The Ultimate Headlight H4, Fog Light and Revers Light Upgrade Not LED or HID 1st Gen Tundra Addition
Discussion in '1st Gen Tundras (2000-2006)' started by onesojourner, Dec 31, 2020.
  1. Feb 14, 2021 at 7:53 AM
    #151
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Thanks fo the heads up on the reversies.
    I'm still looking for those bulbs. The shell on my truck has drapes, so I'm left with looking through the side mirrors and back up cam while backing up.
    That extra light at night would be cool.
  2. Feb 15, 2021 at 6:34 AM
    #152
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Did the 9012 fog light mod. Fogs are way better then the standard 9006 they replaced. More closely matches my headlight color now.
    Also have added LED cargo light bulbs, huge improvement. Also an LED main cabin light, much better. As well as LED back up bulbs. Did not go with the osrams as they were hard to find, more expensive and I have auxiliary LED lights mounted in rear bumper so I'm good as is.
    One thing to note, I shouldn't have changed bulbs outside when it's 15 deg out. One of the tail light housing clips busted... Der.
    Next up new LED parking lights.
    Darkness and HBTundra like this.
  3. Feb 15, 2021 at 7:03 AM
    #153
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I just ordered LED back up bulbs too cause I couldn't find the osrams either. I hope they don't jack up my electrical system (can't imagine they will) . . . I'm old with shitty eye-sight . . . hoping they help at night.
  4. Feb 15, 2021 at 7:13 AM
    #154
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Just installed mine yesterday. They were just a cheap Amazon LED 921 set. They worked when I tested them yesterday in daylight. No electrical issues. Forgot to pay attention this morning but it was fresh snow so pretty bright and not a good test.
    HBTundra[QUOTED] likes this.
  5. Feb 15, 2021 at 8:36 AM
    #155
    onesojourner
    onesojourner [OP] Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Mine broke when it was 70... Epoxy and filler seems to have done the trick.
  6. Feb 15, 2021 at 8:47 AM
    #156
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
  7. Feb 15, 2021 at 9:02 AM
    #157
    HBTundra
    HBTundra New Member
    2006 DC 2wd
  8. Feb 15, 2021 at 9:14 AM
    #158
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Yeah I'll get it fixed up this spring. I knew as I was pulling on it to get the clips to pop out I was running increased risk of it breaking due to the cold. But at the age of the trucks they could break anytime I guess.
  9. Feb 15, 2021 at 5:02 PM
    #159
    Professional Hand Model
    Fred
    Hand Protectors
    I put a little Silicone Lube on those clips last time in there as the Mojo seemed like it needed it. Glad I did based on these potentially becoming a problem.
    Just a heads up to everyone the Sylvania Long Life Incandescents Parking/Brake/Signal Bulbs are cheap and pretty bright compared to some of the LED. The LL Bulbs don’t mess with the System Dynamics, either.
    Punk1974, HBTundra and bmc02[QUOTED] like this.
  10. Feb 16, 2021 at 7:35 AM
    #160
    bmc02
    bmc02 New Member
    Buddy
    E WA
    My 921 LED bulbs are definitely an improvement over the standard bulbs they replaced. Probably not as good as the osrams, but with my in bumper back up lights I don't need any better. Worthwhile upgrade for $20. We'll see if they last as long as they say...
  11. Feb 21, 2021 at 11:22 AM
    #161
    two2cal
    two2cal New Member
    I wish I found this thread before I dropped $35 on some reverse lights but I can tell you these LEDs are BRIGHT!
    Lil Steve, speedtre and KNABORES like this.
  12. Feb 28, 2021 at 5:08 AM
    #162
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Another update on this mod:
    I continue to be pleased with the light output from the headlights, fog lights and reverse lights. Had some battery drain issues that coincided closely with this upgrade. Upon further inspection and measuring of battery drain with the vehicle off it appears my brake controller is the only significant drain at 0.1 amps. I am not currently towing anything that requires the 7 pin harness so I unhooked the power to the controller and harness. Doing so also killed my backup camera it seems, so I'll have to investigate further. Perhaps an always on camera could be the issue and not the always on brake controller. Regardless, the drain does not appear related to the headlight mod.
  13. Feb 28, 2021 at 6:57 AM
    #163
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I ended up ordering these back-up bulbs as sort of an impulse-buy from that online-giant that begins with an 'A'.
    I installed them on my 06 DC w/o issues.
    They are 'heavier' than the stock bulbs, so I bent the receptacle tabs inward a little to give a little better grip.
    I also put a swipe of dielectric on the ends for the 'dork factor'. They are definitely brighter than stock, & it's much easier to see things on screen now while in reverse with the back-up camera in the dark. They are not as bright as @two2cal lights seen above, but I'm satisfied so far. We'll see how they hold up. They were $12.99 for the pair.
  14. Feb 28, 2021 at 7:08 AM
    #164
    Fred
    Hand Protectors
    ‘The A’ has those Osrams back in stock that you couldn’t find last month. They are cheap again at $8 a bulb. Saw this yesterday.
    two2cal and HBTundra[QUOTED] like this.
  15. Feb 28, 2021 at 7:18 AM
    #165
    Fred
    Hand Protectors
    HBTundra likes this.
  16. Mar 31, 2021 at 9:26 AM
    #166
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
  17. Mar 31, 2021 at 9:46 AM
    #167
    These were a fantastic upgrade over the factory bulbs, lots of light and no issues. A little tab bending to tighten up the contacts and they pop right in. Worth it.
  18. Mar 31, 2021 at 12:44 PM
    #168
    Fred
    Hand Protectors
    These are doing nicely. Brighter than both stock or the LED Replacements that I had prior. Overall very good light and just enough to be happy without the extra work/cost of adding additional Aux Lights. Thanks for the recco.
    Update still doing well.
  19. Jul 14, 2021 at 5:36 AM
    #169
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Is anyone else here running the best lighting money can buy?
    BubbaW likes this.
  20. Jul 14, 2021 at 6:13 AM
    #170
    9 months later this mod is working well for me. No burn outs, no battery issues. Good light output.
  21. Jul 14, 2021 at 6:48 AM
    #171
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Putting on short list for fog light update or at least clean up my orig faded globes !
  22. Jul 14, 2021 at 7:03 AM
    #172
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Keep us posted. That was my main front facing light source until I got my harness built.
    BubbaW[QUOTED] likes this.
  23. Jul 14, 2021 at 7:56 AM
    #173
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    Will do…..on page 2 of 6 of comments/advice and veering down rabbit holes from the links posted. Something LED simple for 2004 DC LTD
  24. Jul 18, 2021 at 2:32 PM
    #174
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    5160/6112
    Anybody used the harness the Chinese harness originally listed?
  25. Jul 18, 2021 at 2:38 PM
    #175
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
  26. Aug 10, 2021 at 5:41 AM
    #176
    8 months later, still going strong. Don't drive a lot, maybe 5-6k miles per year, but haven't had any burnouts yet. Or more importantly burn downs. Mod seems solid, keeps the factory look.
  27. Aug 29, 2021 at 6:05 AM
    #177
    daveeasa
    Thinking through the resistor aspect here. Haven’t done my lighting work yet but it’ll be a harness and I’ve so far decided OEM housings for now. I intend to move DRL to the side / signal light via switchback somehow (not sure yet how). And long term I’m hoping for some adapter to get a regular pod in the fog location. Short term I might do a bulb mod or just leave them off. The easiest route there may be a completely independent harness directly off the switch, though I guess that means no indicator light in the dash. I could probably live with that. Also a little tempting to play around with trying to shove a more modern stalk into place with a conversion harness to feed the OEM side.
    Anyway, here is where I wasn’t anticipating trouble. If using a harness, it seems some (all?) trucks won’t turn on the lights at all since the coil draw is so small? In which case the suggestion is to add load resistors of ~50w?
    So, say you use 100w bulbs and the harness, and you “need” resistors, total change from factory spec is around +200w total? Which is ~14 amps, maybe round up to 15? And half of that is going to lighting, the other half wasted to resistors?
    Or do the 50w resistors not actually burn 50w but are rated to 50w?
    Since the headlights do not need to be on for the ECU to be happy, I’m almost wondering if a completely independent system would be best. Maybe a timer to turn off the relay coil after 10 minutes without ignition to add some protection?
    I’m mostly thinking maybe the best plan is to just hijack the negative trigger for high and low beams at the stalk and go from there.
  28. Aug 29, 2021 at 9:53 AM
    #178
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The issue is with the way fog lights work on these trucks. You need to mess with the fig switch and all the weirdness goes away.
    fog light switch gers it’s voltage from the high beam side when lows are on. When you turn the highs on, you fog switch is now ground and ground. I removed the factory pin and ran my on 12v ignition wire to the switch. No more issues
    And I can turn fogs on whenever
    HBTundra and daveeasa[QUOTED] like this.
  29. Dec 8, 2021 at 3:39 PM
    #179
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    03 Tundra AC TRD
    I may have missed this earlier in the thread, but is there an issue running H4 bulbs 100/55W with the stock wiring? I'm assuming that until I upgrade the headlight wiring harness it can't deliver the necessary power to the bulbs and I'm just not getting full use. I'm not experienced with electrical work so pardon my ignorance @empty_lord
  30. Dec 8, 2021 at 3:40 PM
    #180
    empty_lord
    05 rollover special
    The stock wiring can get too hot and pop the fuse or worse catch fire. Rare but can happen. But it will be like less than half the expected output. Not worth it without a harness
    HBTundra and Kimosabe[QUOTED] like this.
