  1. Jul 27, 2021 at 6:10 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Odor neutralizer with a very strong citrusy scent.
    TRDGen and Jack McCarthy like this.
  2. Jul 27, 2021 at 6:24 PM
    daveeasa
    Thanks!
    I plan on 17’s and wanted to do disc conversion. Way behind on planning for that. Good to know it’s possible. Sounds like I’m going with 14WA up front.
    best part of an old truck is zero guilt replacing anything.
    des2mtn[QUOTED] and Sirfive like this.
  3. Jul 27, 2021 at 6:25 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The 13s are the factory TSB upgrade for your truck. The 14s are off a new 4runner and a bit bigger
  4. Jul 27, 2021 at 6:26 PM
    empty_lord
    05 rollover special
    If you go WA don’t forget the caliper needs to have it’s ears machined.
    daveeasa[QUOTED] likes this.
  5. Jul 27, 2021 at 6:35 PM
    des2mtn
    SW
    Tonto cover
    I hear you on that! :)
    I did the rear disc conversion myself and there was some trial-and-error but it's definitely doable. I documented some of it way back in this thread. The guy at SOSperformance might be the one to talk to for master cylinder recommendations if you want discs AND 14WA fronts.
    Rear disc conversion is an excellent time to do your wheel bearings and axle seals if they're original, but not necessary. To do a rear disc conversion you either have to cut the drum brake backing plate in pieces or have it removed via press.
    daveeasa[QUOTED] and Sirfive like this.
  6. Jul 27, 2021 at 7:13 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    With a 2004 dc did you already have the 4 way abs? or just running one sensor?
  7. Jul 27, 2021 at 7:17 PM
    des2mtn
    SW
    Tonto cover
    4-way ABS from the factory
  8. Jul 27, 2021 at 7:22 PM
    empty_lord
    05 rollover special
    I would be replacing the 2 year old wheel bearing just because I don’t want to cut up the backing plate I paid a lot of money for 2 years ago.
  9. Jul 27, 2021 at 7:25 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    can you use sequoia axles by just changing bearings? Im pretty sure im gonna have to build backing plates unless i figure out how to steal the linkage.
  10. Jul 27, 2021 at 7:26 PM
    empty_lord
    05 rollover special
    To use stock sequoia stuff you need the whole axle housing. The sequoia bearing mount has a different bolt pattern
  11. Jul 27, 2021 at 7:29 PM
    des2mtn
    SW
    Tonto cover
    Take a whole Sequoia axle assembly, grind off the suspension mounts and weld in new ones to work on the Tundra.
  12. Jul 27, 2021 at 7:29 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea…my bad. I still wanna steal the linkage. Coil rears would be a treat.
  13. Jul 27, 2021 at 8:46 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    i know mine doesnt count cause its not a tundra, but a 4 day weekend with my brother and dog in a 2 dr s10 blazer. Packed so tight, i lifted the dog in and out the drivers door. And we put the kitchen in the ‘churchcamp trailer’. But ive always been proud in my ability to fill a good hole.
    TRDGen, 1genjunky, Darkness and 4 others like this.
  14. Jul 28, 2021 at 2:48 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  15. Jul 28, 2021 at 7:13 AM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    Finished my backing plate, rear brakes, rear bearings and seals job. Now for the front end.PXL_20210727_163134194.jpg PXL_20210727_163112471.jpg PXL_20210727_163055198.jpg
    Hi06silver, bmf4069, NUDRAT and 5 others like this.
  16. Jul 28, 2021 at 7:21 AM
    This will never pass PHM muster. Whatever this schmutz is on top of the wheel cylinder. Disassemble and start over! Otherwise, great job sir.
    Hi06silver, bmf4069, NUDRAT and 4 others like this.
  17. Jul 28, 2021 at 7:41 AM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Damn you guys can pick up the smallest details....
    That's just brake assembly grease I put around the back of the brake cylinder before putting it in the backing plate.
  18. Jul 28, 2021 at 7:52 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I use that stuff about once a year. Run the ac full blast on recirc, a quick couple of psh-psh into the passenger footwear and watch the vapor get sucked up. Leave windows up and system running for a few minutes with yourself not in the truck. Then I switch to full blast ac and fresh air mode, a quick psh-psh into the cowl above the passenger side and I roll windows down to let that run. Again I stay outside. Then turn off the truck and let it air out with windows down for a while.
    The smell doesn't stick around long but it kills any funk.
    des2mtn and CodyP like this.
  19. Jul 28, 2021 at 7:54 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Also missed the paper gasket.
    NUDRAT likes this.
  20. Jul 28, 2021 at 7:55 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you remember binaca fresh breath spray, it's kind of like that but for your car. A little aerosol can that you shake and give a light spray into your cars hvac intake to kill any misty smells.
    06yotamike, Lil Steve and bmf4069 like this.
  21. Jul 28, 2021 at 7:58 AM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Gaskets are for sailors!
    CodyP and Darkness[QUOTED] like this.
  22. Jul 28, 2021 at 8:07 AM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    OCD activated. Fine!
    bmf4069, NUDRAT, des2mtn and 2 others like this.
  23. Jul 28, 2021 at 8:51 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm not sure where to post this... I know it fits here, but not sure if it should go here, or in @jpink's build thread, or what...
    https://youtu.be/moD8o7Wf3lk
    This is a 60X video. Every second you see, I saw a full minute. Every minute you see, I saw a full hour.
    bmf4069, FirstGenVol and Darkness like this.
  24. Jul 28, 2021 at 9:29 AM
    Damn you drive fast
    bmf4069, NUDRAT and Tundra2 like this.
  25. Jul 28, 2021 at 10:00 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I think the “or what…” would be appropriate
    Tundra2 likes this.
  26. Jul 28, 2021 at 10:14 AM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    On to the front. Just got back from the Zone with some new calipers. One piston was seized on the right side. I could barely spin my wheel when I got it off the ground. I'm surprised it wasn't more noticeable. You can see the hot spots in the old rotor too.
    bmf4069, NUDRAT and tacoguybill like this.
  27. Jul 28, 2021 at 10:19 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    His truck thought it was black
  28. Jul 28, 2021 at 11:51 AM
    Replaced the 15 year old Pioneer cheapy's with some slightly less cheap Fosgate separates. Replaced the factory door speaker and Tweeter. Decided to remove the factory grill and use the tweeter mount so that I could angle the tweeter to help improve soundstage, something that is seriously lacking in these trucks. Results, not bad. Powered by the head unit, so not gonna be cranking it up to 30 and expecting crystal clear sound, but a big improvement over the previous setup. Also cleaned and lubed the window regulators while I was in there to improve performance and prevent failure of the regulators.
    TRDGen, bmf4069, Filthyphil and 4 others like this.
  29. Jul 28, 2021 at 11:54 AM
    And I had to do it all by myself with no help from my brotards :(
    bmf4069, Darkness and FrenchToasty like this.
  30. Jul 28, 2021 at 11:54 AM
    Do you have any brotards?
    Darkness likes this.
