Fumoto Valve Installation
Discussion in '1st Gen Tundras (2000-2006)' started by carpenter356, Dec 9, 2020.
  1. Apr 9, 2021 at 10:35 AM
    #61
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Could it be that the oil pan has been repaired in the past and it has a thread other than oem? Just throwing that out.
    If it was repaired it may not even have a metric thread anymore. I would take the drain plug that came out of it to a hardware or parts store and double check the thread size/pitch. Unless you have a thread gauge etc.
    Also, I put a F133S in my 2008 after I installed a new oem pan. The 133 is an updated version of the 103.
  2. Apr 9, 2021 at 10:43 AM
    #62
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    The Fumoto should thread in just eggzactly like the factory drain bolt. They should make SWEET SWEET LOVE.
    Drainbung likes this.
  3. Apr 9, 2021 at 11:07 AM
    #63
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    i just put on one of these with the short nipple when i did my first oil change. Love it. Have had it on every vehicle i owned. I use a hose to the drain pan. Helps alot to have oil warm and the cap off. i let it drain 15-20 minutes and its more than enough time.
  4. May 6, 2021 at 10:13 AM
    #64
    Old.Ski.Bum
    Old.Ski.Bum New Member
    Paul
    2021 Luna Rock TRD PRO
    I think this may be dumb but, did you use a crush washer when you installed the Fumoto? Thanks
  5. May 6, 2021 at 10:34 AM
    #65
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    2017 Limited Crew TRD, Ironman Pros with JBA uppers. Prinsu rack. RSI, RCI sliders
