Highest mileage 1st Gen. Thread?
Discussion in '1st Gen Tundras (2000-2006)' started by donaldp83, Feb 28, 2017.
How many miles are on your 1st gen?
  1. 0-99k
    51 vote(s)
    9.0%
  2. 100k-199k
    211 vote(s)
    37.3%
  3. 200k-299k
    199 vote(s)
    35.2%
  4. 300k +
    105 vote(s)
    18.6%
  1. Jul 14, 2019 at 11:44 AM
    #181
    Trdookie
    Trdookie New Member
    Chum
    02 2wd limited/TRD 4.7 tundra
    2in leveling kit, 33s falkens
    256k miles, 4.7, timing belt changed at 223, replaced ball joints and power steering rack same time. Leaks out of rear main pretty bad but runs perfect and is quite fast for her age!
  2. Jul 14, 2019 at 12:08 PM
    #182
    Professional Hand Model
    Hand Protectors
    Welcome. Glad she is still fast!
    You mind posting up a pic over in the ‘What have You Done’ 1st gen section of your rear main leak?
  3. Jul 15, 2019 at 6:12 PM
    #183
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Just bought my 2006 DC @ 176k. Hope to get many more out of it! I drive my ~6k/yr, hoping to have it for at least 4 yrs, while I save for a newer 3rd gen. Good things about these trucks at least where I'm at is that there really isn't much more depreciation that is going to happen on them. What I can sell it for at 200k in a couple years should be pretty close to what I bought it for save some of the work I had to do on it below.
    I did have to do a couple things to do, some maintenance/pm work, and some for enjoyment.
    Maintenance:
    • Oil change.
    • Rear diff service.
    • Transmission fluid.
    • Replace windshield.
    • Replace clutch fan.
    Enjoyment:
    • Diode dynamics flasher relay and full LEDs all around interior/exterior.
    • CarPlay stereo upgrade (Kenwood) + USB input on center console.
    • Scangauge II.
    On the fence:
    • Replace drop in Bedliner with a spray-in one.
    • Darker tint all around to reduce heat in cab.
    • Replace driver side mirror with one that doesn't vibrate as much.
    The tint and bedliner are a fair investment, but also do provide enjoyment. I'm in an area where rust isn't an issue, and this truck is local, no rust on bed or frame. I just like the utility and the look of the spray-in bedliner. I also need a solution to haul bikes. I don't want to drop 1k on a rack system. Might just go with a tailgate pad and be done with it.
    Things that the previous owner did that I don't have to:
    • New-ish tires.
    • Timing belt and WP at 165k.
    • Weathertech mats all around.
    • HID headlights and fogs.
    • LED 3rd brake light.
  4. Aug 2, 2019 at 12:21 AM
    #184
    akhero
    akhero New Member
    2005 Toyota Tundra
  5. Aug 2, 2019 at 5:32 AM
    #185
    Hand Protectors
  6. Aug 2, 2019 at 7:00 AM
    #186
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
  7. Aug 2, 2019 at 7:10 AM
    #187
    Hand Protectors
    Not sure if you’ve watched that Nathan garage guy on youtubes, but he has a 1st Gen 4.7 Sequoia with IIRC over 400k on the OD.
    He says he mostly uses it for tow/haul and it has the original transmission.
    With history behind us, I think the A340F planet gears either failed quickly early on (rare) or they’ve gone on forever.
    speedtre and Filthyphil[QUOTED] like this.
  8. Aug 2, 2019 at 7:27 AM
    #188
    Filthyphil
    Phil
    Hopefully lol but man I see a lot of high mileage early 1st gens with original equipment.
  9. Aug 2, 2019 at 10:19 PM
    #189
    Jake92
    Jake92 New Member
    2000 Toyota Tundra SR5 4x4 TRD
    I have a 2000 Tundra SR5 4x4 with 346,923 miles. I’m slowly fixing her up from her previous neglectful owner
  10. Aug 3, 2019 at 8:23 AM
    #190
    Knightsalum
    Knightsalum New Member
    2000 Tundra....500k odom
    My uncle gave my son a 2000 Tundra for his 16th b-day that has just under 500k miles. Just replaced the tires and it looks and runs great.
    speedtre, Sangre Kid, bmf4069 and 5 others like this.
  11. Aug 3, 2019 at 2:16 PM
    #191
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    Welcome!!
  12. Aug 3, 2019 at 8:38 PM
    #192
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Congrats on the truck. Don’t leave us hanging @Knightsalum post some photos of the odometer and the truck.
    Filthyphil likes this.
  13. Aug 4, 2019 at 10:03 AM
    #193
    Knightsalum
    Here’s you go. And I guess I kinda rounded up a little higher then I thought.
  14. Aug 4, 2019 at 10:06 AM
    #194
    Filthyphil
    Phil
    Damn that’s cool seeing the odometer with so many clicks, truck looks to be in great shape.
    ThundaTundra likes this.
  15. Aug 4, 2019 at 10:16 AM
    #195
    Knightsalum
    There's a few small things cosmetically wrong with it, but overall in good shape. Had my mechanic do a full check on it and couldn't find anything wrong with it at all. Put new tires on it (for a slightly more aggressive look), new stereo with hands free kit. The dent in the left bedside is from a wild hog that ran through the woods and jumped into it. That's kinda unique and not sure I'll pay to fix it with the amount of miles and a newly licensed driver.
    And, I couldn't find the post on the keys for some Tundras sticking when trying to start the truck...but, we got a VIN coded key cut and the keys work amazing in the doors and ignition.
    Filthyphil[QUOTED] likes this.
  16. Aug 4, 2019 at 10:39 AM
    #196
    Ricardiac
    Ricardiac New Member
    17' 4x2 5.7L SR5, 04' 4x2 3.6L Stick SR5
    17' color keyed TRD Pro Grill, color keyed handles, chrome mirror backs, TRD Pro Wheels, front and rear swaybar, shifter, tailgate insert (black), 2018 LED headlights and DRLs. 04' Original Owner all stock
    Just saw this thread...
    I have the runt of the litter.. I am the original owner of a 2004 4x2 V6 Stick and about to cross 200K (199800) all stock stuff...
    I rhino lined the bed when I bought it and "betsy" has mostly highway driving miles... and maintenance above from regular fluid changes, filters, tires & bulbs include:
    Timing chain @112K
    Sticking ignition @140K - new key fixed it
    New front windshield @160K - also replaced any nearby rusty screws and aged plastic while it was apart
    AC leaks/broke down @196K- Replaced whole system myself as an educational exercise (been working flawlessly for 2 yrs now) (this also justified some tool purchases (grins))
    Only thing thats nonop is CD part of original radio.. still works but flakes out after a bit.
    ORIGINAL CLUTCH (which surprises me)...
    Probably could use timing chain soon, steering pump pulses when starting transitioning from reverse to first gear, some steering noises
    - if I decide to put her back into full time service will address those issues...
    Still have it and bought a 2017 (about the time the 04' a/c broke down)
    When i had a dealer look at it circa 2017 they told me it was the cleanest engine they had seen with those miles on it (probably the highway miles).
    She is up for sale but not going to give her away so she may stick around for a while :)
    georgiey22 and bmf4069 like this.
  17. Aug 13, 2019 at 10:30 PM
    #197
    Cajunman007
    Cajunman007 New Member
    Shane
    Lafayette, LA
    02 Tundra Access Cab 4x4 4.7
    I just bought an 02 access cab with 310 and some change. Just had timing and water pump changed. Paid $3k. Only problem was the 4WD ECU was out. Picked it up at a junkyard and it works great. Just needs a paint job
    Sangre Kid and Filthyphil like this.
  18. Aug 20, 2019 at 7:48 PM
    #198
    2000Strong
    2000Strong Just a dude and his truck
    Benjamin
    Washington
    2000 Maroon Tundra, AC, Premium Audio, SR5 4.7
    All LED Interior lights, New Headlights, Break Controler, LineX Bedliner.
    My 2000 tundra is about to tick over to 180k miles and it been in my family since 02. its been mine since 17. Dad bought it with 18k miles on it. That's me in the pictures in like like 03 or 04.IMG_2550.jpg IMG_2554.jpg
  19. Aug 20, 2019 at 8:35 PM
    #199
    Filthyphil
    Phil
    That’s pretty cool right there.
    2000Strong[QUOTED] likes this.
  20. Aug 20, 2019 at 8:37 PM
    #200
    2000Strong
    Benjamin
    Washington
    Thanks!
  21. Aug 21, 2019 at 6:27 AM
    #201
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Do you still have that Jeep? ;)
  22. Aug 21, 2019 at 6:36 AM
    #202
    Casper421
    In the woods
    06 DC
    Don’t be silly, a Jeep can’t survive that long. It’s not a tundra.
  23. Aug 21, 2019 at 6:39 AM
    #203
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    I have 14k, runs like a champ
  24. Aug 21, 2019 at 8:15 AM
    #204
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think you are lost. We're asking about highest mileage 1st gens
    bmf4069 likes this.
  25. Aug 21, 2019 at 11:52 AM
    #205
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
  26. Aug 23, 2019 at 10:00 PM
    #206
    2000Strong
    Benjamin
    Washington
    No, but we have a 1955 Wilis with 50k on the clock and god knows what on the engine lol
  27. Sep 12, 2019 at 10:10 PM
    #207
    Mushhuskies
    Mushhuskies New Member
    Pete
    Hawaii
    2005 Toyota Tundra Reg. Cab 4x4
    Ride rite air bags Soon to be new USB power outlet and stereo replacement
    05 regular cab/WT model with 96k. 4.7L 4x4
  28. Sep 13, 2019 at 6:31 AM
    #208
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    04 DC with 257K
  29. Sep 14, 2019 at 2:18 PM
    #209
    Asap
    Asap New Member
    2001 tundra. 2005 tundra
    2001 access cab. 2wd. Purchase with 26k, changed the spark plugs at 300k ( hey. I really had to. I ought to post a picture of the old ones)
    Speedo went out at 378k, changed the timing belt for the first time at around 500k. Based on typical usage and by now I know what that is....close to 600k.
    TX-TRD1stGEN and bmf4069 like this.
  30. Sep 14, 2019 at 2:30 PM
    #210
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Damn bro, what did she do to piss you off? :rofl:
    That's what I call serious neglect! Impressive though. :cheers:
