TRD 2UZFE Engine
Discussion in '1st Gen Tundras (2000-2006)' started by evilrb, Feb 13, 2021.
  1. Feb 13, 2021 at 9:25 PM
    evilrb
    evilrb [OP] New Member
    Jeremy
    UPDATE: 4/7/22
    More info found from the new owner!!
    It's likely a 5.4 330cc block!!!!
    N/A it was rated for about 600 hp
    275152595_515015030270204_1715172361595186170_n.jpg 276016336_288791203427016_1058598110352244127_n.jpg 275639967_969501173932404_1081307641595148438_n.jpg 274840142_1023388151927533_6298050424328258267_n.jpg
    UPDATE: 3/9/2022
    The Block has found a New Home!
    More info here:
    It was an honor to be a part of the caretaking of this special engine.
    The new owner is not only very knowledgeable in our community but it going to be building it and installing back into a Tundra in the future.
    This was most important to me...
    He also found more possible info and so far it is lining up!
    I now have a solid Time Attack toy to play with that I honestly wanted since I was a kid!
    Love the flip ups!
    UPDATE: 3/24/21
    Got the block back from the shop and is going into the corner of my storage until I can find here a good home.
    SO if you're interested just send me a PM.
    Thanks to Gerald and David at Al & Ed Autosound in Huntington Beach!
    They not only hooked it up but definitely made me feel like I wasn't crazy! :rolleyes::rofl:
    163857189_10159461475374236_4925576923323593384_o.jpg 164342631_10159461475359236_4678826567841583701_o.jpg 164701140_10159461475369236_3430708545814555473_o.jpg 163959781_10159461475364236_9220639853414919699_o.jpg 164072077_10159461475339236_6399311515580662529_o.jpg 164544110_10159461475354236_5039477909253049436_o.jpg 164724675_10159461475349236_4027471867810958547_o.jpg 163413406_10159461475384236_2865272992598712212_o.jpg 165241186_10159461475379236_2415379342621997688_o.jpg
    UPDATE: 2/17/21
    So I was moving the engine and left it in my truck this weekend and wouldn't you know that the first rains we had in a bit just so happened when I had to leave my engine overnight...
    Well, the cylinder walls got a slight surface so I just dropped it off to get it cleaned up for long-term storage until I have a good home for this bad boy!
    While there we took measurements on the bore size in comparison to the other stock block I have and well...
    The TRD block is 3.800-inch bore compared to the stock 3.691-inch
    The crank is also forged and looks like has a longer stroke.
    Also, the cam gears look to be Chromoly as well.
    It's getting stripped down this week, measured, cleaned, and painted before being wrapped up in plastic.
    I'll post as much as I can on the process but boy is this tempting to play with more...
    Let me know if you guys have any more input or theories about proper size or if you just even want it.
    I just feel better about taking care of this properly for the future.
    Special thanks to David and the crew at Al & Ed's auto sound in Huntington Beach!
    MORE PICTURES ADDED BELOW:
    20210214_170647_resized.jpg 20210216_145709_resized.jpg 20210214_170642_resized.jpg 20210216_145709_resized.jpg 20210216_145715_resized.jpg 20210216_145726_resized.jpg 20210217_145946_resized.jpg 20210217_145958_resized.jpg 20200320_172857.jpg 20200320_173549.jpg 20200320_173919(0).jpg 20200321_171001.jpg 20200320_172912.jpg 20200321_171007.jpg 20200321_171030.jpg 20200321_171045.jpg 90507093_10158400670934236_6255835972198465536_o.jpg 1ddfaeacd76f4a98b037cdf0bc017dec.jpg ba1c45d0af1f44a1a3680a8bccd451e0.jpg 20200320_172713.jpg 7f4b600a0818411b9ab4cb4fe23b6cb1.jpg
    Ok guys, I've been putting this off but now I have some down time>
    As promised here is all the pictures and info I have on the TRD Block that I scored.
    I got it off of offer up and I noticed the TRD logo's so I went to check it out.
    This is one of the engines from Rick Huseman who died in 2011
    Info here:https://en.wikipedia.org/wiki/Rick_Huseman
    The engine seems to be complete except rods, pistons, and cams.
    TRD dry sump pan
    TRD Crank
    Various TRD plates and engine cradle
    Had it checked out and it's definitely in great shape but does need a refresh of everything done to it since it's just been sitting for over a decade.
    Also got 2 Boatec racing bedside from his truck too, if anyone is interested.
    I also have a spare engine that is torn down that was with it.
    I haven't looked through everything yet as my space and time is limited.
    TRD is close to me in Costa Mesa but the people I used to know there are no longer there anymore, neither are my connections at Toyota...
    So if you guys have any info to share I would be more than grateful to hear it!
    Info I've found so far:
    https://www.trdusa.com/trd-engines-behind-the-build.html
    https://en.wikipedia.org/wiki/Triad_Racing_Technologies
    And 2 ebay listings that might be comparable:
    https://www.ebay.com/itm/Phase-14-T...Engine/283751145895?ssPageName=STRK:MEBIDX:IT
    https://www.ebay.com/itm/Toyota-TRD...lumbed/133630865583?ssPageName=STRK:MEBIDX:IT
    Ultimately, I want to find a good home to someone that will rebuild it and use it for what it is.
    it's a great coffee table but sad to see it there at the same time.
    Would love to trade it for an MKIV Supra shell or a GT4 Celica, Evo, Etc...
    You know, something fun to play with on the track and mountains
    Or atleast add to the funds to get me there.
    Please add any info that you can contribute!
  2. Feb 14, 2021 at 5:07 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    What are the big differences between the TRD block and the factory 2UZ? Beefier mains and crank? Thicker decks? Appears at least one of the two crate engines you linked are of larger displacement. Bigger bore on this one? The others don't appear to be running any boost. The drag one has a 250 shot of nitrous on it. Curious what rods and pistons they are running for that. It's a cool piece for sure.
    evilrb[OP] and speedtre like this.
  3. Feb 14, 2021 at 7:29 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I think I just heard @empty_lord take a VERY deep breath...:D
  4. Feb 14, 2021 at 10:40 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ve known he’s had it and I want it
  5. Feb 14, 2021 at 10:55 AM
    Professional Hand Model
    Fred
    Hand Protectors
  6. Feb 14, 2021 at 10:56 AM
    speedtre
    speedtre New Member
    Inland Northwest
    :thumbsup:
  7. Feb 14, 2021 at 11:46 AM
    empty_lord
    05 rollover special
    I can dream right? I can’t get any info about it from region. I wouldn’t be surprised if it’s a special higher than normal nickel content iron block designed for more abuse.
  8. Feb 14, 2021 at 11:53 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    BA. :popcorn:
    Tundra2 likes this.
  9. Feb 14, 2021 at 12:05 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    That is exactly what I'm wondering too, those bores are gigantic.
    Tundra2 and evilrb[OP] like this.
  10. Feb 14, 2021 at 1:28 PM
    evilrb
    Jeremy
    I know the TRD crank and mains are but not sure about the bore size.
    When I first got this and had it checked, I didn't know what specs to look for so it was just a basic inspection.
    I can measure it but god knows where my tools are in my storage.
    I included all the info I could that I've collected so far.
    not much other info, that's why I posted so you guys might be able to help me get more info.
    or ask the right questions for me to find out.
    As of right now, it's staying with me and I'll clean it up and try to store it properly to use down the road.
    It's such a kool piece that I really want to see it run again one day.
    But I'm still open to hear what you guys think it's worth or want it.
    As long as it will be cared for that's the best I'm looking for.
    empty_lord, I told you I'm interested in your Benz. :rolleyes:o_O:D:rofl::rofl:
  11. Feb 16, 2021 at 1:26 AM
    evilrb
    Jeremy
    I just realized that I posted this thread in the FS section.
    I am looking to sell it but with caveats... trade would be better, will add cash too for the right project...
    Can a Mod move this or should I just make a new thread??
  12. Feb 17, 2021 at 7:05 AM
    Where do u want it moved to
    evilrb[OP] likes this.
  13. Feb 17, 2021 at 7:15 AM
    evilrb
    Jeremy
    It's a 2uz so first gen threads or general, dealers choice!
    Thanks!
    Tundra2 likes this.
  14. Feb 17, 2021 at 6:14 PM
    evilrb
    Jeremy
    Updated!!!
    Tundra2 likes this.
  15. Mar 24, 2021 at 10:55 PM
    evilrb
    Jeremy
    Another Update with more pictures!
    I love the way it came out and I definitely feel better about doing it!
    N84434 and Tundra2 like this.
  16. Mar 24, 2021 at 11:30 PM
    empty_lord
    05 rollover special
    3.800 bore? Did you happen to get crank measurements to see if it’s a striker? Curious what displacement that sucker is. May give ideas for me...
    seems like 4.9ish l would achievable with just a bore and larger pistons. Couple that with maybe a bump in compression and blueprinting, can probably make the 2uz a decent performer for not a TON of money.
    Tundra2 likes this.
  17. Mar 25, 2021 at 1:22 AM
    evilrb
    Jeremy
    I was in a rush today but forgot to ask.
    Earlier they confirmed a bigger crank.
    Ill try to ask for the numbers or measure it myself if I can...
    Gotta look up how...
    But it looking around it looks like right around the 5.0 mark similar engines with the bore were 5.3 like the 3S motors so maybe close to there.
    I'm still an amature so I don't want to speculate too much.
    I got a bunch of parts to install on my truck so for the next few weeks I'm gonna concentrate on that.
    Unless... the benz is an option and I'll get you all the info I can...:rolleyes::p:rofl::rofl::rofl::rofl::rofl:
    empty_lord[QUOTED] likes this.
  18. Mar 9, 2022 at 12:22 AM
    evilrb
    Jeremy
    BUMP for the NEW Update!
    Schcoman, 5N0W808, KNABORES and 3 others like this.
  19. Mar 10, 2022 at 8:40 AM
    nickrick78
    nickrick78 New Member
    Pittsburgh PA
    2004 DC
    We need some more of *these* updates ;)
    evilrb[QUOTED][OP] and Darkness like this.
  20. Mar 10, 2022 at 8:47 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I just got a 6" lift myself :anonymous:
  21. Mar 10, 2022 at 9:04 AM
    FrenchToasty The Desert rat, 6 lug enthusiast
    The SoAz
    None
    Shackle or puck lift?
    evilrb[OP] and Darkness[QUOTED] like this.
  22. Mar 10, 2022 at 9:12 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Cradle with full spindle extension :bananadance:
  23. Mar 11, 2022 at 12:25 AM
    empty_lord
    05 rollover special
    It was a drag racing program engine
    evilrb[OP] and 5N0W808[QUOTED] like this.
  24. Mar 11, 2022 at 12:46 AM
    evilrb
    Jeremy
    Possible TRD team racing engine
  25. Apr 7, 2022 at 9:13 PM
    evilrb
    Jeremy
    BUMP WITH NEW INFO
  26. Apr 8, 2022 at 4:10 AM
    bmf4069 Yup, that's car parts in a dishwasher
    I like doc Martin's.
  27. Apr 8, 2022 at 6:25 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Those blue besides you got, were those with the motor? Looks a bit like that fabtech color.
    evilrb[OP], bmf4069 and FrenchToasty like this.
  28. Apr 8, 2022 at 9:59 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 AC TRD
    Bassani cat-back
    Cool stuff for sure, glad it went to an enthusiast.
  29. Apr 9, 2022 at 12:39 AM
    evilrb
    Jeremy
    Yes, I bought this engine and bedsides off Rick's brother... Didn't know it at the time.
    Thanks, everyone, if I find out more, I'll post it for future reference.
    Darkness[QUOTED] likes this.
  30. Dec 4, 2022 at 2:32 PM
    rancejunge
    rancejunge New Member
    Rance
    Lexus GX470
    lift DT headers MAP ECU3
    So did someone buy this block or still for sale? Thanks.
