19 Tundra overhead console
Discussion in '2.5 Gen Tundras (2014-2021)' started by jaredmorganlv, Nov 25, 2020.
  1. Nov 25, 2020 at 8:46 PM
    jaredmorganlv
    jaredmorganlv [OP] New Member
    2019 crewmax TSS
    I did the LED swap into my overhead console when I bought the truck. Fell victim to crappy LED’s and had a flicker. When I replaced the map light led the prongs broke off and it’s not repairable. My question is the copper power ribbon replaceable or do I need to order a complete new overhead console.
  2. Nov 25, 2020 at 9:43 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Can you pull the console down and try to solder the prongs back on?
    If not, you're probably looking at buying the entire assembly..
  3. Nov 25, 2020 at 11:09 PM
    fiveduece
    fiveduece I like to party.
    Brandon
    2020 TRD sport MGM crewmax
    tint, N-Fabs, trifold cover, bilstein 5100 w/spacers, +2 shackles, MT deegan wheels
    Which side broke? I have an extra console that I'm pretty sure the passenger side is good on. I can check in the morning for sure, if it will do you any good
  4. Nov 25, 2020 at 11:17 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    No. It didn't break. It just pushed the copper off the tabs. Normally. Just pull it down and you will see. Easy fix man.
  5. Nov 25, 2020 at 11:19 PM
    netranger6
    Jeremy
    You sure they broke off? Typically happens on the right side. You push bulb in. Like after market led. And it pushed the 2 contacts off the board. There are 2 little nipples that hold each one. I ahd same experience. More than once.
    BravoDeltaRomeo likes this.
  6. Nov 25, 2020 at 11:21 PM
    netranger6
    Jeremy
    The 2 prongs that hold your bulb. Looking up at them. If you can't see them well, they are likely just up off the board. Leds fit a little tighter and thats normally what happens. You simply end up pushing them up off the board.
  7. Nov 26, 2020 at 5:50 AM
    jaredmorganlv
    2019 crewmax TSS
    Well I had them slip off the nipple before a couple times. Then in an effort to add tension back to the clips I re-bent them in and of course you know what happened. The prongs snapped and I’m stuck with one map light. The driver side is the one that is damaged. I’ve tried finding the part on Toyota’s parts page but can’t find exactly what it’s called.
    netranger6 likes this.
  8. Nov 26, 2020 at 8:49 AM
    fiveduece
    Brandon
    I can't do you much good, drivers side was also the ones I broke. Pretty certain they are bent 180 degrees different between passenger and drivers side.
    Found complete overhead console online from a junkyard. It was like $80 or something. Good luck. Let me know if you think passenger side will work, they are yours.
  9. Nov 26, 2020 at 11:00 AM
    netranger6
    Jeremy
    When I do my 21 next week. I am literally pulling it down to install them.
