Did IT Again
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nowhereman, Sep 27, 2021.
  1. Oct 2, 2021 at 8:27 AM
    #61
    Nowhereman
    Nowhereman [OP] New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    The only thing I can think of that I've added was one of those OBD2 chip sets that monitor your driving for insurance purposes.
    I can't believe that would drag down a car battery.
  2. Oct 2, 2021 at 8:30 AM
    #62
    I have a battery isolator on my Jeep for when I roll it. It’s like changing the battery out, so you lose those settings.
  3. Oct 2, 2021 at 8:32 AM
    #63
    Is it one of those chips that you send back or have to download information from a computer? Or does it do it WiFi?
  4. Oct 2, 2021 at 8:36 AM
    #64
    Nowhereman
    Al
    Monterey Bay area
    WIFI
  5. Oct 2, 2021 at 8:37 AM
    #65
    Nowhereman
    Al
    Monterey Bay area
    I also ordered a Diode for fuse block.
    Should stop any battery drain to the electronics.
  6. Oct 2, 2021 at 8:39 AM
    #66
    Nowhereman
    Al
    Monterey Bay area
    If the Diode works, then I ship back the battery isolate switch to Amazon.
    ColoradoTJ likes this.
  7. Oct 2, 2021 at 8:44 AM
    #67
    I bet the diode works. Still need to install one on my Jeep for drain, but I have to keep the battery disconnect anyway.
  8. Oct 2, 2021 at 8:58 AM
    #68
    Nowhereman
    Al
    Monterey Bay area
  9. Oct 2, 2021 at 10:23 AM
    #69
    PJR202
    PJR202 New Member
    I'm no battery expert, but can't they just measure the battery drain and do some math to determine how long it'll last?
  10. Oct 2, 2021 at 1:11 PM
    #70
    Nowhereman
    Al
    Monterey Bay area
    I don't think they're that intelligent at the dealerships.
    Whatever tests they did, they came back A OK so I got the paperwork from them.
    It happens again I get a new battery.
    sleepybear723 likes this.
  11. Oct 2, 2021 at 3:21 PM
    #71
    DVCNick
    DVCNick New Member
    2011 5.7 4x4 Double Cab
    If you have an amp meter you can measure the draw yourself.
    It is by design.
    The only way to "fix it" is buy an older vehicle without electronics that run on battery power all the time.
  12. Oct 2, 2021 at 9:54 PM
    #72
    Nowhereman
    Al
    Monterey Bay area
    The fix if I want the electronics active when not driving is to install a monster battery or a 2nd battery if I don't drive it regularly.
  13. Oct 2, 2021 at 10:00 PM
    #73
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    You seem to complain mostly without accepting other opinions. Why even ask?
  14. Oct 2, 2021 at 10:53 PM
    #74
    mgnchakar
    mgnchakar New Member
    2016 Black Tundra TRD 4x4
    Factory battery went 5+ years 60k I’ll take it
  15. Oct 3, 2021 at 6:06 AM
    #75
    Nowhereman
    Al
    Monterey Bay area
    Complain?
    I think not. I take all opinions in and process against my environment that I have to deal with.
    There are tradeoffs always through life. These recommendations are all feasible but come with tradeoffs.
    Doesn't mean there bad by no means.
    MGNCHAKAR just said he got 5 + years from his Toyota battery; that's what I expect from a battery also.
    Complain? you need to pick your wording a little better maybe next time?
  16. Oct 3, 2021 at 6:30 AM
    #76
    Factory batteries suck ass. I replaced mine in less than two years.
    I don’t believe the OB2 is drawing that. Hell, even when I had my scangauge hooked up I had no issues
    sleepybear723 and 2mchfun like this.
  17. Oct 3, 2021 at 7:48 AM
    #77
    34ford
    34ford New Member
    2018 sky silver DC 5300 miles
    none yet
    I have a 2018 SRS upgrade, sits in storage sometimes 6-8 wks. Only has 5800 miles. Never has problem stating w/o tender as no 110 volt where i store. Still has factory battery. My 2017 Jeep Rubicon w/ 800 miles and 2 yrs. old and on tender died . Who knows, Jeep battery replaced ,sat 6 wks. w/o tender, starts right up. I would think just luck of draw on battery a I live in Fl. and heat just cooks our batteries here. 34ford
  18. Oct 3, 2021 at 8:46 AM
    #78
    Nowhereman
    Al
    Monterey Bay area
    Noted... I'm just pulling every potential I can.
    I do not believe it can cause issues either.
  19. Oct 3, 2021 at 8:52 AM
    #79
    2mchfun
    I think CA summer has caused part of your problem and climate difference is part of the reason so many of us experience different results.
  20. Oct 3, 2021 at 11:55 AM
    #80
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Personal experience: OBD Veepeak bluetooth reader plugged in, 4 month old Northstar AGM battery drained to the point of a no start after two weeks. Happened twice. Only reason I learned this is a had a few spaces of just driving the other vehicle because of Covid.
    Reader removed, no issues. Scanguage is considerably more efficient as it isn’t broadcasting.
    T-Rex266[QUOTED] likes this.
  21. Oct 3, 2021 at 1:57 PM
    #81
    madera59
    madera59 New Member
    Michael
    2015 SR5 CC Tundra
    I haven't read through all the responses, so my apologies if i am repeating an earlier response. If you have an after market remote starter AND you leave your truck for an extended time..it will drain a weak, small capacity or old battery. Same goes for leaving a code reader attached.
    I have replaced my factory battery with a Kirkland ~ 800 CCA battery 84 month warranty...with great success. I had previously replaced with a new smaller CCA Kirkland battery ( showed compatible with tundra model)which was dead twice in one year..... Costco replaced at no charge.
    Kirkland is made by Interstate Which is part of Johnson Controls.
    One important thing to note: Retailers can and do have manufacturers make products to their own specifications, which sometimes are not as good or as reliable as the known brand.....usually as some components and or manufacturing processes are not the same as the manufacturers product..... But this allows the sub retailer to make a claim ( sometimes inaccurately ) that they have a top brand manufacturer making their product...and sometimes a better price point due to the changes, they just fail to mention that it is not the same spec..... So make sure you compare specs.....
  22. Oct 3, 2021 at 2:36 PM
    #82
    timsp8
    NY
    Have you tried to unplug it while parked? I’m not sure how they work, but if your phone is out of cell range and constantly looking for a signal it’ll drain the battery. The OBD thing might be doing the same thing.
  23. Oct 8, 2021 at 10:32 PM
    #83
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    I'm in agreement with the OP. His battery shouldn't be having problems and why spend any of his own money to try and get around it or rectify it when it should work from the factory without any heroic efforts.
    I just came upon this thread as my 2019 1794 is exhibiting battery problems and I recall there's been reports of shitty batteries. I took delivery on this truck almost exactly 2 years ago to the day. The battery should be fine. I haven't hooked anything up to it so everything pull off it is factory shit. Today I started it on 3 separate occasions and it took a few extra ooomphs to get it started. I'll keep an eye on it but my plan if it keeps happening is to take it down to the dealer and start the process for them to replace it. Last thing I want to do is spend a few hundred to a thousand bucks on a friggin battery. They should just work.
  24. Oct 8, 2021 at 10:41 PM
    #84
    AZBoatHauler
    So.Arizona
    There are a lot of things we could talk about that shouldn’t happen. A TRD Pro should have recovery points but come March people will be buying a $70k+ off-road truck without any.
    Some people value their time more than a relatively small amount of money. Making 3 trips to hear some service advisor’s BS isn’t all that appealing to most.
    2mchfun and Cpl_Punishment like this.
  25. Oct 9, 2021 at 4:36 AM
    #85
    2mchfun
    This x2 /\ /\ /\ for starters. Secondly, let's talk about sarters too. Starters are simply high torque DC electric motors, they do not like weak batteries. Folks who choose to squeeze by with weak batteries are likely to wind up with premature starter failure. Low voltage, turns to high amps, turns to high heat, turns to damaged starter. The starter is by no means easy to replace either and if diy is not on the table, be prepared to lay dow 1200-1500 bucks due to being a knucklehead. As a bonus, you will also be without your truck too! Maybe you will learn, maybe not.
  26. Oct 9, 2021 at 5:23 AM
    #86
    sleepybear723
    sleepybear723 New Member
    Does it have a “karr” alarm or some other dealer add on gps recovery system. Check the windows or door seal for stickers and under drivers side footwell for a mess of non factory wires.
  27. Oct 9, 2021 at 5:25 AM
    #87
    sleepybear723
    Cool you got 2 years out of a Toyota battery! Best I’ve managed is 18 months…
  28. Oct 9, 2021 at 5:27 AM
    #88
    sleepybear723
    Then get a new battery under warranty.
  29. Oct 9, 2021 at 9:46 AM
    #89
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    OK, I get it. We need to understand that Toyota put some shitty parts in our trucks. OK.
    If we are in agreement one of those is the OEM battery, then is Northstar the way to go? If I elect to buy my own battery, and would prefer to not spend $1k but more like $300 to $400, any recommendations? My Wrangler needed a new battery a year ago, I simply went to Walmart but it's my daughter's car and it needed immediate replacement.
  30. Oct 9, 2021 at 9:52 AM
    #90
    2mchfun
    Oreilly's ultimate gold, I always buy one of those about every 4-5 yrs for all my vehicles and never had a problem. Yes, I know, parts stores are high on battery prices.
