Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. May 25, 2021 at 9:49 AM
    #931
    The 4 inch are sold out
  2. May 25, 2021 at 9:53 AM
    #932
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    Got it. I just updated my post...
    It was me... I didn't want to miss out on organizing the group buy. :p
    Tundra234[QUOTED] likes this.
  3. May 25, 2021 at 9:58 AM
    #933
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Question Jimmy are the 1.5 long enough. MoonRock went with the 2 inch in the group buy. Also these will need washers and nuts correct? Thanks.
  4. May 25, 2021 at 10:01 AM
    #934
    He went with the 2 inch upon my recommendation after the 1.5's sold out.
  5. May 25, 2021 at 10:02 AM
    #935
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    from @Classy63 first post:
    Hardware used (for seeking security hardware)
    5/8x4 (2)
    3/8x4 (2)
    1/2x1.75 (2)
    3/4x1.75 (2)
    @Classy63 are 1.5" long enough?
    RusPro21[QUOTED] likes this.
  6. May 25, 2021 at 10:08 AM
    #936
    AT x AT
    Jimmy
    Mods, what mods?
    From my understanding, we should be able to use the washers and nuts that will come with the plates.
    See @Tundra234 's post: https://www.tundras.com/threads/valhalla’s-shield-theft-deterrent-skid-plates-info-and-ordering-post.84911/page-32#post-2252315
  7. May 25, 2021 at 10:18 AM
    #937
    Netmonkey
    Georgetown, TX
  8. May 25, 2021 at 10:21 AM
    #938
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    In for group buy
  9. May 25, 2021 at 11:17 AM
    #939
    AT x AT
    Jimmy
    Mods, what mods?
    I completely missed Tyler's post!
    Edited my post. We are locked in for this group buy.
    https://www.tundras.com/threads/val...-and-ordering-post.84911/page-32#post-2252234
    I have already placed the order. To keep this thread uncluttered, I will create a PM chat with the following members:
    @RusPro21
    @Netmonkey
    @Bammer
    @Greyota
    @pearlpower
    pearlpower[QUOTED] and Greyota like this.
  10. May 25, 2021 at 11:47 AM
    #940
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    Ok, 1.5 for the 1/2” bolt would work, but you won’t have any threads sticking out but it works
  11. May 25, 2021 at 12:05 PM
    #941
    RusPro21
    Don
    Pa.
    Jimmy can you get the order changed to the 1.75. It probably was not shipped out yet.
  12. May 25, 2021 at 12:11 PM
    #942
    AT x AT
    Jimmy
    Mods, what mods?
    Checking with the vendor...standby for an update.
  13. May 25, 2021 at 1:30 PM
    #943
    Greyota
    Greyota New Member
    2020 TRD Pro CM
    295/70R18 Falken Wildpeaks Toytec Shackles Retrax PRO XR Amp Research PowerSteps Valhalla Cat Plates
    Just a note for anyone with the Amp Research PowerSteps - the passenger side bracket for the rear cat plate interferes with the Amp Research bracket up on the frame. Mine was aluminum, so I drilled out some material to make room for it, and had to drill a second hole in the rear skid plate where it attaches to the bracket. Fairly simple, but something to keep in mind. I'll report back if there are any issues driving around and if the step bracket moves around and hits it or not.
    AggiePhil and equin like this.
  14. May 25, 2021 at 2:04 PM
    #944
    Classy63
    Tyler
    Cypress Texas
    I have installed many plates on trucks that have AMP steps, the arm does touch the bracket, but I have never heard of any issues
    AggiePhil likes this.
  15. May 25, 2021 at 2:10 PM
    #945
    Greyota
    Greyota New Member
    2020 TRD Pro CM
    Yeah, it would retract and close without my little mod, but I wasn't really sure at the time and it didn't take that long to drill out that aluminum.
  16. May 25, 2021 at 5:03 PM
    #946
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    For those who have installed the front and rear cat plates, I am set for the sockets on Tyler's list but Don't have all of the wrench sizes. I have large crescent wrenches for my tractor. Will there be enough room for the crescent wrench, or do i need to look at a set of larger wrenches?
  17. May 25, 2021 at 5:07 PM
    #947
    Classy63
    Tyler
    Cypress Texas
    When I do installs, I use a small electric impact and a crescent wrench under the truck. The only spot where you may have a bit of an issue is the big 5/8 bolts between the oil pan with the crescent.
  18. May 25, 2021 at 5:16 PM
    #948
    3rdTundra
    Central Texas
    Thanks Tyler. I have a small impact and plenty of crescent wrenches. Guess I will give it a shot.
  19. May 25, 2021 at 5:53 PM
    #949
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    You should be fine. I used a large and small crescent on the frame bolts for the side brackets. Those are beefy.
  20. May 25, 2021 at 6:18 PM
    #950
    Classy63
    Tyler
    Cypress Texas
    Something I have considered for V3, I have thought about eliminating the 3/8 bolts and going to 1/2” bolts at the rear of the front plate and front of the rear plate. More strength and one less socket you have to change. Plus the Procomp guys with the traction bars need a 1/2” bolt anyway
    AT x AT likes this.
  21. May 25, 2021 at 7:29 PM
    #951
    AT x AT
    Jimmy
    Mods, what mods?
    That would help with one less socket to use, but how often will someone really be under the truck working on the transmission/transfer case? I may have jinxed myself just by saying that though. :rofl:
    Were there any other improvements to V3 other than changing out the bolts? If it is a minor change and it won't affect your production schedule and you already have the bolts sourced for this change, then go for it. :benchpress:
  22. May 25, 2021 at 9:48 PM
    #952
    Photoweekender
    Photoweekender New Member
    Queens, NY
    2022 Tundra Limited DC TRD OR 4x4 Army Green
    TRD Pro Skid Plate Tonneau cover - OEM Talons Garage cat plate Emblem blackout Solar panel on tonneau cover
    Count me in
  23. May 26, 2021 at 7:17 AM
    #953
    teddyadams
    teddyadams New Member
    Teddy
    The Woodlands
    2021 CM4x4 SR5
    @Classy63
    Just curious, any idea when order R754452031 will ship?
    I'm asking because I'm leaving town and want to be able to give my housesitter a heads up if she's going to have to move something that weighs half her body weight to the garage!
    Also, for others: Fred Haas Toyota replaced mine the same day. Cost me $7,300. Travelers insurance reimbursed me 100% minus the deductible within 3 days. Bastards hit 4 tundras and a Prius at The Woodlands Express park and ride north of Houston.
    equin likes this.
  24. May 26, 2021 at 7:19 AM
    #954
    AT x AT
    Jimmy
    Mods, what mods?
    The group buy is full, but I will put another one together. I will keep you in mind for the next one. :thumbsup:
  25. May 26, 2021 at 8:13 AM
    #955
    Classy63
    Tyler
    Cypress Texas
    Messaged
  26. May 26, 2021 at 10:49 AM
    #956
    Scooter916
    Scooter916 New Member
    Nathan
    08 5.7l CrewMax SR5 2wd,
    custom shift knob, Hooke Road front and rear bumpers, 12v Solutions Remote Start
    @Classy63 So glad I found this forum, we had the cat stolen off our company van a few weeks ago so now I'm super paranoid about my truck. Also I did some some pretty good damage to my stock front skid plate the other night so I might have to be replacing that here soon once I can get under there and inspect. Not that I'm cheap but do you have a "package deal" if I get all three (engine skid, front and rear plates)
  27. May 26, 2021 at 11:22 AM
    #957
    Classy63
    Tyler
    Cypress Texas
    No discounts or package deals are planned sir
  28. May 26, 2021 at 11:24 AM
    #958
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Each plate comes with a discount of about 2500 bucks that you save by not dealing with stolen cats ;)
  29. May 26, 2021 at 11:24 AM
    #959
    Scooter916
    Nathan
    not a problem at all, thought I'd ask. I will start putting some cash aside. Great product BTW!
  30. May 26, 2021 at 11:25 AM
    #960
    Scooter916
    Nathan
    DaddyPete likes this.
Thread Status:
