Eibach PRO-TRUCK COILOVER STAGE 2 On Sale. Edit-Sale is OVER.
Discussion in 'Deals & Group Buys' started by Tundra14Platinum, Apr 2, 2021.
Thread Status:
Not open for further replies.
  1. Feb 16, 2022 at 8:43 AM
    #241
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    As promised, picked her up before work today. Looks great I think with my 33.4 tall tires! I will do a review once I have some seat time. Set at 2 inches. I filled up the gas tank (38 gallon) before dropping it off and the driver side is a little lower than passenger. So, I will run it as is for a little bit, allow the coilovers to break in and do any settling and when I install RAS for the rear I may adjust the fronts a bit to even them out or add some lift depending on how high RAS raises the rear. Drive from the shop to work was good. They feel very similar to the OR package shocks, dont nose dive with braking, firm but my OR shocks were too, ran smooth on the highway. Pics are not great, sun was at an odd angle and very bright, I will have better pics for the review.20220216_104946.jpg 20220216_095937.jpg 20220216_100008.jpg 20220216_095924.jpg
  2. Feb 21, 2022 at 9:50 AM
    #242
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    2019 Silver Sky Limited Crewmax
    Diamondback SE RCI skid plate Husky Mats WeatherTech bed-liner SCS Ray10's Eibach Stage 2 coilovers Toyo AT3 275/70/18 RAS HD Tuffy console safe
    Finally getting kit put on next week...
    Install quote seems a bit expensive but at this point want to have it done!
    $1400 to install front and rears shocks/coilovers, mount balance and alignment. Transfer TPMS from TRD wheels to SCS Ray10's with new Toyo AT3 275/75/18. I originally wanted 295/70/18's but would have needed SPC control arms. I'm hoping I'm happy with those tires. I'll post pics when it's done.
    SHAKA U F4KA likes this.
  3. Feb 22, 2022 at 11:24 AM
    #243
    frichco228
    That is high. My install was $730 which included coilovers and rear shocks install and alignment.
  4. Feb 25, 2022 at 2:51 PM
    #244
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    For those wondering, I called Eibach and was told the included springs are 16” 650 lb, and they will accept any spring rate in the catalog.
  5. Feb 25, 2022 at 3:56 PM
    #245
    skip1980
    skip1980 New Member
    Columbia, Missouri
    Wow! That is high. Just put mine on over the weekend. Rears take 30 min and fronts took an hour a side. How many hours labor are they quoting you?
  6. Feb 25, 2022 at 3:57 PM
    #246
    skip1980
    skip1980 New Member
    Columbia, Missouri
    That's high also.
  7. Feb 26, 2022 at 6:40 AM
    #247
    frichco228
    I was fine with the price. Trying to find a shop locally that would install customer parts vs parts ordered from them was a nightmare. Happy to spend 100-200 more and get it done vs waiting a few months until warmer weather and trying to install myself.
  8. Feb 26, 2022 at 10:42 AM
    #248
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    I'm in Northern VA everything is high!
  9. Feb 26, 2022 at 12:29 PM
    #249
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    i did UCA’s also and it took a while to complete. I also did air bags in the back. I learned some tricks along the way I wish I knew ahead of time. Like when my cv shaft spit out and I had to pull the boot reinstall, grease and reband. Luckily I had the tools and the knowledge. Then I learned to only unhooks the LCA. Made the passenger side a breeze.
    The Dude likes this.
  10. Mar 1, 2022 at 2:20 PM
    #250
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    Finally done I'm happy with the ride! Just need to give it a bath. Gonna apply Dr. Beastly matte wheel coating tomorrow.
  11. Mar 1, 2022 at 4:39 PM
    #251
    skip1980
    skip1980 New Member
    Columbia, Missouri
    Just curious why you thought you needed spc control arms with 295/70/18's. That's the size I put on and not even close to rubbing control arms. What's your wheel offset. Mine are 18x9 with a +18.
  12. Mar 16, 2022 at 7:52 AM
    #252
    frichco228
    Question- does anyone know the motion ratio for the Tundra? I need to adjust the diver side up about a half inch to compensate for the 38gallon tank weight to match the passenger side. I am going to guess I would raise .25( show .25 more of the coilover threads) to increase ride height a half inch. Can anyone confirm?
    And here she is with RAS HD installed, added an inch of rake back, so effectively a 2/1 lift.
  13. Mar 16, 2022 at 8:02 AM
    #253
    Elduder
    Elduder New Member
  14. Mar 16, 2022 at 8:06 AM
    #254
    ScenicRoute
  15. Mar 16, 2022 at 8:13 AM
    #255
    frichco228
    Thanks! Eibach just responded as well and they said it was technically .63 to 1. So I should be good to go raising the driver side just under 1/4 inch to gain a half inch height.
  16. Mar 31, 2022 at 4:24 PM
    #256
    DiamondW
    Kent
    CenTex
    ‘17 CM
    Anyone heard when the rear resi shocks are gonna drop?
  17. Mar 31, 2022 at 5:25 PM
    #257
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    RobertD and DiamondW[QUOTED] like this.
  18. Mar 31, 2022 at 6:12 PM
    #258
    DiamondW
    Kent
    CenTex
    ‘17 CM
  19. Apr 2, 2022 at 3:00 PM
    #259
    Smokingloon
    Smokingloon New Member
    I am almost certain I will order a set once it drops.
    When I called eibach a week ago asking when the front covers will be back in stock. They told me around April 15th time frame. Hopefully the rears show up around the same time.
    DiamondW likes this.
  20. Apr 4, 2022 at 4:42 PM
    #260
    Elduder
    Elduder New Member
    Eibach is running a 10% off right now.
    SHAKA U F4KA and DiamondW like this.
  21. Apr 8, 2022 at 4:34 PM
    #261
    DiamondW
    Kent
    CenTex
    ‘17 CM
    Saw this comment from Eibach on YouTube. Hopefully more accurate than their last target lol.
  22. Apr 8, 2022 at 7:02 PM
    #262
    Sc00ter
    Sc00ter New Member
    AZ
    Total noob question, but I installed the fronts and am getting an alignment, if I install the the rears later am I going to have to get another alignment? My gut is telling me no, but I want to know for sure since I couldn’t really find anything online/on the forum
  23. Apr 8, 2022 at 7:04 PM
    #263
    Elduder
    Elduder New Member
    No alignment needed for the rear.
    Sc00ter[QUOTED] likes this.
  24. Oct 27, 2022 at 2:17 PM
    #264
    JohnnyMoxon69
    JohnnyMoxon69 New Member
    2011 Tundra Limited Crewmax
    Truck looks great! I'm leaning towards the same setup. Which shim did you get from Coachbuilder? I see three different ones on the site .25", .50" and 1.00". Did you need to buy replacement bolts to use the one shim?
    Thanks!
  25. Dec 20, 2022 at 3:49 PM
    #265
    RobertD
    Robert
    DFW, Texas
    I will say, I do not own Eibach shocks and Memario has always been amazing with his communications. I reached out to Eibach with some pretty generic questions and I'm going on over 3 months of them looking like complete idiots and they still haven't addressed my question that should have taken less than 5 minutes.
    If not for @memario1214 I would totally write off Eibach based on my current experience with them. Just beyond disappointed
  26. Dec 20, 2022 at 4:02 PM
    #266
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    What are your questions?
  27. Dec 20, 2022 at 4:34 PM
    #267
    RobertD
    Robert
    DFW, Texas
    I reached out to them in September to see if they had plan to release a Pro-series shock for the Tundra with a 2.5" shock body instead of the current offering which is 2". Expected a "No" but wanted to ask before black Friday sales.
    They still haven't addressed this and keep responding with useless info. The message today informed me that they fired the person who had bren working my ticket.
    That was it, no responding to my previous message or answering my initial question.
  28. Dec 20, 2022 at 4:44 PM
    #268
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    Interesting. Maybe them not answering means the 2.5” body is in the works.…
  29. Dec 20, 2022 at 4:46 PM
    #269
    RobertD
    Robert
    DFW, Texas
    I do not think so. They have essentially told me their current offering is fantastic.
    I do understand its a good product but that wasn't my question. I just didn't want to place an order, install the new components, and then have them release what I really wanted.
    Life has happened since September and suspension wasn't purchased, but I am still annoyed to get responses from them that don't answer the question I asked.
  30. Dec 20, 2022 at 4:51 PM
    #270
    dherring256
    2018 MGM SR5
    Fuzzy Dice
    I’m leaning more towards they will…. Eventually. They could have named the rear resi “stage 3,” but they may be leaving stage 3 open for a larger body.
    FWIW I had the stage 2 on my Tacoma before I traded it in, and I loved it. I just hated the new Tacoma.
Thread Status:
