  1. Jan 23, 2022 at 12:27 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Passenger side is mounted. The coating on my headers was a bit thick in the threads and I didn’t catch it at first. Really dodged a bullet but be warned to anyone installing these. Chase the threads. It’s not an issue going in, it’s coming out that will be an issue later. I put the wrong sensor in the bung. Realised after I had snugged it down. Removing it I found out how good of a thread locker ceramic coating is. Luckily threads in the bung are safe. I need to get a new oxygen sensor now though. [​IMG] [​IMG] [​IMG] [​IMG]
    Voss, oscardog86, chrisb and 7 others like this.
  2. Jan 23, 2022 at 1:05 AM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    Nice save. That must have been a pucker moment. Those Looong tubes look real sweet! Engine mounts are cool too. Glad it's coming together.
    5N0W808 and empty_lord like this.
  3. Jan 23, 2022 at 1:11 AM
    empty_lord
    05 rollover special
    Your gracious sale of these to me expedited the header install. Lol. These were probably going to be put on the back burner till summer before you offered these
  4. Jan 23, 2022 at 1:34 AM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    I'm glad it worked out, my man! Entertainment for all of us. I assume you got some sweet exhaust to put on?
    alb1k likes this.
  5. Jan 23, 2022 at 1:36 AM
    empty_lord
    05 rollover special
    All DIY 304 stainless. 3” GESI cats directly off the manifolds to a 3” to 2.5” reducer out to an x pipe then eventually 2 QTP screamer mufflers I’ll have wired to a wireless box controlled by a fob I can then program to my home link mirror and seamlessly control my exhaust from my mirror
    mufflers are a few months out likely because $$$ it’ll be dumped before the axle till then.
    I’m just trying to be kind to the people around me and have a way to make the truck quiet for night.
    oscardog86, chrisb and bmf4069 like this.
  6. Jan 23, 2022 at 1:51 AM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    Haha, that will be so cool! :rofl: Like hittin' the nitrous button. Yee Ha!
    alb1k likes this.
  7. Jan 23, 2022 at 7:06 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Nice, I'll check them out. Thanks!
  8. Jan 23, 2022 at 7:12 AM
    Yesterday I:
    • Rolled around on my creeper and checked all my slider bolts
    • Did the same for my lower bj bolts
    • Snugged up the bolts for my Skid Row armor
    • Reapplied Fluid Film's new competitor "BP Blast Surface Shield" Don't tell FF I'm cheating on them
    • Buffed out some scratches from my driver side after plowing through those snow covered trees a few weeks ago. Gotta love white for not showing pin stripes.
    oscardog86, chrisb, bmf4069 and 5 others like this.
  9. Jan 23, 2022 at 7:46 AM
    Daaaaamn, you must be grateful that sensor came out without snapping off or something else stupid. What a shitshow that would've been to need to drill its corpse out of a new header.
  10. Jan 23, 2022 at 12:23 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Voss, hammeron, w666 and 8 others like this.
  11. Jan 23, 2022 at 6:08 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    I bet if you were handy with some power tools and a welder, you could fab a crash bar that would still allow you to run the winch plate.
    oscardog86 and chrisb like this.
  12. Jan 23, 2022 at 6:08 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    oscardog86, alb1k and 5N0W808[QUOTED] like this.
  13. Jan 23, 2022 at 6:23 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    I'd look at the ARB front air locker. Those Powertrax lunchbox lockers are finicky for on-road use.
    oscardog86 likes this.
  14. Jan 23, 2022 at 6:35 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    That's a question for someone else. I'm not sure quite frankly.
  15. Jan 23, 2022 at 6:40 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Correct, even if it didn't have an ADD it would still be fine in 2wd. Those type of lockers only lock when there's power input from the prop shaft.
    oscardog86 and 5N0W808[QUOTED] like this.
  16. Jan 23, 2022 at 9:00 PM
    alb1k
    Left Coast
    It's good
    Tie rods, the extended sway links have been there a while. I see you have the link - good for a front level or a tad bigger.
    5N0W808[QUOTED] likes this.
  17. Jan 23, 2022 at 9:13 PM
    alb1k
    Left Coast
    It's good
    I'm getting close to a locker for 2WD. Those links will definitely free up your front suspension - before I had them I had to disconnect the sway bar for full drop, and had a bent stock link. I'm in the 3" range.
    chrisb and 5N0W808[QUOTED] like this.
  18. Jan 24, 2022 at 3:14 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    It'll just pull you straight whatever direction the wheels are turned. Other than that not much.
  19. Jan 24, 2022 at 4:28 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    If you're in 4wd because the road has snow/slush on it, it could induce surprise understeer. I expect you can imagine how much fun that would be.
  20. Jan 24, 2022 at 1:37 PM
    06yotamike
    06yotamike New Member
    NC
    2006 Tundra DC XSP 4x4 4.7 Bluesteel Metallic
    Lubed up the tailgate lockups today, and geez, wish I had done that sooner, its like a new tailgate now.
    chrisb, bmf4069, NUDRAT and 4 others like this.
  21. Jan 24, 2022 at 1:51 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Did an oil change over the weekend. Was less than 3k miles since the last one but had been almost 5 months. Im at 96,366 miles on the odometer now. Just barely breaking her in!
    tacoguybill, KK6PD, chrisb and 4 others like this.
  22. Jan 24, 2022 at 2:04 PM
    Night and day, eh? I prefer the gauge @chunk proposed for 'how to know' when it's time to lube: If it takes more than two fingers to open, you need to lube it. At the age our trucks are, anything much more than 2 fingers of firm pressure is going to start breaking the plastics inside, and you'll be potentially fucked. Better to be proactive about it.
    If anyone has broken tailgate plastics or needs to lube, there's a thread for that here, and another one here.
  23. Jan 24, 2022 at 2:20 PM
    Just so you know, there is nothing wrong with going longer than 5 months. My last oil change was 12 months. I asked Blackstone labs about this a few years ago and they confirmed age doesn't really matter with modern oil.
  24. Jan 24, 2022 at 2:23 PM
    oscardog86
    Southern California
    Ive heard that so I wasnt super worried about it but I also use conventional oil and it isnt that expensive to just do it myself. But thanks for the heads up!
  25. Jan 24, 2022 at 3:23 PM
    JustJake
    JustJake New Member
    2006 AC
  26. Jan 24, 2022 at 3:27 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I ordered and installed OEM climate control knobs, and I gotta say, nice upgrade. There rotate so much better than whatever was already on there. Honestly, I can't believe I didn't consider this earlier.
    I also, lubed my tailgate handle, the rods, and latches. Much more better.
    And decided to build a small box to go in between the wheel wells to hold a sandbag or two to help with winter ice and snow. Keeps the weight over the wheels and prevents the sandbags from sliding around and smashing skis and boards in the back.
    oscardog86, chrisb and shifty` like this.
  27. Jan 24, 2022 at 3:28 PM
  28. Jan 24, 2022 at 4:07 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Started my front end work today. Broke 4 out of 6 of the top hat studs. Should have had those on hand. Also, noticed my upper ball joint boot was toast on one side. Haven't decided my approach for that yet. Figured out I only bought one boot kit for my axles, not sure why:censored:. Going to throw some Cardone ones in it and rebuild the OG's on my own time. And the best for last, when I unscrewed the power steering line, found out Previous owner was running regular power steering fluid....:censored:
    KK6PD, oscardog86, chrisb and 6 others like this.
  29. Jan 24, 2022 at 4:35 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Had some crazy strong winds in the Foothills of LA over the weekend.
    Luckily a much larger branch which broke off right above my roof somehow ended up in the middle of the street. Damage report…
    I consider myself lucky
    KK6PD, oscardog86, chrisb and 5 others like this.
  30. Jan 24, 2022 at 4:45 PM
    @Voss didn't you just have body work done? :(
    Voss likes this.
