  1. Oct 8, 2021 at 6:13 PM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    I got the same size in Coopers and have no rubbing issues.
  2. Oct 8, 2021 at 6:29 PM
    nhw544
    nhw544 Food fight!
    RVA
    Taco-Spike[QUOTED] likes this.
  3. Oct 8, 2021 at 6:43 PM
    RobertD
    Robert
    DFW, Texas
    What's chipping? Did you use a clear coat?
  4. Oct 8, 2021 at 6:47 PM
    nhw544
    nhw544 Food fight!
    RVA
    I used SEM trim paint. It’s chipping on the top part of the cup holder. Probably just abuse from taking the water bottle in and out.
  5. Oct 8, 2021 at 6:53 PM
    RobertD
    Robert
    DFW, Texas
    That sucks. Did you scuff the chrome at all before spraying it? I also added some clear after my SEM trim paint and its been holding up pretty good.
  6. Oct 8, 2021 at 7:09 PM
    Bergy24
    Bergy24 New Member
    Installed the JBL sub Enclosure from James Randy Taylor (Tech 12 Volts)
  7. Oct 8, 2021 at 7:20 PM
    Ragnarkov
    Ragnarkov New Member
    Stephen
    2021 Silver Sky Metalic Platinum Tundra
    Nothing.... yet.
    Thanks!
    Also, bronze. I spent weeks and weeks going over options before landing on those.
    50Shades[QUOTED] likes this.
  8. Oct 8, 2021 at 7:24 PM
    Ragnarkov
    Stephen
    Nothing.... yet.
    I've been looking at that insert bumper. How was the install? I like it's integration with the stock bumper. Clean, but still gives bull bar, lights, winch, all if you want.
  9. Oct 8, 2021 at 7:55 PM
    nhw544
    nhw544 Food fight!
    RVA
    I honestly don’t remember. If I did I obviously did a shitty job haha. I might give it another try. Gotta pull it out again to do the rear window switch relocation mod, so light as well spray it again.
    RobertD[QUOTED] likes this.
  10. Oct 8, 2021 at 7:59 PM
    RobertD
    Robert
    DFW, Texas
    I vote try painting it again before you spend money. If it works well, you can use that money for other mods!
  11. Oct 8, 2021 at 8:01 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Install Wasn’t to bad, measured twice-cut once;)
    Clean look and functional is my goal
  12. Oct 8, 2021 at 8:53 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Interesting. Mine is a 21 limited Crewmax. I sent RCI some pictures because I thought for sure I was missing a mounting point. I could only get 3 of the bigger bolts in on the drivers side. RCI said it looked good and that different years vary on the amount of hardware you can use without drilling.
  13. Oct 8, 2021 at 9:06 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Installed the Air Up Down system this evening …will test functionality tomorrow, but fully expecting it to run well after seeing one used in my buddy’s truck. Install wasn’t too bad, just a pain routing all the hose across the back wall and out to each of the wheel wells.
    I added Threadserts for the mounting bracket to give a more secure/sturdy platform as was concerned using just self-tapping screws might not be strong enough for the weight when off-roading.
    Last photo shows one of the connection valves at the driver’s side rear (chrome capped valve mounted on the frame)
  14. Oct 8, 2021 at 10:17 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Started my Tundra up about 3 or 4 times today and all of those times it seemed like the battery was having a tougher than usual time. I seem to remember a thread here or somewhere in this forum that stated our OEM batteries suck.
    I took delivery of my 2019 Tundra almost exactly 2 years ago. It seems like it's WAY TOO EARLY for the battery to be going bad.
    Anyone have any experience with this? Is it time for a new battery or do I need to do some simple maintenance on it?
    FYI, I don't have anything drawing off the battery that's not already stock.
  15. Oct 8, 2021 at 10:22 PM
    RobertD
    Robert
    DFW, Texas
    Stop off anywhere that does battery checks (dealership, Autozone, O'Reilly). My stock battery lasted about 30 months. At 24 months it is a little earlier than most but I wouldn't be surprised if it was the battery.
  16. Oct 9, 2021 at 5:04 AM
    NorthShore
    NorthShore New Member
    2014 SR5 TRD Offroad Crewmax
    What bumper is that? Looks great. Might have to grab one.
  17. Oct 9, 2021 at 5:06 AM
    Quote the post that you are referring to. We have no idea who's bumper you are asking about. :notsure:
    GODZILLA likes this.
  18. Oct 9, 2021 at 5:15 AM
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    haha thats true
  19. Oct 9, 2021 at 7:52 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I love the Sprayway. I've heard Dawn isn't really good for the top coat, though... I got some of the pink stuff, but it's pricey for soap and I'm a bit of a cheapskate on stuff like that. Sorry to hear about the nonsense - - been there, and it does take too much of your brain away for much too long. Have a better day.
    Tundratoofun likes this.
  20. Oct 9, 2021 at 8:13 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    That mounting point lined up with the welded nut on the back drivers side for me. I couldn’t get either of the provided bolts to work. RCI recommended drilling some extra holes, but I don’t want to do that at the moment. They did say that I shouldn’t have any issues once I can get that smaller bolt on the back. Weird Toyota changed the frame up so much, but I feel like RCI did a good job making the sliders as universal as possible.
    Lodge14[QUOTED] likes this.
  21. Oct 9, 2021 at 9:20 AM
    100LL
    100LL smells better than Jet-A
    NW Oregon
    2020 SR5
    Potatoes.
    It's well known here that the stock battery is trash.
  22. Oct 9, 2021 at 10:00 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    Should I get it replaced under warranty or just spring for a new battery myself?
    I did find a threat on the battery, here - https://www.tundras.com/threads/did-it-again.95754/page-3.
    The OP on that thread is trying to get it replaced under warranty whereas others are saying just bite the bullet and buy a new on yourself.
  23. Oct 9, 2021 at 10:08 AM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    Toyota actually replaced my battery on the first service visit - it had gone bad already, but not bad enough for me to notice.
  24. Oct 9, 2021 at 10:18 AM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I bit the bullet and traded her in......103750 miles and the dealer gave me $28,000 for it.
  25. Oct 9, 2021 at 10:34 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Such BS. I just replaced the battery on my 2015 4Runner, lasted 7 years and 100k+. Definitely won’t find that anymore. Costco’s deal/warranty on interstate batteries is hard to beat if anyone is looking for a new one.
  26. Oct 9, 2021 at 10:51 AM
    VadersTundy
    VadersTundy New Member
    2019 black sr5 crewmax
    A2A7E6D0-C736-49FB-8818-55DAD8A554B6.jpg Installed Bushwacker OE smooth fender flares. Wheels are +18 offset so it lines up pretty darn well
  27. Oct 9, 2021 at 11:05 AM
    Did you put PPF behind the flares?
  28. Oct 9, 2021 at 11:14 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    I know what you mean. I just got the tundra and I love the sound of a V8, but then I’m like “nah, I’m not trying to listen to that on the highway while towing.”
    mcharfauros likes this.
  29. Oct 9, 2021 at 11:38 AM
    CBrider
    CBrider New Member
    Cary
    Eugene, OR
    2017 1794 Edition TRD Sunset Bronze Mica TRD exhaust
    Diamond Back Cover
    Installed 2019+ TRD Pro headlights and color matched bumper ends. The bumper ends were powder coated with Prismatic Powders' Lazer Copper. They are slightly darker than Sunset Bronze Mica.
    Before:
    After:
    GAknight, AggiePhil, TomC843 and 10 others like this.
  30. Oct 9, 2021 at 1:08 PM
    nhw544
    nhw544 Food fight!
    RVA
    Good point! Lord knows this forum just keeps giving me more ideas on how to spend money lol.
