Fumoto Valve Installation
Discussion in '1st Gen Tundras (2000-2006)' started by carpenter356, Dec 9, 2020.
  1. Apr 9, 2021 at 10:35 AM
    #61
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Could it be that the oil pan has been repaired in the past and it has a thread other than oem? Just throwing that out.
    If it was repaired it may not even have a metric thread anymore. I would take the drain plug that came out of it to a hardware or parts store and double check the thread size/pitch. Unless you have a thread gauge etc.
    Also, I put a F133S in my 2008 after I installed a new oem pan. The 133 is an updated version of the 103.
  2. Apr 9, 2021 at 10:43 AM
    #62
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    The Fumoto should thread in just eggzactly like the factory drain bolt. They should make SWEET SWEET LOVE.
    Drainbung likes this.
  3. Apr 9, 2021 at 11:07 AM
    #63
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    i just put on one of these with the short nipple when i did my first oil change. Love it. Have had it on every vehicle i owned. I use a hose to the drain pan. Helps alot to have oil warm and the cap off. i let it drain 15-20 minutes and its more than enough time.
  4. May 6, 2021 at 10:13 AM
    #64
    Old.Ski.Bum
    Old.Ski.Bum New Member
    Paul
    2021 Luna Rock TRD PRO
    I think this may be dumb but, did you use a crush washer when you installed the Fumoto? Thanks
  5. May 6, 2021 at 10:34 AM
    #65
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
