Budget fender well splash guard
Discussion in 'General Tundra Discussion' started by CaptSpaulding, Jan 31, 2019.
  1. Jan 31, 2019 at 10:35 PM
    CaptSpaulding
    CaptSpaulding [OP] ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    I recently replaced the fabric splash guards in each fender well. OEM was too expensive (currently on disability and 1 armed... shoulder reconstruction).
    In total, it took about an hour, using 1 arm and a few clamps. With 2 working arms, 30 minutes. I suggest aligning the 'ribs' a little better than I did for aesthetics
    Lowe's had idoor/outdoor runner material called 'Nance' by Blue Hawk for $3.95/foot. Purchased 4' total, although about 2' would have been enough.
    For the clips that hold the pieces in place, I was able to salvage most of the stock clips, and had an assortment of extras laying around for the rest. For reference, they're part number 90080-46327. I used a dedicated tool to remove the clips, a screwdriver or two would probably work as well.
    Remove the clips, trace the peice onto the rubber side of the new material, mark the holes as well. Cut out your pattern, I used a 5/16 drill bit with a peice of wood beneath for the holes. Pop your new pieces in with the clips and you're done.
    It's been about 2 weeks of driving in rain, mud and freeway, all is holding up great.20190125_202933.jpg 20190126_102614.jpg 20190126_095130.jpg Screenshot_20190131-223055_Gallery.jpg
  2. Feb 1, 2019 at 2:44 AM
    Beardedbeast
    Beardedbeast New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
    Good job,most couldn’t do that with two good arms
    CaptSpaulding[OP] likes this.
  3. Feb 1, 2019 at 5:47 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Looks really good. I used the same material to make a doggy door on my garage and one on my shed. Stores get between $50-$100 for a doggy door now.
    I cut my holes, trimmed it with KDAT 1x4 and used the outdoor carpet for the flap. Have under $30 total into 2 doggy doors.
    The stuff seems to hold up well to UV and heavy use, although a wheel well application will be extreme duty use compared to my 2 mutts.
  4. Feb 1, 2019 at 6:07 AM
    Rubberdown
    That’s rather ingenious! I just had to rig mine yesterday as one of the holes rips through and it was falling down on top of the reservoir for my shock.
  5. Feb 1, 2019 at 6:23 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Great idea!
  6. Feb 1, 2019 at 9:13 AM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Mine too, the stock guards don't last long if you're in the dirt much. Ideally, I would go with Mammoth Guards
  7. Feb 1, 2019 at 10:51 AM
    G10dra
    G10dra Not a New Member
    it look like this could help with a little bit of sound deading.
  8. Feb 1, 2019 at 10:52 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Nice I like it
  9. Feb 3, 2019 at 10:54 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thank you for the inexpensive idea! Great job! I guess I’m going to Lowes in the morning.
  10. Feb 3, 2019 at 11:00 AM
    buffaluphagus
    buffaluphagus —————————————
    Looks good may have to give it a shot
  11. Apr 13, 2019 at 5:12 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Subbed.
  12. Jun 26, 2019 at 1:25 PM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    wow! I am going to need to do that for the front splash guard pieces on mine.
