Rattle on cold startup
Discussion in '2.5 Gen Tundras (2014-2021)' started by Brefftields, Feb 23, 2022.
  1. Feb 23, 2022 at 9:58 AM
    Brefftields
    Brefftields [OP] New Member
    2015 Crewmax
    My 2015 crewmax Has a rattle on start up, especially worse and rattles longer in cold weather. The rattle lasts typically for a minute followed by a click and no more rattle for 30 seconds or so then another click followed by more rattling. And it sounds like the rattle is a result of something in the engine turning on, the clicking noise before and after the rattle seems to me like something turning on and off. Anyone else experience this? I would love to resolve it, I take great care of my truck and it sounds like it’s falling apart until that rattle stops.
  2. Feb 23, 2022 at 10:11 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. Feb 23, 2022 at 6:11 PM
    Brefftields
    2015 Crewmax
    Thank you! At least I know now, not looking forward to the fix but glad to eliminate all the guessing. One of the links led to this YouTube video and that’s exactly what my 2015 5.7L sounds like. Noticed around 80,000 and getting louder around 130,000.
    https://m.youtube.com/watch?v=jxb4JwlMoeo
    Seafury and frichco228[QUOTED] like this.
  4. Mar 9, 2022 at 5:24 PM
    CWLE
    CWLE New Member
    Connie
    2015 Toyota Sequoia
    My 2015 Toyota Sequoia rattles like this, too. It s so loud. It doesn t always do it, but most of the time. I can hear it when I m driving. Did you figure it out?
  5. Mar 9, 2022 at 5:59 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Thicken up your oil use...5w30 if you aren't in a too cold of outside parking...I run 0w20 in winter and 5w30 the rest...MUCH quieter in all regards...
  6. Mar 10, 2022 at 5:20 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Welcome to the worst Tundra issue.
    I have it also, its bad.
    I have tried different oil weights and additives, makes no difference and can even be worse.
    Even my beloved Lucas oil stabilizer did not fix it.
    Save up the $2k+ and have it fixed once you can't take it anymore.
    I am letting mine go for as long as I can.
    When enough people point it out or complain about it, I'll eventually let some master tech crack open my pristine engine to fix it right.
    Once I find a trustworthy master tech that has done this before that is.
