Anyone with the power rear step able to take some photos and video?
Discussion in '3rd Gen Tundras (2022+)' started by DexterL, Jan 15, 2022.
  1. Jan 15, 2022 at 10:03 PM
    DexterL
    DexterL [OP] New Member
    21 lunar rock TRD pro Seqouia
    Wondering what it looks like under there vs the factory flinstone version for non platinum/ 1794's and if it will be retrofittable. Thanks!
    johnnygoodlife likes this.
  2. Jan 16, 2022 at 2:22 PM
    damnfingers
    damnfingers New Member
    Gene
    I'd like to see this too...getting too old to clamber up over the tailgate without help :)
  3. Apr 14, 2022 at 7:21 AM
    cephasiii
    cephasiii New Member
    2022 Tundra 1794 4x4 in Midnight Black and Rich Cream Leather
    Toyota Integrated Dashcam Rough Country Tri-fold Hard Tonneau cover
    Are you talking about the automatic bed step? If so, I can take a few pics.
  4. Apr 14, 2022 at 1:55 PM
    DexterL
    correct!
  5. Apr 15, 2022 at 10:03 AM
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    Not a great…video at this link (I hope): A36E9102-DB99-4C3F-8FBC-BFD428A7425D.jpg
    cephasiii and 1lowlife like this.
  6. Apr 15, 2022 at 10:04 AM
    22PlatWCP
    Mississippi
    Here’s opening:
    cephasiii likes this.
  7. Apr 15, 2022 at 10:06 AM
    SoCalJose
    SoCalJose New Member
    I wonder if the existing wiring is there on other models (like the limited) so that a power bed step and power running boards could be added later. Can anyone with a limited or other trim confirm that wiring is there?
  8. Apr 17, 2022 at 10:05 AM
    Pathfinder21
    Pathfinder21 New Member
    2022 Tundra Platinum - Crewmax 5.5'
    I’m not sure about the wiring. I have the Platinum that didn’t come with power running boards/power step, but included this option to the sale of it. So dealer is going to provide both once Toyota provides ability to get them. Does anyone know the Toyota Part numbers required ti get both the power running boards and power step? I keep wondering if dealer is not ordering them for me, hoping I will be satisfied with the TRD running board that came on my Platinum model.
  9. Apr 18, 2022 at 10:11 AM
    The Howard
    The Howard New Member
    2022 White Tundra SR5
    The part number has not been made available yet. Checked with the local Toyota dealership parts depot every week. Called and even showed up at the door of Amp Research in Tustin California also with no luck.
  10. Apr 21, 2022 at 9:23 AM
    Pathfinder21
    I’ll keep working on this accessory as well and let you know what I find out. I did see that Toyota does have specific part numbers that add up to the power running boards and power step, however, the motor assemblies that drive the running boards and bed step show that they are not available using www.parts.toyota.com.
    I was able to find part numbers online for all the related parts, but it appears that the motor assemblies, side auto step show “product not available”, the main part number for the Power Running Boards is 517010C020, the motor assemblies listed are 857600C040 and 857600C050. The power step assembly main part number is 523600C010 and the motor assembly listed is 857600C060 which also says “Product Not Available”.
    One of my local Toyota dealerships looked up the three motor assemblies and said that these motor assemblies were discontinued parts. Makes no sense to me since these running boards and power step will only fit the 2022 Tundras. I can’t imagine that the motors are already discontinued unless they are failing on the new Tundras, which I have not heard of any so far.
    I know that Toyota.com website is still allowing to build and provide the Power running boards and power step as an accessory on the Platinum/1794 trims, so why don’t they have this accessory available for their dealership? Must be another supply chain micro-chip shortage issue or manpower issue with Toyota.
  11. Apr 21, 2022 at 11:31 AM
    DexterL
    Or their supplier (amp research) doesnt want toyota selling these so they can sell them directly to you under their umbrella. Those of you holding your breath for toyota oem running boards added post build are most likely not going to ever get them, or pay 2x more than AMP will charge you.
  12. Aug 11, 2023 at 7:00 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    resurrecting an old thread...
    I was able to get the Dealer to add the rear step to my 1794, but it isn't powered. Is there a way to just add the powered component to the installed step, or are they two completely separate parts?
