addressed my question that should have taken less than 5 minutes.
    If not for @memario1214 I would totally write off Eibach based on my current experience with them. Just beyond disappointed
