Installing LED interior lights.
Discussion in 'Lighting' started by Mtneer4life, Oct 27, 2021.
  1. Oct 27, 2021 at 10:56 AM
    Mtneer4life
    Mtneer4life [OP] New Member
    Dusty
    2019 Cavalry Blue Tundra
    I installed the Fyre Flys brand LED interior lights yesterday. Ran into a problem though, curious if anyone else has had this happen. I started with the driver side map light and as I was attempting to push the bulb into the socket I must have pushed too hard and lifted the socket out of the point where it doesn’t make contact. I pulled the overhead console down and tried to repair it. But it looks like part of the circuit is broken. Is there a quick fix or do I need to purchase a new overhead console?
  2. Oct 27, 2021 at 11:06 AM
    Taco-Spike
    Two Trucks
    If it's broken probably need to replace.
    check some junk yards for totaled ones
    Not sure of the schematic's but soldering jumpers might generate functionality again to provide continuity and 'complete' the circuit ~ theoretically*
    Mtneer4life[OP] likes this.
  3. Oct 27, 2021 at 11:15 AM
    Mtneer4life
    Dusty
    Thought about trying to solder a jumper.
    Taco-Spike[QUOTED] likes this.
  4. Oct 27, 2021 at 11:17 AM
    Taco-Spike
    Two Trucks
    yeah, I mean, what's the worst that could happen? It wont work?
    Second thought on that, could create a short / surge and blow a fuse...? or something else? Just speculating here but these things happen
  5. Oct 27, 2021 at 1:01 PM
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    Wish I could do better than this, but keep searching. There’s a thread somewhere and there’s a fix or two for this. Same thread also was helpful when I installed the rest of my interior LEDs. I just wish I could remember what the thread was but I was looking for help, just try “interior LEDs” and it should be one of the bazillions that come up
  6. Oct 27, 2021 at 1:08 PM
    Gman8P0W1
    Gman8P0W1 New Member
    Utah
    21 Lunar Pro
    ADD Venom w/Rigid 30” AT Overland Summit KMC: 315/70/17 KO2
    I feel your pain helped a friend do his and it broke too
  7. Oct 27, 2021 at 1:10 PM
    justcuz
    justcuz 2.5 Gen Member
    the same thing happened to me.
    it could not be repaired.
    found a replacement console on ebay.
    all is good now.
  8. Oct 27, 2021 at 1:11 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    When I did mine, I tried inserting the bulb cross wise and crushed the contract. Lesson learned for me...check direction of bulb contacts. :crazy:
    Luckily, I was able to bend it back into place and get it to work. Battery was disconnected the whole time.
  9. Oct 27, 2021 at 1:25 PM
    Mtneer4life
    Dusty
    Yeah I didn’t think I was pushing it that hard.
  10. Oct 27, 2021 at 1:26 PM
    Mtneer4life
    Dusty
    How much did you pay?
  11. Oct 27, 2021 at 2:35 PM
    justcuz
    it was just under $100
  12. Nov 2, 2021 at 12:39 PM
    ekmason
    ekmason New Member
    2021 Tundra SR5 TRD Off-Road MBM
    I did the same thing on mine, but was able to repair it once I took the console down.
  13. Nov 7, 2021 at 12:18 PM
    CGP
    CGP New Member
    Happened to me too. I used one of these to pull and align the loose contact while pushing the led bulb up. Once it snaps into place, the pick is skinny enough to pull out. Make sure you have good lighting while doing this.
  14. Nov 7, 2021 at 2:49 PM
    Mtneer4life
    Dusty
    Ok thanks for mentioning this option. Mine looks as if the contact has broken. Did yours look as if it broke? And then you fixed it?
  15. Nov 7, 2021 at 4:06 PM
    Mtneer4life
    Dusty
    Ok thanks I’ll look more closely at what you are describing and compare it with what my socket looks like. I didn’t push that hard in my opinion. If it looks like the welds came loose I’ll try the fix you mentioned.
    NewImprovedRon likes this.
  16. Nov 7, 2021 at 4:50 PM
    CGP
    CGP New Member
    hard to say. I remember that that metal clip kept shifting to the side and up in when I push the bulb in. So I need way to stabilize it while pushing the bulb. Once the loose metal clip latches on the bulb (all the way in), it didn’t matter being loose because the other metal clip was holding the everything in place.
  17. Nov 10, 2021 at 5:20 PM
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    I had this happen to me today out of the blue. The socket was loose and pushed in (map light). I didn't research how to remove the console and found out about the plastic tabs on the circuits until after the damage was done...
    I took a small set of pliers and was careful not to touch anything and started trying to bend the socket back into place while the console was still installed and battery was still connected (I know....I know). Blew the fuse for the dome light as when I flipped the switch from off to on...nothing came on. Then hopped on tundras.com and found out how to remove the console and I fixed the tabs on the circuits near the map light that was problematic.
    Then comes the drop of your stomach falling down a roller coaster...the cargo lights don't work. Fuse looks good for the cargo lights, but don't have any spare 7.5 amp fuses in the garage.
    Tomorrow- picking up a few 7.5 amp fuses and praying I didn't burn up the body ECU. Also, will dig out my voltmeter to see if I got voltage at the sockets.
    I've had LEDs installed for 4 years since buying the truck, but (1) map light rattled loose...now I got a sick feeling in my stomach.
  18. Nov 11, 2021 at 5:01 PM
    DanTundra
    DanTundra Danny
    Wilmington, NC
    Yup, I learned my lesson.
    I didn't want to thread jack this thread, so I started a new thread with my current issue. Replaced blown dome fuse under the hood, but still don't have cargo lights which I replaced that fuse even though it tested good.
  19. Nov 12, 2021 at 1:55 PM
    DanTundra
    DanTundra Danny
    Wilmington, NC
    Interior lights came back with replacing the dome fuse which was blown.
    Tested the cargo lamp fuse this morning and tested fine with a test light.
    After work going to try to test at the switch, then the socket.
