Tundra Lean
Discussion in '2.5 Gen Tundras (2014-2021)' started by Arminius, Nov 27, 2021.
  1. Nov 27, 2021 at 7:51 PM
    Arminius
    Arminius [OP] New Member
    2019 Tundra Crewmax Limited OffRoad
    2.5 Kings OEM, no adjusters, ICON RXT Leaf Pack - Option 1, Fuel wheels, 285/60/20 Nitto Ridge Grapplers E load rating Light Truck, TRD duel exhaust, TRC cold air intake, TRD Pro grill
    Anyone else annoyed by this? It's like a crooked picture frame. Even though it's slightly off and you didn't notice it before, once you do it's all you see! My right side front is like 3/4 inches higher than the left and it's bothering me. I have the TRD Pro Fox suspension and Camburg UCA's with the Wescott spacers up front and back, but I'm thinking of removing the Westcott and Camburg UCA's and going with one of those Tundra spacers in the right side they sell at Toytech, but wanted to see if anyone else had the same problem or had tried the spacers on the ride side to level the front?
  2. Nov 27, 2021 at 7:56 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    A small top plate spacer on the driver’s side will knock that right out. I recommend you checking out Coachbuilder aka Ekstrom designs.
    619Tundra, alb1k and Arminius[OP] like this.
  3. Nov 27, 2021 at 8:05 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Wait, what? Why would you remove Camburg UCA's?
  4. Nov 27, 2021 at 8:23 PM
    Arminius
    It seems like they are allowing too much range of movement. Before, when I would turn full left or right and then let go of the steering wheel, the wheels would come back towards center. Now they don't return. They just stay full left or right.
  5. Nov 27, 2021 at 8:26 PM
    alb1k
    Left Coast
    It's good
    They allow for more droop or wheel drop, maybe. They are tighter than stock for steering and deflection. You are describing another problem. Do not take those off.
    Edit: Dude, you have Kings on there as well. Get to a good off-road suspension shop and talk to them. And, thank you for your service!
    HulkSmurf14 likes this.
  6. Nov 27, 2021 at 8:50 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    That’s alignment
  7. Nov 27, 2021 at 8:51 PM
    Arminius
    Actually, I had the Kings taken off and sold them for 75% of what I paid. I was very very unhappy with how they performed on the street. My ride quality on the street was AWEFUL! I put a used set of TRD Pro Fox shocks on and the poor ride quality went away. I don't jump my truck or beat it on the off road, so I learned my lesson not to go with a racing suspension if I am going to drive on the streets.
    Oey12 likes this.
  8. Nov 27, 2021 at 8:55 PM
    alb1k
    Left Coast
    It's good
    OK...but, the Camburg UCAs help don't hurt regardless, unless you are going back to stock height as well. Then, I don't think it matters. Still, go to a good suspension shop.
  9. Nov 27, 2021 at 9:18 PM
    Arminius
    Ok, I'll stick with the Camburgs. I just want a reliable truck that rides nice that I can take off road occasionally.
  10. Nov 27, 2021 at 9:21 PM
    alb1k
    Left Coast
    It's good
    Good call. But if you want to be sure, we can trade. I won't charge you anything.
  11. Nov 27, 2021 at 9:39 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The Westcott kit already uses 3/8 or 1/2 inch top plate spacers along with the collar lift. I’d need to look at mine, but I don’t think there’s a ton of room left for an additional shim… also, I thought the OEM Fox Pro were like the Bilstein Pro setup that compensated for the lean with different coils per side. Think those could be swapped?
    Arminius[OP] and Gunship Guy like this.
  12. Nov 27, 2021 at 10:19 PM
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    I’m on the TRD Fox setup with CB +2s in the rear. I have no lean. I’ve had it on other Toyota vehicles where I had an aftermarket setup, but Toyota compensates for the lean with their OEM suspension. I’m curious why you have it with an OEM suspension kit…
  13. Nov 27, 2021 at 10:44 PM
    alb1k
    Left Coast
    It's good
    Sounds like something is off. OEM, Kings, Camburg, no Kings, changes... either a lot of swaps without knowing why, or something else.
  14. Nov 28, 2021 at 5:23 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Wait your worried about a slight side to side difference? Hope you realize that when the truck is in motion it moves and flexes all around and the differences are a few inches all around so it's just about never equal. Plus that the fuel level, passengers, and or cargo loads will cause it to vary too. Kinda silly to compare it to a crooked picture frame that doesn't move. You might notice the wheel centercaps are out of line when you park too.
  15. Nov 28, 2021 at 5:46 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I had the lean and added a 1/4 inch shim above the drivers side strut when I added the 6112s…perfect now.
    Arminius[OP] and HulkSmurf14 like this.
  16. Nov 28, 2021 at 6:30 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Not sure if you subbed out the install, but did you check to make sure the left and right are installed on the correct sides?
    Terndrerrr likes this.
  17. Nov 28, 2021 at 7:26 AM
    Arminius
    I don't know if the TRD Pro setup has left and right sides but it would make sense if they did. I paid a shop to install everything because I don't have the tools or place to do it myself.
  18. Nov 28, 2021 at 7:27 AM
    Arminius
    I'll call the shop that installed it and ask them.
  19. Nov 28, 2021 at 7:30 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    look at the top of the reservoirs on each shock - that will tell you the shocks are at least on the right sides. Another member posted about his resis hitting other suspension components and turned out his shop installed everything on the wrong sides. It’s possible the springs got swapped if they mixed them while installing the Westcott kit.
    Arminius[QUOTED][OP] likes this.
  20. Nov 28, 2021 at 7:33 AM
    Arminius
    That's why I started the thread because I'm trying to find a solution other than just spending more money. I did a total of 3 swaps, or rather paid a shop to do it.
  21. Nov 28, 2021 at 7:35 AM
    Arminius
    I take it the tops of the reservoirs will have a L or R on them? I'll go take a look here in a little while, thanks!
  22. Nov 28, 2021 at 7:36 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I believe it should have LF or RF or something along those lines.
  23. Nov 28, 2021 at 7:37 AM
    ZPhilip
    Philip
    West Chester, PA
    Yes they do. I’m not sure if the spring differs left to right but the height of the spring perch does. I have the TRD Pro Fox and can confirm this height differential.
  24. Nov 28, 2021 at 7:49 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  25. Nov 28, 2021 at 1:45 PM
    Arminius
    Just checked and they are installed on the correct sides. I'll give Wescott a call tomorrow and ask a few questions.
  26. Nov 28, 2021 at 2:48 PM
    Terndrerrr
    Music City
    Dual 5.7s
    Here’s a pic from a different thread if anyone else is troubleshooting and could use it. The L (drivers side) is on top
    1bad10tacoma, Arminius[OP] and 1UP like this.
