Recommended Remote Starter for 2021 Tundra
Discussion in 'Electrical' started by Browneye14, Sep 14, 2021.
  1. Sep 14, 2021 at 4:33 AM
    Browneye14
    Browneye14 [OP] New Member
    Sup Fellows! I have a 2021 TRD PRO Tundra with push to start. I am interested in getting a remote starter for the truck as we slowly enter cold season. Something to warm my bum up with. Any recommendations?
    Thank You,
    Browneye
  2. Sep 19, 2021 at 6:08 AM
    PapPap
    PapPap New Member
    Tennessee
    2021 TRD Sport
    I'm curious also. I just disconnected my "connected services" feature and it removed the remote start. Not a big deal because I really didn't like they way it turned the truck off when you opened the door.
    Wallygator likes this.
  3. Oct 6, 2021 at 7:37 PM
    Bentarm13
    Bentarm13 New Member
    Following. Toyota could not have created a worse remote system if they had gotten drunk, spun around 9 times, puked on their shoes and stuck a finger up their a*#ss.
    Wallygator, Tyman and WILLINH like this.
  4. Jan 2, 2022 at 3:45 PM
    welshmike
    welshmike New Member
    DFW
    2021 cement Sr5
    Power steps, tonneau cover, blacked out badges, custom under rear seat storage, mirror covers, 2017 Trd pro color matched grill, plasti-dipped rims and bumpers. Trail grid pro FRAC, Start-x remote starter, Loncky leather steering wheel, leather shift knob. Painted cup holder-gear selector trim. Desert eagle off road cat shield, skid plate. Yitamotor floor mats. Calipers painted black. Kenwood amp, pioneer dash tweeters, infinity rear door speakers and tweeters. De-badged, Trd rear sway bar, ham radio antenna. Half console safe. Kenwood DMX1057XR. CDT 6x9’s. Sound deadening on doors.
    I’m also looking for a starter for my ‘21. X-start is about $220 and 12voltsolutions is $350 ($270 if you have push button, I don’t). Both are plug and play with no wire cutting. If there are no issues with x-start, at over $100 cheaper, they’ll get my money.
  5. Jan 2, 2022 at 5:29 PM
    GaTundra79
    GaTundra79 New Member
    White 2021 SR5 4x4
    I installed x-start and it's worked fine. Usually takes 4 clicks to get it to crank instead of 3. You'll have to use your key to unlock the door, but the car does not cut off when you open the door.
    Wallygator and welshmike like this.
  6. Jan 2, 2022 at 7:04 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  7. Jan 9, 2022 at 4:59 AM
    digdug
    digdug New Member
    Doug
    2008 Crewmax
    Toytec Ultimate kit w/ Bilstein Fabtech UCA TRD stabilizer Boss shocks - Rear Airlift wireless one 35x12.5x20 Nitto G2 Grappler
  8. Jan 10, 2022 at 5:01 PM
    okcowboy
    okcowboy New Member
    No Mans Land (Tulsa, OK)
    2021 Tundra 4x4 1794 Edition Wind Chill Pearl
    I have the 12voltsolutions.com on my ‘21 with the App module and I really like it. I had one on my ‘19 also. It is kind of expensive but I like that it’s plug and play with no cutting/splicing.
    Wallygator, bflooks and digdug like this.
  9. Jan 27, 2022 at 11:41 AM
    medic_84
    medic_84 New Member
    2022 GMC Sierra 1500 Duramax 4x4 with a bench!!!!
    I have a tech12volt remote start on my 2016.... 3 pushes of the lock button from factory remote and she starts. I can use the remote to unlock the doors and get in all with the truck continuing to run. place key in ignition turn on and push on brake and you are ready to roll. JAMES IS AMAZING WITH CUSTOMER SERVICE!!!! My buddy just purchase a 2021 and while not listed on tech12volt website it will work as long as you have a key and not push button.
    https://shop.tech12volts.com/product.sc?productId=537&categoryId=59
  10. Jan 27, 2022 at 1:31 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Start X uses a Fortin Evo One Module, as does the other mentioned. I'm not sure what differentiates the two other than support and warranty. I purchased Start X before I was aware of the other, no complaints at all.
    Wallygator and welshmike[QUOTED] like this.
  11. Jan 27, 2022 at 2:15 PM
    medic_84
    medic_84 New Member
    When I was doing my research several people on here suggested James at tech12volts….. yes it’s a Fortin Evo module….. I think fortin plays well with Toyota….. had a remote start installed locally on the wife’s sienna and they pieced together a system using the same module as my truck.
  12. Jan 27, 2022 at 2:16 PM
    medic_84
    medic_84 New Member
    I’m sure most are respectable companies….. James and tech12volts used to be a recommended/sponsored vendor on here…. Not sure if that’s still the case…. Maybe someone else will chime in.
  13. Jan 28, 2022 at 1:00 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Wondering if you pulled the trigger on a remote start yet? I was debating between Start X which I found on Amazon for $179 https://www.amazon.com/Start-X-Remote-Starter-Splicing-Install/dp/B094Q5W683?ie=UTF8 and the tech 12v option. I also found some on 12v solutions which seem very similar but are much more expensive. I am a little concerned about range for the Start X, those that have it, is it decent range? I just basically want to be able to sit at my local bar and start my truck when I am getting ready to leave.
  14. Jan 28, 2022 at 1:24 PM
    19TurdPro
    2019 Tundra TRD Pro
    There is nothing inside either unit that determines range. This unit picks up the lock signal triggered by the OEM fob from within the wiring of the truck, so the range is whatever your stock fob does. You can either add long range, RF Fortin Transmitters (which adds their own fob and antenna), or use the CarLink CL6 cellular module (ASCL6), which is what I have. CarLink requires an annual subscription.
    Wallygator and Nbab23[QUOTED] like this.
  15. Jan 28, 2022 at 2:15 PM
    plact88
    plact88 MGM SR5 CM
    Tucson, AZ
    2021 MGM Tundra Crewmax
    VLED Interior VLED Cargo Light VLED Reverse Light Driverside Grab Handle Bilstein 5100 front 2nd setting TRD Dual Exhaust Black Chrome AJT Chrome Delete TRD Air Filter Tyger Side Steps TVD Vinyl Decals MGM Tundra Radio Decals TVD Vinyl Decals MGM Tailgate Handle Decals Tundra Tailgate Badge Chrome Moto Metal 970 wheels 275/70/18 KO2 Tires TRD Rear Sway Bar MGM Door Handles and Mirror Caps TRD Pro LED Black Housing Headlights Black Housing LED Fog Lights AJT Black Door Handles AJT Black Steering Wheel Controls Tacoma Leather Steering Wheel Pedal Commander TRD Pro Hood Scoop 12 Volt Solutions Remote Start Clazzio Leather Seat Covers
    I just installed my 12VoltSolutuons a month ago. Works amazing. For the '21 you will have to cut a wire and splice 2. It's really not too difficult, especially with an extra set of hands, 1 person holds and the other crimps. Has great connections and have had no problems at all. Won't have to cut a wire if you also purchase the long range fob or the app module.
    Wallygator and Nbab23 like this.
  16. Jan 28, 2022 at 3:03 PM
    welshmike
    DFW
    2021 cement Sr5
    I just ordered the Start-x, should be here Sunday. Let you know my thoughts as soon as I’ve installed it.
  17. Jan 29, 2022 at 7:14 PM
    welshmike
    DFW
    2021 cement Sr5
    Well, Sunday came early, Amazon dropped the start-x off today. I watched their install video while making the connections, took about 30 mins and works great. Two steps I did not do, under the hood pin, and, since mine is a ‘21, you have to splice into one wire to allow you to use the remote to unlock the door once you’ve used the remote to start it. May do it in a few days, for now, I’ll just use the key to unlock the door. Overall, very happy with the kit.
    Wallygator, Nbab23 and 19TurdPro like this.
  18. Jan 30, 2022 at 5:56 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Very cool. Mines a 2020 so I'll have to splice as well. Definitely going to purchase one and then add the Carlink down the road if I want a bit more range.
  19. Jan 30, 2022 at 11:05 AM
    welshmike
    DFW
    2021 cement Sr5
    carlink would be nice, I’m just too cheap, though, everything these days has a paid subscription attached.
    Nbab23[QUOTED] and Wallygator like this.
  20. Jan 30, 2022 at 4:33 PM
    19TurdPro
    2019 Tundra TRD Pro
    It runs over a cellular network. Those aren't free.
  21. Jan 30, 2022 at 5:51 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Yeah I think I saw it was around $40 a year and the first year is included in the price of the actual device. I don’t think that’s too bad for the convenience.
  22. Jan 30, 2022 at 6:05 PM
    19TurdPro
    2019 Tundra TRD Pro
    On the plus side, it also has a GPS locator. You'll never misplace your truck again.
    Nbab23 likes this.
  23. Feb 17, 2022 at 8:30 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    So I finally got around to installing the start X. Pretty straight forward other than it being a little tight for the wire splice. And double and triple checking that I was cutting the correct wire. I felt like I was diffusing a bomb.
    I added the carlink as well which took a while to program correctly but once I did works great.
    Vang530 likes this.
  24. Feb 27, 2022 at 9:29 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    My truck is an ‘18, so may be different.
    My remote start is a DEI product. I believe it may be a Viper. Stupid simple.
    Uses the OEM key and nothing else. I click “Lock” button three times to start. Truck fires up. Doors remain locked. When I’m ready to enter, I unlock with the key button and I’m in. Put in the key and turn it “On” position, touch the brake pedal, and slam it in gear. That’s it.
    Engine does not shut off unless I get the brake pedal prior to getting the ignition turned to “On”. This could be quite different with a keyless ignition…
    The ONLY thing I don’t like on mine is that the steering wheel doesn’t come to me if I remote start. It remains retracted. The work around is to touch the driver memory button on the door. Or, use the control knob to move the wheel.
    Nbab23 likes this.
