Air Intake Tube Alternative
Discussion in 'Performance and Tuning' started by JeffMac, Feb 26, 2021.
  1. May 28, 2021 at 11:58 AM
    #61
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Finally got around to building my version on the TRD intake on a budget. I will say that the air seems a lot less confused as to what direction it is supposed to flow. Not much for gains as expected but the slight whistle I had from the K&N drop in filter went away completely. It was replaced with a sort of growl at the 3500-4000 rpm range. I really like the new sound and breaking necks at the dead stop takeoff. [​IMG][​IMG][​IMG]
    chugs, bulldog93, KatoK and 1 other person like this.
  2. May 29, 2021 at 6:43 PM
    #62
    KatoK
    KatoK 2021 Super White 4X4 TRD Pro
    Jeff
    N. Texas
    Looks good! Just confirming, you just bought the TRD intake tube and the other 'tubes' off Amazon?
  3. May 29, 2021 at 7:33 PM
    #63
    Shanet421
    San Diego,CA
    Yes intake tube, air accelerator and PCV hose from Toyota...2 other tubes from Amazon
    I can post links for Amazon if you need
  4. May 29, 2021 at 7:37 PM
    #64
    KatoK
    Jeff
    N. Texas
    thanks, the Amazon link from post #26, right?
  5. May 29, 2021 at 7:40 PM
    #65
    Shanet421
    San Diego,CA
    I returned the 4” ID hose for this one. It’s tight but didn’t have to trim length at all. The 4” was too sloppy for me
    HiwowSport 6inch Length Silicone 4-Ply Long Straight Coupler Silicone Hose Black and Red Color with T-clamp 3.5'' https://www.amazon.com/dp/B0823QHW1J/ref=cm_sw_r_cp_api_glt_fabc_GJRV9B41VJPX9Z53TTG3
    Didn’t use the hose clamps either I’m going for CALI legal that why I got the factory PCV hose also
    chugs and KatoK[QUOTED] like this.
  6. May 30, 2021 at 7:06 AM
    #66
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
  7. Jun 21, 2021 at 11:27 AM
    #67
    KatoK
    Jeff
    N. Texas
    I went ahead with the TRD tubes and bellows. Picked up the PCV tube at AutoZone. What I noticed is that the tube coming out of of the box is what is too long. It hits the first bellow. At first, I thought it was the top notch since the bellows came up short to the lower one but after squeezing it, I realized this. Someone else noted the bellows seemed too large for the box - but the clamp sealed it down well. As of now it all works but it does look to be pushing the top of air box back about a 1/4". No issue yet, but I may trim that down if needed. I like the red look and didn't want to mix up the tubes.
    bulldog93, chugs and prevent like this.
  8. Jun 21, 2021 at 11:30 AM
    #68
    KatoK
    Jeff
    N. Texas
    Another Question - Does the SABM actually do anything? I see that it increases air flow due to 2 holes... I was just going to throw in a better air filter and call it a day...
    10TundraSR5 likes this.
  9. Jun 22, 2021 at 5:41 AM
    #69
    Nowhereman
    Al
    Monterey Bay area
    Look, to each his own but, unless you just want pretty colors in your engine compartment your wasting money.
    Go check out the filters available and find one that passes a little more air.
    Tubes that are colored don't mean squat. The smoother the air flow the better the air flow so unless you have some specific reason to need bellows, stay away and go smooth bore.
  10. Jun 22, 2021 at 8:07 AM
    #70
    KatoK
    Jeff
    N. Texas
    I don't really care about the fancy colored tubes but the simplicity of install. The first half of the TB to 45 degree to straight tube is what I would recommend buying since its pretty much plug n play. There's some mods for the bellows - and along with your point of smoother air, I agree, this is prolly a better item bought off Amazon or the silicone intakes link you provided. I might try the straight tube and offload the bellows here.
    Any thoughts on the SABM? I think its a waste of time but interested in others experience.
  11. Jun 22, 2021 at 11:37 AM
    #71
    Nowhereman
    Al
    Monterey Bay area
    Where I picked up throttle response, mileage and seat of the pants HP was not the intake / filter box system on my WS6 but, the change to ported / polished MAF ends.
    Maybe the combo of all of them as the MAF ends came last for me.
    I would start at the MAF itself then do the intake filter.
    Stock injectors can handle these mods no problem.
    A pedal commander or chip set added to these mods should take care of 90% of the drivers looking just a little more with better mileage.
    After this, I'd do exhaust like the DD set up with a 12 incher (my choice for the Tundra)
    Should have a very good performing motor that up ticks the mileage thing.
    Anything after that better have a MOFO blower or Turbo being shoehorned in.....
    jhardy1979 likes this.
  12. Jul 6, 2021 at 3:13 AM
    #72
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    Here is mine. TRD lid with aFe intake tube and TRD air flow. Still want to do SABM though
  13. Aug 12, 2021 at 4:02 AM
    #73
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    Getting ready to do this and only question I have is what to use to extend the PCV hose - I didn't think the $70ish price tag was reasonable for that. Can I use some standard 3/8" id fuel line that I already have? Do I need to buy a 3/8" id coupler? The extension in the post below is what I am looking at.
  14. Aug 12, 2021 at 5:33 AM
    #74
    Unstable_Trip
    Unstable_Trip New Member
    Tom
    North MS
    '14 Blue Ribbon SR5 DC 4x4
    15/32. You can get 2 ft of it for like $4. Only need about 12 inches though. Just run it from the crankcase to the intake tube
    RobertD likes this.
  15. Aug 12, 2021 at 5:34 AM
    #75
    Eborseti22
    Evan
    Roger that - appreciate the response!
    Unstable_Trip[QUOTED] likes this.
  16. Aug 13, 2021 at 3:10 PM
    #76
    Eborseti22
    Evan
    Got this done today. Ordered the intake coupler, bellows, tube, TRD filter, and airflow accelerator from Sparks. Used some simple 1/2” ID rubber fuel hose in place of the PCV piece.
    Definitely a throatier growl with the resonator gone! As for noticeable gains - maybe better acceleration, but probably just me hoping.
    CCC7C0DF-241A-43ED-B91A-302DCB87DF4D.jpg 00B91A30-283F-4330-8DCD-FE7969BE05B3.jpg
    Shanet421 and KatoK like this.
  17. Sep 1, 2021 at 8:05 PM
    #77
    surffj62
    surffj62 New Member
    2011 DBL RW
    I just switched from a KN cone filter and intake to a stock box with kn filter because the drone of daily driving was just getting to be lame.
    What is it that the resonator does exactly?
  18. Sep 3, 2021 at 7:15 AM
    #78
    KatoK
    Jeff
    N. Texas
    This it too much info but a good description:
    https://itstillruns.com/air-intake-resonator-do-12156112.html
    bulldog93, prevent and Stant1dm like this.
  19. Sep 16, 2021 at 8:44 AM
    #79
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    this is the setup I was thinking about doing as well.
    also, your radium catch can, do you have that attached to your crank case?
  20. Oct 8, 2021 at 9:49 AM
    #80
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    i have this AFE kit but pulled it after thinking about the pop rivets used on the AFE badge. Not sure why they chose to use that type of fastener. I didn’t feel good about the stem dislodging from rivet and going right through the throttle body.
    bulldog93 and TX210Tundra like this.
  21. Oct 8, 2021 at 9:54 AM
    #81
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    I always had that thought too with mine ! Never had an issue though. Could dab a small dot of JB Weld on them for peace of mind.
    gabex35[QUOTED] likes this.
  22. Oct 8, 2021 at 9:59 AM
    #82
    SpeshulED
    Would you happen to have you AFE still? I’ll take it off your hands.
  23. Oct 8, 2021 at 10:02 AM
    #83
    gabex35
    San Diego
    Sorry man, I sold it a few months ago.
  24. Sep 25, 2022 at 3:16 PM
    #84
    MikeBeach
    MikeBeach New Member
    Houston TX
    '11 CM-DAP-SABM/AFE/5100s etc.
    Try #2: trimmed down reducer; 4" to 3" Inch 45 Degree Coupler Elbow Black Silicone Reducer Coupler Turbo Intake Pipe Black https://www.amazon.com/dp/B09CD7RLMV
    $17.55
    Airbox side coupler; Ucreative 4'' Length Hump Black Silicone High Temperature 4-ply Reinforced Straight Hump Coupler Hose (4.0" (102mm)) https://www.amazon.com/dp/B08YZ2VVK9
    $14.99
    TRD Tube= $40.86
    Total: $73.40 into this project.
    chugs, dorton and WVI like this.
  25. Oct 9, 2023 at 1:19 PM
    #85
    RobertD
    Robert
    DFW, Texas
    Thanks all for the info. @Shanet421 was the main person who I mimic'd so thanks for all your details and Amazon parts lists. I didn't like the clamps that came with the boots so I bought some from the hardware store. All in, happy with this mod and the price is a lot cheaper than paying Toyota for the TRD kit. I still don't know the correct way to cut the boots, all I can say is take your time and give yourself room to correct. I did take this as an opportunity to paint my intake cover (engine cover had been painted previously) and really enjoy the pops of blue under my hood :headbang:
    RainMan_PNW and Shanet421 like this.
  26. Oct 10, 2023 at 8:12 AM
    #86
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    bulldog93 likes this.
  27. Oct 10, 2023 at 8:38 AM
    #87
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    lol gold wrap.. But for the stock box, nice drop dry filter, TRD accelerator, SABM, Nice smooth couplers, maybe that K&N tube. But not much gains here. Definitely the dry highflow filter and SABM are worth it.
    GOLD WRAP!
    bulldog93 and RobertD like this.
  28. Oct 10, 2023 at 9:12 AM
    #88
    azTony
    Tony
    Sun Lakes, AZ
    Only thing I do not have are the smooth couplers and the k&n tube. I don’t think I will be doing any gold though, thanks Rey!
  29. Dec 29, 2023 at 8:26 PM
    #89
    Jnickoles
    Jnickoles New Member
    2021 Tundra sr5
    Older thread, I know… but did anyone come up with what combination of parts would work best for the 2021 tundra? I see in this thread that they changed the air box around 2020 sometime, and I’m just looking to basically get rid of the resonator, so did any of the 2020/2021 guys find a combination of parts that fit, sealed and worked well together?
  30. Dec 29, 2023 at 8:57 PM
    #90
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I'm close. Just need to actually have time to finish the install.
