Bad socket in overhead console dome light
Discussion in '2nd Gen Tundras (2007-2013)' started by Bozothedog, Mar 3, 2022.
  1. Mar 3, 2022 at 4:40 PM
    Bozothedog
    Bozothedog [OP] New Member
    I put new LED bulbs into the overhead and one kept falling out. Tried to adjust to fix it and now, I broke it. Went to the dealership today to buy a new part and was told that I would have to buy the whole console.....crazy. Anybody have a fix for this. Thanks
  2. Mar 3, 2022 at 5:55 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
  3. Mar 3, 2022 at 9:22 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    I had the same issue.
    pull the console down. 6 torx screws and unplug the power plug. You will be able to do all repairs from behind it.
    they use copper bands, like flat wire and looks like a circuit board but easy to work on from behind. You can solder repairs or bends things back into shape.
  4. Mar 3, 2022 at 9:29 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I did the same as @Jwood562 described. I bent and busted the flat metal and screwed up the prongs that hold the bulb. I was able to fix the prongs behind the unit. Two screws behind the glasses door, two behind the lower plastic cover.
    edit: I have the 2.5 gen but the process is about the same.
  5. Mar 4, 2022 at 7:22 AM
    dels67malibu
    dels67malibu New Member
    I had to do the same, on mine the plastic that held the prongs in was broken, so I used some epoxy to mold it back in place. It was broken by the previous owner, who put some crappy leds in it.
    BlueRibbon4x4[QUOTED] likes this.
  6. Mar 6, 2022 at 2:07 PM
    Bozothedog
    OP here...I took the overhead console out and repaired the socket mount....I used superglue and baking soda to hold the copper lines in place. All good now.
    NewImprovedRon likes this.
