Investigation: "new" engine sound
Discussion in 'General Tundra Discussion' started by Spvrtan, Apr 13, 2017.
  1. Apr 13, 2017 at 11:55 AM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    So I fixed my initial problem a few days ago after waiting to fix it for weeks (actually a few months due to being busy with other things) where my engine was giving off a high-pitched squeal:
    https://www.tundras.com/threads/engine-whine-especially-when-revving-up-low-voltage-meter.9960/
    ..the problem was a bad supercharger idler pulley bearing.
    Now, I'm onto the next sound, which I honestly don't remember being there or not before the squeal started. It only happens when I shut off the engine. Here's a video of what it sounds like..
    https://www.youtube.com/watch?v=j0yEQtJUffU&feature=youtu.be
    Again, the sound isn't audible with the engine running and the hood popped.
  2. Apr 13, 2017 at 12:20 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Sounds like the fan clutch or bearings bud
  3. Apr 13, 2017 at 12:22 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Air pumps or something like that. Maybe fan clutch. Not really sure. Happens on mine too.
  4. Apr 13, 2017 at 12:28 PM
    Bear
    Bear
    Custer, SD
    I'm leaning fan clutch assembly/bearings...only because that thing still spins pretty good (3-4 seconds)after engine shut down
  5. Apr 13, 2017 at 12:44 PM
    VA10
    VA10 New Member
    Virginia
    Mine has been doing that since I drove off the lot.
  6. Apr 13, 2017 at 3:21 PM
    Normal
    Every Tacoma will do that too.
  7. Apr 13, 2017 at 5:45 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Mine does the exact same thing. Normal.
  8. Apr 13, 2017 at 7:58 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mine doesn't do that....but my secondary air injection pumps have been disabled. I suspect that's what you're all hearing. See if you can localize it in the front passenger fender.
  9. Apr 14, 2017 at 10:25 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Mine makes this noise and it only has 400 miles on it. My wife's 4Runner also has made this noise since new.
