2018 Tundra TRD Sport Suggestions
Discussion in 'General Tundra Discussion' started by Cem77, Jun 18, 2021.
  1. Jun 18, 2021 at 12:36 PM
    Cem77
    Cem77 [OP] New Member
    2018 Blazing Blue Tundra TRD Sport
    I have had my 2018 Tundra TRD Sport for a week now, have ordered some stuff for it, but looking for suggestions on lift size. Don’t want it too tall so I was thinking 3 to 4 inches. First 4wd to own.8B04D25B-D599-47A8-92C9-22DFB5C2D0AF.jpg90EDCF9E-B58F-47A8-89C7-B32415778501.jpg
  2. Jun 18, 2021 at 12:41 PM
    18" TRD Off Road Wheels
    Welcome to the Forum.
    There's lots of discussion on lifts, and some vendors on here that can provide guidance as well. You should know that lifting 3" or more you will likely have to get aftermarket UCAs to get alignments back in spec, and might need a diff drop as well. If you are going to go with new wheels and tires you'll want to figure out what offset you want, and if you are willing to :sawzall: and :welder: to make them fit.
    A place to start, maybe? https://www.tundras.com/threads/guide-different-types-of-lifts.546/
    Kgfit85 and frichco228 like this.
  3. Jun 18, 2021 at 12:45 PM
    Cem77
    Thanks for the info, I honestly don’t know what I want, everyone around me that have 4wd go with 6” and I don’t want mine that tall, guess I will have to find a couple to look at that are shorter.
  4. Jun 18, 2021 at 12:47 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    That’s a gorgeous looking truck you got there OP!
  5. Jun 18, 2021 at 12:48 PM
    The crazy thing is, the Tundra can pull off any height you want to toss on it. You can add a little bigger tire stock if you only want a little taller truck, too. That's the route I went. I'm not wanting to go huge, so I just bumped up the tire size a tiny bit.
    I'd suggest deciding what your intended use for the truck is going to be, and then seeing what mods fit that goal.
  6. Jul 11, 2021 at 8:20 AM
    Cem77
    Ended up just having the front leveled 2-1/2”, got Nitto Ridge Grapplers and Fuel Maverick satin black wheels with milling and step bars.1C95D82B-041D-4120-8934-C1FFAB6EF95C.jpg
    Kgfit85 likes this.
  7. Jul 14, 2021 at 9:04 PM
    Markful
    Markful New Member
    Mark
    Puyallup, WA
    '21 DBL CAB PRO LR, '08 dbl cab (gone)
    Sharp rig. Tint the front windows a bit and it'll really pop!
    How do u like the nittos?
  8. Jul 14, 2021 at 9:23 PM
    Belated welcome from NY.
    Looks great.
