Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Aug 23, 2021 at 9:19 PM
    Just be leary of the tent of shame.
  2. Aug 23, 2021 at 9:20 PM
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
  3. Aug 23, 2021 at 9:22 PM
    Why is that mislabeled? Should be shame.
    :D
  4. Aug 23, 2021 at 9:22 PM
    Tundra2
    Noah
    Western Kentucky
    So what's the best source for Radiator hoses, and Spring clamps? Don't feel like using worm clamps like I did on the 2002. Rather do this one the right way the first time. @empty_lord
  5. Aug 23, 2021 at 9:23 PM
    Tundra2
    Noah
    Western Kentucky
    You don't understand the pain of a body clip flying into your eyeball at Mach Jesus, do you? I busted my damn knuckles, and my eyes in that damned tent more times than I want to admit. :rofl:
  6. Aug 23, 2021 at 9:26 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    OEM on spring clamps. Hoses too. Or use silicon hoses
    Tundra2[QUOTED][OP] likes this.
  7. Aug 23, 2021 at 9:30 PM
    Tundra2
    Noah
    Western Kentucky
    OK. Good idea to do alternator too? Rather have one big ass job I can pick at slowly as opposed to one job I have to keep taking things off for.
    No FIPG for the water pump? I see the kit you linked comes with a gasket, but I thought I'd read about Form-in-place-gasket used on the WP?
  8. Aug 23, 2021 at 9:39 PM
    empty_lord
    05 rollover special
    Get Toyota FIPG for the water inlet.
    Alternator is a good idea at the same time, if you want to do the upgrade you’ll need to cut the 3rd ear off the alt and re pin the plug. But a 150amp alt is damn near bolt on.
    No need to cut the ear if you get the 03-06 stud for the spot
  9. Aug 23, 2021 at 9:44 PM
    Tundra2
    Noah
    Western Kentucky
    Is there a specific FIPG that you would recommend? I don't always understand toyota's mumbo jumbo on their websites.
    Alternator changed in 2003? I remember seeing a post of one with a third ear and one without side by side. More amp means more light :drool:
    So a 2003 alt is a bolt on?
  10. Aug 23, 2021 at 9:48 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
  11. Aug 23, 2021 at 10:09 PM
    daveeasa
    ^^ And T2, I'm mid-flight on that (though I wimped out and handed the job to my mechanic since I don't have space to have the truck all opened up for longer periods of time and he does.) I'll let you know how it goes. I figured alternator, water pump and serpentine belt and tensioner were a good plan at the same time.
    Tundra2[OP] and Desert Dog like this.
  12. Aug 23, 2021 at 10:55 PM
    empty_lord
    05 rollover special
    there is coolant specific. but its like $80 a tube.. the oil pan black stuff works fine
    chrisb and Tundra2[QUOTED][OP] like this.
  13. Aug 23, 2021 at 11:41 PM
    Tundra2
    Noah
    Western Kentucky
    Thinking of going purple with the interior lights for various reasons, but like I mentioned in a post way back when. Purple might be Uber cool if I can find some 74s that are purple too
  14. Aug 24, 2021 at 12:07 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    4hi button will push in and stay pushed in. 4lo will push in and come right back out. If 4hi won't engage then 4lo won't either.
    Maybe I missed it but how many miles? (Edit: 289k found on what have you done page)
  15. Aug 24, 2021 at 2:13 AM
    Desert Dog
    I like how you think. It's good if one can budget in doing the alternator while it's more readily accessible during the tb job.
    Tundra2[OP] and daveeasa[QUOTED] like this.
  16. Aug 24, 2021 at 4:56 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    What happened to the Sequoia?
  17. Aug 24, 2021 at 7:04 AM
    Tundra2
    Noah
    Western Kentucky
    Sequioa isn't mine so no build thread.
  18. Aug 24, 2021 at 7:05 AM
    You need to do a video walk-around of this thing. One pic is a tease!
  19. Aug 24, 2021 at 7:11 AM
    If you end up loving this one, I'd be tempted the sell your AC since it needs a frame. I wouldn't want to insure 3 vehicles.
    Tundra2[OP] likes this.
  20. Aug 24, 2021 at 7:14 AM
    #50
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Hmm I was checking on Rockauto two weeks ago and I could've sworn they had the same kit for like $60 less plus the 5% code that's available on here. Now it says out of stock.
    Hurry up and put a cap on that thing.
  21. Aug 24, 2021 at 7:19 AM
    #51
    Where is this 5% code you speak up?
  22. Aug 24, 2021 at 7:25 AM
    #52
    des2mtn
    Shady Grove
    Tonto cover
  23. Aug 24, 2021 at 7:45 AM
    #53
    Tundra2
    Noah
    Western Kentucky
    So, I did a good walk around in the cool morning. Apparently, there was a lot that I missed when I was wallering around a Walmart parking lot about noon. The asphalt was about a million degrees.
    Kinda bummed if I'm honest. I didn't notice the cab rot because I didn't get in the passengers side. Can that be fixed properly???
    Most of this trash is from me. I'll run out to the trash deposit sometime.
    Also, I wallered around on the ground looking inside the frame near the front, and then my elbows couldn't take the heat of the asphalt any more. I glanced at the rear and called it good.
    Think I'll take this one to Toyota, and have it inspected for a new frame. That's about a 3 inch hole on the spare tire cross member.
    My tundra will never leave.
  24. Aug 24, 2021 at 7:51 AM
    #54
    Tundra2
    Noah
    Western Kentucky
    Also checked the fluids, radiator is just God awful.
    Rest of the engine fluids were at proper levels. Put half a gallon of distilled in it.. Pulled new check engine light codes today.
    Live data shows fuel system was in Open loop 100% of the time. I think I've got my work cut out for me with this 100% sure farm truck.
    Airbag codes.
  25. Aug 24, 2021 at 8:19 AM
    #55
    Desert Dog
    The rotted rockers suck but the good news is the old ones can be cut out and new ones welded and sealed in. It's done all the time.
    Try Corporate for the rest of your frame issues. If you don't have any success and you're determined to keep it, I don't see anything that can't be fixed properly by a skilled welder and the correct material. Again, it's done all the time, but first things first.
    Denso radiator ~ $150 + other components needed.
    My unsolicited advice is if you plan on keeping it don't drive it this coming winter if the frame and rockers aren't fixed by then. There is hope in that old truck; all it takes is a lil $$$ and some patience.
  26. Aug 24, 2021 at 8:23 AM
    #56
    empty_lord
    05 rollover special
    Shoot me the vin. I’ll tell you if it’s open or not for replacement
  27. Aug 24, 2021 at 8:23 AM
    #57
    Needs a little work. Strangely, I like the rims.
    How's your skillz at fixing the rot under the door?
  28. Aug 24, 2021 at 10:25 AM
    #58
    How is the rot that bad in KY? I didn't think yall had rust issues?
  29. Aug 24, 2021 at 10:50 AM
    #59
    I had the same question last year for Noah. It has to be from dirt that was left on there for years and never washed off. It shows you how shitty these frames were though. Didn't take much for rot to start.
    Tundra2[OP] and Jack McCarthy like this.
  30. Aug 24, 2021 at 11:54 AM
    #60
    Neighbor has this in his Xterra. Hates it.
    Sounds very Ride The Lightning to me.
    Meanwhile, you still got a good deal. The rust on that crossmember isn't too bad. IMHO it's the main framerails you should worry about. If those are compromised, you're pretty much screwed.
    Tundra2[QUOTED][OP] and daveeasa like this.
