Where to get the rubber inner fender well liners?
Discussion in '2nd Gen Tundras (2007-2013)' started by kenomouth64, Apr 26, 2017.
  1. Apr 26, 2017 at 9:34 AM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Does anyone know where I can get the Rubber Inner fender well Liners for this truck.
    I am looking for the rubber front fender well liners. The little rubber mats that are pinned to the frame.
    I am not sure exactly what these are called, I ahve been looking for them online, but have yet to find them.
    I will also need the 'clips'.
    ***Note***
    I am not looking for the plastic liner, but just the 2 small rubber mats that cover the side of the engines components.
    Rica25 likes this.
  2. Apr 26, 2017 at 9:35 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  3. Apr 26, 2017 at 10:27 AM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    2016 CrewMax TRD PRO
    NewImprovedRon likes this.
  4. Apr 26, 2017 at 10:42 AM
    kenomouth64
    Tetrus
    That is definitely an interesting name for them.
  5. Apr 26, 2017 at 11:07 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I did the rubber mat thing on my older 4Runner. Only cost a few bucks. The factory ones were ridiculous.
    Rica25 likes this.
  6. Apr 26, 2017 at 11:35 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    Just buy some good rubber sheets from McMaster that are better than the stock material, trace the OEM mats over them, cut, drill holes, and mount.
    AnonVet likes this.
  7. Apr 26, 2017 at 12:12 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    There are two per side. The front most seals are different on each side, and the rear seals are the same on both sides. There are 22 clips in total for them as well. They can be found here in the store:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-front-seal-537360c030/?c=aT04MTkzMTU1NSZyPTY=
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-front-seal-537370c030/?c=aT04MTkzMTU1NSZyPTY=
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-rear-seal-537390c020/?c=aT04MTkzMTU1NSZyPTY= x2
    And the clips:
    https://parts.toyotaofcoolsprings.c...hield-clip-9008046327/?c=aT04MTkzMDI1NSZyPTE2
    I would definitely consider making your own.
  8. Dec 1, 2018 at 4:38 PM
    TSAV14
    TSAV14 New Member
    2018 Toyota Tundra Crewmax 4x4
    I just finished making my own fender apron seals. Pretty easy project. Went to Toyota and got $30 worth of clips and went to Home Depot and got 4ft. of 2mm rubber "runner" for about $10. Was only able to finish the drivers side before it got dark, but it only took about 40 minutes. Here are some before and after pictures. Enjoy! gVgmMVQfQJmiJLDg04zLmA.jpgLx5imPSQSYGy7I897QJClg.jpg8rwU8SgrRvC4KKURq%Ri9w.jpg4Z5OLaiAQrK7%bxKjAlCcw.jpguCF4XSuLQK2+X46A7OnzuQ.jpgt+6ceqLtShOZcKhovRQFGg.jpg
    Bob_Wiley, Ketchumj, Rica25 and 9 others like this.
  9. Dec 8, 2018 at 5:25 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    I did the same using some shelving material from lowes. Still looks good 4 years later!
    Rica25 likes this.
  10. Dec 8, 2018 at 7:40 PM
    throttlejock
    throttlejock New Member
    Seth
    Theres a guy on Ebay who sells a kit, $100 or thereabouts. They're thicker than oem and come with nice expansion clip things
    Rica25 likes this.
  11. Dec 8, 2018 at 7:55 PM
    throttlejock
    Seth
    Rica25, Major and Jcantin1 like this.
  12. Mar 5, 2019 at 12:29 PM
    NickOfTiming
    NickOfTiming New Member
    Arizona
    2010 BLACK DC 5.7 4X4
    I just found mine should be replaced. Can anyone elaborate on the need for these/ purpose?
    Mountun Goat likes this.
  13. Mar 5, 2019 at 12:33 PM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    Keeps water out of the engine bay
    Black Wolf and NickOfTiming like this.
  14. Mar 7, 2019 at 6:20 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Runnhunt likes this.
  15. Mar 9, 2019 at 4:27 PM
    NickOfTiming
    Arizona
    Can I get the template for these? Missing factory on one side. I found some material that I like.
  16. Mar 9, 2019 at 4:29 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    I can trace them for you when I get back home in a bit
  17. Mar 9, 2019 at 4:33 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Also, keeps the fender well from looking like ass:hattip:
    GODZILLA, Major, ecm209 and 2 others like this.
  18. Mar 9, 2019 at 4:34 PM
    15whtrd
    15whtrd Mr. Blonde
    Mountun Goat[QUOTED] likes this.
  19. Mar 9, 2019 at 4:34 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    hairy man ass I should add. Not the good ones.
    GODZILLA, TheBeast and CaptSpaulding like this.
  20. Mar 9, 2019 at 4:48 PM
    NickOfTiming
    Arizona
    The other side is smooth, not sure which I'll have facing out.IMG_20190309_170236.jpg
  21. Mar 9, 2019 at 4:50 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Smooth out. Ribbed will hold mud and debris I bet. Harder to armour all too
  22. Mar 9, 2019 at 5:19 PM
    NickOfTiming
    Arizona
    Thanks Cap!
    rodneysworld and Mountun Goat like this.
  23. Mar 10, 2019 at 9:30 PM
    NickOfTiming
    Arizona
    Started thinking about it, the ribbed side would probably take more abrasions. I always spray out debris anyway.
    TheBeast and Mountun Goat like this.
  24. Mar 20, 2019 at 3:04 PM
    NickOfTiming
    Arizona
    Did you get a tracing?
  25. Mar 20, 2019 at 3:07 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Shoot man, I forgot about that. I'll go trace them right now. I'll take a picture of the outlines of each, and provide some measurements for reference
    GODZILLA and Rica25 like this.
  26. Mar 20, 2019 at 3:40 PM
    Aurora CO
    Damn I'm glad I came across this thread again. I had to partially remove my front passenger side felt apron when I replaced my defective power steering pressure sensor. The apron is 12 years old and tears easily. Ding....ding....ding......all of our lab benches have rubber anti static mats. About an 1/8" thick. Topside is blue grip surface. Bottom side is smooth and black. OK...dirty minds kick in now.....................ding......ding......ding.....now that that's out of the way......ding.....ding.....ding>>>>I have a roll of it left . 36 inches wide by 15 ft........ding......ding.....ding......guess what I'm doing tomorrow?????
    NickOfTiming and CaptSpaulding like this.
  27. Mar 20, 2019 at 5:28 PM
    FXFormat
    FXFormat New Member
    What's the purpose of these liners? Do they do anything? My fell off awhile ago and i never thought to replace them.
    Rica25 likes this.
  28. Mar 20, 2019 at 5:45 PM
    NickOfTiming
    Arizona
    They keep debris from getting kicked into the engine bay.
    Rica25 and Black Wolf like this.
  29. Mar 20, 2019 at 6:41 PM
    Aurora CO
    Yep...will make it easier when my starter ever fails. Clean of mud,dirt, debris is always good.
  30. Mar 27, 2019 at 3:52 PM
    NickOfTiming
    Arizona
    Ok, so I made templates that could cover as much space as possible - not factory traced, and I'm happy with how they turned out. I cut and scanned them, so if you can print on A4 paper, you can use them. Should fit 2007-2018 I believe. Just print, tape up, and cut on the material you want. I want to design them in Fusion360 and make a DXF file if you have a machine capable of cutting other materials (aluminum etc.) Not sure when illI get around to that....when I get some free time.
    If you like what you see, here is the link...
    https://drive.google.com/file/d/169FT8DxwTlJQSDYsTQNh2v6sDR6eSoQ0/view?usp=sharing
