Differential and Transfer Case Fluid Change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Squirrely, Jun 11, 2021.
  1. Jun 11, 2021 at 12:55 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Im pretty ready now to get this going. I was very hesitant at first, but with all the info you have provided me and the forum. Im ready to get this going.
  2. Jun 11, 2021 at 1:06 PM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    I know what you mean. The first time you do this (or anything else really lol) you take your time, go over everthing twice as you're doing it and make sure you're doing it correctly, but it's really not that bad. The hardest part is just getting your mind set on which oil you're gonna use and getting the necessary tools to do the job correctly. One thing I forgot to mention was that I had a hard ass time getting the rear diff fill plug off, ended up using a breaker bar on it and came off with almost no effort using that.
    Blowdart and Ely010606[QUOTED] like this.
  3. Jun 11, 2021 at 1:17 PM
    Ely010606
    SPARKS, NV
    I definitely have the gear oil made up already. I will for sure read this thread again to refresh this old brain of mine. Just in case i miss anything. Thanks
  4. Jun 11, 2021 at 1:58 PM
    Squirrely
    Squirrely [OP] New Member
    Brandon
    Illinois
    2019 Tundra SR5 Crewmax TRD Off Road
    This is all great stuff. Now to get rid of the rear suspension squeak and I’ll be all set.
  5. Jun 12, 2021 at 7:04 PM
    Ely010606
    SPARKS, NV
    @mech_engineer09 , I got a question, on the crush washer, does the flat end goes to the plug and the rounded side goes to diff side. Or the opposite, or it doesn’t matter. Thanks
  6. Jun 12, 2021 at 7:21 PM
    15whtrd
    15whtrd Mr. Blonde
    I did rounded side towards the diff and flat towards the plug. No leaks
    Ely010606[QUOTED] likes this.
  7. Jun 12, 2021 at 8:09 PM
    Ely010606
    SPARKS, NV
    Awesome, thank you.
  8. Jun 12, 2021 at 8:19 PM
    Wallygator
    Don't waste your money please. Use Royal Purple Synchromax in the transfer case and you and your wallet can thank me later. ;). I also accept beer. Completely compatible with that ridiculously priced golden child oil (genuine LF) from Toyota.
    https://www.royalpurple.com/product/synchromax-manual-transmission-fluid/
  9. Jun 21, 2021 at 7:13 AM
    rodm1
    rodm1 New Member
    Tundra Sask, NCred, Blowdart and 2 others like this.
  10. Jul 18, 2021 at 2:49 PM
    Ely010606
    SPARKS, NV
    @mech_engineer09 , I want to say thank you for all the advice the Amsoil worked out great. I bought 6 qt and I have some extra in the container, the truck was leveled I waited till it started dripping and i stop. Im going for a ride , do I top it off with the remainder or I'm good. Thanks you for everyone also with the advice.
  11. Jul 18, 2021 at 4:50 PM
    mley1
    mley1 New Member
    Martin
    2019 Tundra Limited Crew Max
  12. Jul 19, 2021 at 8:16 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    Ely010606 likes this.
  13. Jul 19, 2021 at 8:35 AM
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    I’m gonna do an early drain & fill at 15k with Amsoil in the diffs and Ravenol 75W in the TC. Thread is bookmarked. Thanks for the info, all! Especially @mech_engineer09 :cheers:
  14. Jul 19, 2021 at 1:05 PM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Do yourself a favor and get the Lexus front diff drain and fill plugs since you're doing an early miles fluid swap. Those 10mm Allens are hateful things IMO.
    Front diff drain plug Lexus PN 90341-24016.
    Front diff fill plug Lexus PN 90341-18060.
    Apx $40 for the two at a Lexus dealer and they'll throw in the washers.
    AndyTex, coldcanuk and Ely010606 like this.
  15. Jul 19, 2021 at 1:34 PM
    Ely010606
    SPARKS, NV
    This will work for the 2017 Tundra . And you use the same washer also. Thanks for the info I just changed mine this weekend and would prefer this if it’s a direct change.
  16. Sep 2, 2021 at 10:05 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Good prices here
    [​IMG] [​IMG]
    Part No.: 90341-24016PLUG, STRAIGHT SCREW$8.08
    Part No.: 90341-18060PLUG, STRAIGHT SCREW$8.05
    Caveman and Jhon like this.
  17. Sep 2, 2021 at 10:33 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    thanks for sharing those I just ordered them for $24 shipped. Hard to beat that.
    parkerbows[QUOTED] likes this.
  18. Jun 30, 2022 at 5:27 PM
    Doxiedad
    Doxiedad Distinguished Member
    James
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    So what kind of socket works best for the transfer case plugs? I bought a set of drain plug sockets. Square drive 8mm and 10 mm and of course it seems that 9mm is what I need, but doesn’t seem to be a common socket.
  19. Jun 30, 2022 at 9:08 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    You can just use a 3/8 drive ratchet on the BorgWarner transfer cases, earlier models have the typical 24mm bolt. The plugs in the transfer case are not in very tight at all, you will be surprised how easily they come out. I'd suggest removing the little skid plate, its not necessary but if you dont the fluid will drain in it, it has a hole but still, its simple to remove. Make sure to use Toyota 75w fluid, thats what it calls for, Ravenol is the only aftermarket supplier at the moment if you dont want to spend the money on the OEM cans.
    Doxiedad[QUOTED] likes this.
  20. Jun 30, 2022 at 9:54 PM
    #50
    Doxiedad
    James
    Awesome. Thanks !
    Joe333x[QUOTED] likes this.
  21. Jul 1, 2022 at 5:59 AM
    #51
    parkerbows
    Jack
    not sure if mentioned but I would use a liquid thread sealant. and I couldnt get near the recommended torque, just felt too tight and was no way near that originally
  22. Jul 1, 2022 at 8:59 AM
    #52
    Joe333x
    Joe333x Member
    Boston
    Yeah maybe i should have used some sealant but I didn't and luckily no leaks, I used where the sealant stopped to know how far to put it back in.
  23. Jul 1, 2022 at 9:17 AM
    #53
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Those Amsoil bags are the best for tight spots. The Sequoia rear end was gonna suck if I had to squeeze from a hard bottle.
  24. Jul 1, 2022 at 9:23 AM
    #54
    Joe333x
    Joe333x Member
    Boston
    Slippery Pete pumps are great too, the one that fits in a normal quart size engine oil quart container is my favorite. I use it for tranny fluid and used it for the transfer case by pouring the 75W can into an old WS bottle. Valvoline is in bags now too, haven't tried them yet though.
  25. Jul 1, 2022 at 9:28 AM
    #55
    Terndrerrr
    Music City
    Dual 5.7s
    Are you referring to the aluminum transfer case? I marked where the plugs were with a sharpie and used Teflon tape when screwing them back in to the spot I marked. No torquing necessary
    texasrho83 likes this.
  26. Jul 1, 2022 at 9:34 AM
    #56
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Hmm ain't heard of those... I'll do some research.
  27. Jul 2, 2022 at 10:58 PM
    #57
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I use a 200ml Mighty Max syringe for the front diff.
    200cc Oil Fluid Extractor, Fluid Syringe Pump Manual Suction Vacuum Fuel for ATV's, Boats, Farm Equipment, Industrial Gear Boxes, Motor Vehicles, Oil Change Evacuation Pump https://www.amazon.com/dp/B08KXN6FVD
    Any regular bottle will work for the rear, and the Ravenol 75w goes in the T-case easily with the extended hose on their bottles.
    I also use the extractor for power steering fluid swaps.
  28. Jul 2, 2022 at 11:53 PM
    #58
    Chad D.
    Chad D. New Member
    Western Oregon
    Not quite midnight here in Oregon….
    I use the extractor syringe to fill the front diff. I drain it like anyone else by dumping it into a pan.
    I use 75w in the transfer case. The Ravenol quart bottles have a nice extendable tube that makes filling the transfer case easy without a pump.
    I have more uses for the extractor than a little oil pump, but I am familiar with them. I’ve used them in the past. I prefer the extractor though. Either one will do the job.
  29. Jul 2, 2022 at 11:58 PM
    #59
    Joe333x
    Joe333x Member
    Boston
    Yup Im an idiot and cant read lol I'm the one who shouldn't be posting 4th of July weekend at 2am. 75w definitely not meant for the transmission! Posts deleted.
  30. Nov 5, 2022 at 11:26 AM
    #60
    truck77
    truck77 New Member
    Tony
    Hey everyone, so I read about all the different metals in the current transfer case so I searched a bunch of fluids. I ended up going with redline mt-lv, which is okay for the metals within the toyota transfer case and is a 75w. They even specify it for toyota and much cheaper then toyota's fluid. Maybe this will help everyone out.
