Potentially snapped Timing Belt
Discussion in '1st Gen Tundras (2000-2006)' started by thefish712, Jun 21, 2021.
  1. Jun 29, 2021 at 5:06 PM
    #271
    ToyotaJim
    ToyotaJim New Member
    I'm just repeating advice given to me when I thought I had a starter problem and was debating what to do.
    https://www.tundras.com/threads/rep...-what-else-while-in-there.79543/#post-2013432
  2. Jun 29, 2021 at 5:06 PM
    #272
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Good question….for me it’s because I want one(tips hat to PHM for talking it up)….just like factory HU had to go to make way for car play and BU camera and new HALO head lights courtesy of @SouthPaw and shorties will be installed one day and…..because we can ?
    SouthPaw and N84434 like this.
  3. Jun 29, 2021 at 8:54 PM
    #273
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Good choice. These trucks are million mile machines. In one year, you have already paid for it. Keep us posted on the results once it’s all said and done.
  4. Jun 30, 2021 at 4:54 AM
    #274
    Just didn't know if anyone had a true failure of the starter beyond the contacts (technically a wear item). Does the new HD starter fix or add something to the truck? I have also done the HU swap with backup camera to add a new function to the truck and would love some of those projectors from @SouthPaw.
    SouthPaw and BubbaW[QUOTED] like this.
  5. Jun 30, 2021 at 4:59 AM
    #275
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    It's a cold weather starter, which basically means it's built for heavy duty use. Not sure physically how it's different, but I would assume heavier windings to allow for more torque to turn a cold engine.
    BubbaW and des2mtn like this.
  6. Jun 30, 2021 at 5:00 AM
    #276
    Looks like I'm chiming in too late, but this was gonna be my suggestion. Buy a motor, then ask if anyone on the forum could help. I would even loan you my FSM if you needed it.
    I'm glad you're getting it fixed though. Always better to keep a 1st gen on the road than letting it die and buying a newer gen.
  7. Jun 30, 2021 at 5:01 AM
    #277
    Gotcha, so our northern brethren may benefit during ice-pocalypses and thundersnows.
    des2mtn, N84434[QUOTED] and bmf4069 like this.
  8. Jun 30, 2021 at 7:23 AM
    #278
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    This page (along with a few others on the internets) suggests that the CK All Weather Guard package included the larger battery and HD starter, i.e. Tundras with the All Weather pkg already have the HD starter.
    https://www.msn.com/en-us/autos/toyota/tundra/2003/options/sr5-4x4-access-cab/sd-AAbLRfU
    Tundra2 likes this.
  9. Jun 30, 2021 at 12:47 PM
    #279
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    My starter sounds like it struggles a little more on the really cold mornings. I worries me a little bit, so if I goes out or I was in the manifold for any reason I'd replace it for peace of mind, but I'm OCD like that.
    N84434[QUOTED] and ToyotaJim like this.
  10. Jul 1, 2021 at 5:27 AM
    #280
    N84434
    Milwaukee WI.
    2001 Limited TRD
    It could be a battery issue, or yeah, it could be the starter letting you know it wants to retire soon.
    Doing a starter on the 2UZ, especially on the non-VVTi engines isn't horrible. It's still a big job, but it's better than installing headers... The VVTi engine has the secondary Air Pump that you have to work around, and a few more connectors on the manifold.
    I did one on a 1UZ in a 1998 LS400 and that was BY FAR the worst starter I've ever changed. It makes my stomach hurt just thinking about that day...
    ToyotaJim likes this.
  11. Jul 1, 2021 at 5:28 AM
    #281
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Engineers will climb over a mountain of virgins to ‘F’ a mechanic.
    ToyotaJim, bmf4069 and BubbaW like this.
  12. Jul 1, 2021 at 5:54 AM
    #282
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Hot damn, I got a pretty good deal then according to the actual window sticker:yes:
    tounge in cheek
  13. Jul 1, 2021 at 6:05 AM
    #283
    Richid
    Richid New Member
    And 4.10s for $275...
  14. Jul 1, 2021 at 6:27 AM
    #284
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Don't forget that Valor Exhaust Tip....:cool:
    BubbaW likes this.
  15. Jul 1, 2021 at 8:00 AM
    #285
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd tow package
    $7k is a fair chunk of change but if ya like the truck and want to keep it... thumbs up!
    For my 2000 A/C 4w/d SR5 recently paid for new serpentine and timing belt, water pump, radiator, valve cover gaskets, plugs, replaced fluids in transmission, transfer case and f/r differentials, and a handful a minor stuff. $2,600... and I only plan to keep the truck another year or two. So... dropping $7k on a Tundra that ya want to keep for maybe another 5-10 years ain't so much.
    In your situation if I was in cheap-mode I'd consider pulling the heads first to inspect. If no piston damage was present I'd toss on a set of reconditioned heads and call it done.
    Good luck sir.
    ToyotaJim and thefish712[OP] like this.
  16. Jul 1, 2021 at 8:17 AM
    #286
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    He is not doing the work, pulling head is another 8hrs he have to pay.
  17. Jul 1, 2021 at 8:36 AM
    #287
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    All the talk about LS swaps, again he is in California. Not practical here unless you know a smog guy who plays dirty or you are registered in a city where smog isn't required.
  18. Jul 1, 2021 at 10:04 AM
    #288
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Is there anyway at 280k I’d still be on the original belt. I have all types of service records on the carfax, but not a single one on the timing belt. Belt is original Toyota printed on it, not mitsuboshi, and it is in really bad condition. Major deep cracks, and it kinda stretches.
  19. Jul 1, 2021 at 10:07 AM
    #289
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Have you checked the owners section on Toyota's website? If it was changed at a dealership, it might show-up there.
    Diablo169[QUOTED] likes this.
  20. Jul 1, 2021 at 10:11 AM
    #290
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I wouldn’t drive it till it’s changed
    Filthyphil, bmf4069 and Badknees like this.
  21. Jul 1, 2021 at 10:37 AM
    #291
    I think it could definitely be possible. I wish I could find the old post but we had one member claim his Sequoia (same engine) had a ridiculous amount of miles on the original belt. It was over 300K.
  22. Jul 1, 2021 at 10:40 AM
    #292
    @Diablo169 not the same post but check this one out.
    https://www.tundras.com/threads/highest-mileage-1st-gen-thread.11039/page-7
    Diablo169 likes this.
  23. Jul 1, 2021 at 10:42 AM
    #293
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Yeah it’s all torn apart right now. I need to replace the front main seal and the little water hoses.
  24. Jul 1, 2021 at 6:33 PM
    #294
    N84434
    Milwaukee WI.
    2001 Limited TRD
    @Diablo169 There will be a date stamp on the water pump if its the original Toyota pump. Mine was the original. It had a November 2000 date on it.
  25. Jul 2, 2021 at 9:51 PM
    #295
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I suggest not being blacked out when you decide to tear your engine apart. Luckily I had my girlfriend with me to label bags.
    Still can’t find the upper left long water pump bolt Cool thing about Toyota’s is you only need 90% of the hardware to make it functional.
  26. Aug 4, 2021 at 7:28 PM
    #296
    thefish712
    thefish712 [OP] New Member
    Fish
    2005 Toyota Tundra 4.7L V8 4WD Double Cab
    The big update - FINALLY got the truck back today. Let me know what you think,,, bc there’s a story behind it.
    Around early to mid July I called for an update. They said they weren’t huge fans of the engine and had a new one on the way. Not much more info other than it had less miles.
    Fast forward to last week - I call and ask what the deal is and they said it’ll be ready in the next few days. I ask if I can pay over the phone since I’m not in the area and may have a friend pick it up for me instead. They said no because,,,, the shop changed ownership and the new owner does not accept payment over the phone. So that wasn’t great.
    But not much of a choice on my part and I go to pick up the engine today. Same price and they said the engine looks and runs great. I ask for info or some sort of paperwork documenting/certifying/etc the engine I have in my truck now. He said he’s got nothing and that the old owner would be the one with that info. So now I’ve got no idea what’s in my truck and I tell him that’s pretty sketchy. He agrees. So we ended with him saying that the old owner will be in the shop tomorrow and will have him reach out to me with all that info.
    The truck truly sounds and runs great so far, but I’m a bit sketched out. The old owner seemed like a good guy and came highly recommended, but I can’t help but wonder if he found a cheaper older engine, used that instead, and charged me the same.
    Thoughts?
  27. Aug 4, 2021 at 7:37 PM
    #297
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Check for the vin plate on the motor (I think they had them?) I can run the vin to get an idea at least
  28. Aug 4, 2021 at 7:37 PM
    #298
    ToyotaJim
    Welp, the good news is good. As for engine matching, isn't this something that should have been confirmed before thousands of dollars of parts and labor? Some in-person VIN matching, confirmation, etc.? I don't know what recourse there is if it's not what you expected. It's now a running truck. And suppose it's a different engine. There could be many reasons, but in the end, the answer will be that if you wanted to be this hands-on and detailed, the time was before or upon engine delivery, not after weeks of installation work. This is a headscrather. I think you're kinda stuck with what you've got. It would, I agree, be good to confirm what is in there. A VIN check on the engine, to see what history the engine had, perhaps a car-fax on the engine?
  29. Aug 4, 2021 at 7:37 PM
    #299
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    From my experience, they don't get any info with motors other than a tag that is zip tied to it saying what it came out of and what the mileage was. Don't expect much if anything.
    Do your oil change early, like 500 miles. Do another around 1000-1500 miles. It will come out nasty but after that should be okay.
  30. Aug 4, 2021 at 7:41 PM
    #300
    ToyotaJim
    Agree with the two above posters. Run the VIN to get as much info on the prior truck as possible. And I would carefully "break in" this used engine, run 1 or 2 short oil change intervals with premium oils. Run premium oils and a new filter a short period, and change it, and repeat. Maybe send the oil in for an oil analysis for 50 bucks if you care to know the condition of the internals of the engine.
    I'm also ASSUMING that when the engine was out, it was thoroughly updated with all new seals, gaskets, belts, tensioner, etc. since that would have been the smart/correct time to do it. So you should be set for another 7 years or 90k miles or thereabouts.
    thefish712[OP] and Darkness like this.
