Compustar 4900S installation
Discussion in '2nd Gen Tundras (2007-2013)' started by BlueCrushSC16, Jun 1, 2021.
  1. Jun 1, 2021 at 4:41 PM
    BlueCrushSC16
    BlueCrushSC16 [OP] New Member
    Charleston, SC
    Detailed instructions for the Compustar 4900S remote start/ keyless entry installation in my '07 Tundra.
  2. Jun 1, 2021 at 5:34 PM
    BlueCrushSC16
    Charleston, SC
    Material needed:
    Compustar module - https://www.amazon.com/gp/product/B081ZFH11W/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
    Blade AL (immobilizer bypass) - https://www.amazon.com/gp/product/B0019807TG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
    Autopage flashing interface - https://www.amazon.com/gp/product/B0035F0KZC/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8
    Tesa Tape - https://www.amazon.com/gp/product/B00XPBB6L8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
    Other Consumables - zip ties, electrical tape, solder
    Total cost (outside of consumables I already had on hand): $234.45
    Total time to complete approx. 10 hours, but I was slow and methodical and had to do some additional reading to figure out some wiring and the flashing and programming of the unit. 21 wiring solder connections to make. I highly recommend solder vice vampire/ "T" taps for wiring connections.
  3. Jun 1, 2021 at 6:45 PM
    BlueCrushSC16
    Charleston, SC
    Pre-installation:
    1) Remove cartridge slot dust cover on the bottom of the CM-900.
    2) Insert BladeAL cartridge into the bottom of CM-900. Be careful not to bend any of the electrical contacts.
    3) Cut and tie back any UNUSED wires on harnesses to CN2 and CN3. USED wires on CN2 and CN3 harnesses are boxed red in the illustration of the next post. I left approx 3 inches on unused wires, tied back, and insulated in case I ever have to use them in the future. Wrapped harnesses with Tesa tape up to a certain point.
    The following YouTube video was somewhat informative:
    https://www.youtube.com/watch?v=TCt5UJPK65E
  4. Jun 1, 2021 at 6:52 PM
    BlueCrushSC16
    Charleston, SC
    Installation:
    1) Disconnect negative battery terminal
    2) Disassemble driver's side lower dash, lower shroud of steering wheel, and driver's side kick panel. I won't go into the steps necessary for this as there is plenty of documentation readily available on the internet.
    3) With access to wiring/ harnesses you can begin installation.
  5. Jun 5, 2021 at 2:25 PM
    BlueCrushSC16
    Charleston, SC
    Connect CN1 wiring:
    CN1 - 8 PIN /// OEM - 8 PIN (under steering column)
    1 - Red /// White
    3 - Red/Wht /// Light Blue
    4 - White /// Gray
    5 - Blue /// Black
    6 - Yellow /// Dark Green
    7 - Green /// Light Green
    8 - Black /// Ground (Bare Metal)
    CN1 - 8 PIN /// Connector with gray release tab (under driver's kick panel/ same connector as horn wire)
    2 - Grn/Wht /// Green
  6. Jun 5, 2021 at 2:44 PM
    BlueCrushSC16
    Charleston, SC
    Connect CN2 Wiring:
    CN2 - 20 PIN /// OEM - 7 PIN (under steering column)
    1 - Gray/Red /// 5 - Blue
    2 - Grn/Red /// 4 - Light Blue
    5 - Orange/Black /// Ground (Bare Metal)
    CN2 - 20 PIN /// OEM - OBDII Port
    6 - Brown/ Red /// 6 - Purple
    16 - Brown/ Yellow /// 14 - White
  7. Jun 5, 2021 at 3:02 PM
    BlueCrushSC16
    Charleston, SC
    Connect CN3 wiring:
    CN3 - 12 PIN /// OEM - 20 PIN (under steering clumn)
    4 - Black /// Ground (Bare Metal)
    6 - Orange/Wht /// Gray
    CN3 - 12 PIN /// Blue connector (under driver's kick panel)
    2 - Blue/Grn /// 14 - Light Green
    3 - Blue /// 16 - Pink
  8. Jun 5, 2021 at 3:46 PM
    BlueCrushSC16
    Charleston, SC
    Connect CN3 wiring:
    CN3 - 12 PIN /// Connector with gray release tab (under driver's kick panel/ same connector as parking light wire)
    7 - White /// Purple (horn)
  9. Jun 5, 2021 at 4:02 PM
    BlueCrushSC16
    Charleston, SC
    I installed the safety switch earlier in the install using a drill and unibit until the switch would slide in and I could put the lock washer and jam nut on the under side to secure it in place. You will have to adjust the height accordingly. I ran the Gray/Black wire from CN3 out of the firewall boot into the engine compartment and wrapped it in loom.
    CN3 - 12 PIN /// Hood safety switch
    8 - Gray/Blk /// Hood safety switch terminal (used red crimp lug)
  10. Jun 5, 2021 at 4:11 PM
    BlueCrushSC16
    Charleston, SC
    CN3 - 12 PIN /// Brake Pedal Connector
    9 - Light Blue/Wht /// Orange
    CN3 - 12 PIN /// OBDII Port
    12 - Yellow/Blk /// 9 - White
  11. Jun 5, 2021 at 4:24 PM
    BlueCrushSC16
    Charleston, SC
    Wiring complete!
    From here, I used the Tesa tape and wrapped everything up nice and tidy. I mounted the antenna in the upper left corner of the windshield and ran the wire down the A pillar to the control unit. I mounted the control and Drone units in the locations I wanted, dressed and zip tied the cabling to the units, making sure nothing was going to snag and break or rub causing a short circuit, and reinstalled the trim pieces removed for installation. DO NOT connect CN1 thru 3 to the control unit at this time! Your computer will not recognize the control unit when you go to program it.
  12. Jun 5, 2021 at 4:52 PM
    BlueCrushSC16
    Charleston, SC
    WARNING! Ensure your laptop is plugged into an outlet. The loss of power during a firmware update AKA "flash" could result in "bricking" your device (remote start control unit).
    Flashing and Programming:
    With CNs1 thru 3 disconnected and your laptop/ computer on, plug in the Autopage flashing interface USB side only to your laptop. Lt your laptop discover the device. Wait for the prompt telling you it is installed and ready for use. Plug in the other side of the Autopage flashing interface to the control unit CN6.
    Using Internet Explorer Login to:
    https://www.idatalink.com/
    Create an account. Just make up a company name, select independent installer (or something like that), and your email. Confirm your account via the email they send you. Login.
    You may have to update your plugin version (I did). Current version is 6.3.6. It should prompt you to update if your are not.
    When that's complete, click "Flash your Module" in the upper right hand corner of the web page. Use the drop down menus to select Make, Model, Engine, Trim, Etc... It should bring up the correct firmware and prompt you to start (or something like that). It will prompt you it's complete and the flash is successful. Disconnect the CN6 connector from the control unit and put away your laptop.
    Plug in CNs 1 thru 3, 5, 7 and 8 to the control unit. Reconnect negative battery terminal on the vehicle and make sure the hood safety switch is engaged. Follow the following programming sequence:
  13. Jun 5, 2021 at 4:54 PM
    BlueCrushSC16
    Charleston, SC
    Download the DroneMobile app from the App Store and check functionality of both key fob and phone app. Enjoy!
  14. Jun 6, 2021 at 10:45 AM
    W3agle
    W3agle New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    How well does the keyless entry work? Assuming it means what I think it means - if I pull on the door with the key fob in my pocket it will unlock?
  15. Jun 6, 2021 at 1:49 PM
    BlueCrushSC16
    Charleston, SC
    Sorry. Not that keyless entry. You still need to click the unlock button on the fob.
    W3agle[QUOTED] likes this.
  16. Jun 6, 2021 at 2:23 PM
    W3agle
    W3agle New Member
    San Diego, CA
  17. Jun 6, 2021 at 5:37 PM
    BlueCrushSC16
    Charleston, SC
  18. Sep 2, 2024 at 5:22 PM
    OnlyToyotas
    OnlyToyotas New Member
    2007 Tundra 4.7L
    We installed everything and completed the firmware update. However, we went to go through the programming sequence and it does not give us a blue light of any sort for the key programming. Everything works properly, except when you remove the key from the ignition (after auto starting) the truck will stay running even if you take the key out until you hit the auto start button again. Any suggestions?
  19. Sep 3, 2024 at 11:27 AM
    BlueCrushSC16
    Charleston, SC
    First off, I would try programming it again. There should have been no reason it didn't do what instructions stated. If that fails. I would contact Compustar and see what they say.
  20. Nov 20, 2024 at 9:19 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    This seems like a good system to replace my OEM one.... My immobilizer is starting to reject all of my keys. I know I'm resurrecting an old thread, but I may need this post to find it later.... lol.
