  1. Mar 10, 2021 at 10:14 AM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    I just installed my new Spyder headlights, TRD Pro Grille and DIY Footwell LED mod. I have to lower my light bar. In a time crunch so I’ll do that later. Next week I’ll finally get around to install my Bumpershellz. Ignore inspection sticker date its COVID season.F4F9C5EB-F49A-4DED-8207-BB9B41BA5C34.jpg
  2. Mar 10, 2021 at 10:43 AM
    harrydunn
    harrydunn New Member
    Columbia, MO
    Because I was inverted.
    Call it, Friendo.
  3. Mar 10, 2021 at 10:46 AM
    3xYOTA
    3xYOTA Taco/Rav/Tundra
    Far West Texas
    2020 Tundra 1794
    is the hood bulge flat black or are my eyes playing trick on me. Interested to see how the bumbershellz come out
  4. Mar 10, 2021 at 10:53 AM
    The_Geologist
    The_Geologist I reject your reality and substitute my own!
    Flathead Valley, MT
    2019 Tundra Limited CM Cavalry Blue TRD OR
    Line-X bedliner Century Ultra Topper Thule Rack
    I've had the Tundra 3 months now, and just passed 1,000 miles that I have put on it. Yes, I don't drive much. Don't usually take trips until the summer!
    Just ran it through the touchless car wash last night to get the worst of the winter crud off it. Need to re-learn how to hand wash a vehicle once it gets warmer out. Haven't done that since I was a kid!
    Fotnot and JerryH like this.
  5. Mar 10, 2021 at 11:02 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    dig around in here a lil bit if you're needing ideas on anything. also ask if needed. pretty knowledgeable guys in there
    https://www.tundras.com/threads/ask-the-detailer.18408/
  6. Mar 10, 2021 at 11:24 AM
    vanthesupreme
    vanthesupreme I'm Batman
    OKlahoma
    2014 Tundra
    Yes a little bit. Ill take pics later this afternoon of the driver and passenger difference for ya
  7. Mar 10, 2021 at 11:32 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Why did you go with the Spyder headlights over the OEM LEDs?
  8. Mar 10, 2021 at 11:43 AM
    JeffMac
    Jeff
    South Florida
    I have the bulge plasti dipped black for now. I may do a coat of the glossifier ontop to see how it comes out. Most likely I’ll order a painted one.
    Sean492 likes this.
  9. Mar 10, 2021 at 12:04 PM
    TWINTURB089
    TWINTURB089 New Member
    BILL
    2021 1794 TUNDRA
    81FC2CD7-EEED-4282-804C-DA3E99AB4B6C.jpg Just bought a 2021 1794 last night and installed dick cepek 305/55/20s on the stock rims, no lift, no rubbing. Looking at a lift kit so i can go to 35-37 inch tires.
  10. Mar 10, 2021 at 12:45 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Interesting Stealership story but one I'm familiar with as this happened to me (at least once) before on my Infiniti.
    Took my Tundra in for 10k mile oil change and tire rotation. Note: I had the oil changed at 1k and 5k miles and they covered it under Toyota care but for some reason they made me pay for this one.
    I recently curbed my front passenger rim. So when I picked up my truck just now, the curbed rim was in the same position. So I called and said, "the tech didn't rotate the tires and if he told you he rotated the tires, how do I know he actually changed the oil?"
    The SA said he would check the video footage. He called me back within 6 minutes (I found it odd he could check video footage that quickly) and said he checked the video and the tech did change the oil but did not rotate the tires.
    Now I don't know what to believe. I guess I'll have to start changing my own oil.
    BlueRibbon4x4 likes this.
  11. Mar 10, 2021 at 12:47 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    Lift kit alone likely won't solve rubbing issues with 35" or 37". You'll probably need a BMC too.
  12. Mar 10, 2021 at 12:50 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    This is the way.
    Jcmf52 and FlyingWolfe like this.
  13. Mar 10, 2021 at 1:25 PM
    TWINTURB089
    BILL
    2021 1794 TUNDRA
    ???? Really.... I figured i would go with the 6 inch lift kit. I cant believe adding 6 inches of lift would rub adding 2 inches of rubber. Seems odd
  14. Mar 10, 2021 at 1:55 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Oh my word I was totally joking about the tilt-o-whirl thing and then this little bastard falls out of my blower LMAO
  15. Mar 10, 2021 at 1:56 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    6" might do it. Everyone I know who has done 4" or less can't fit 35" without a BMC.
  16. Mar 10, 2021 at 2:14 PM
    Dwarven1
    Dwarven1 New Member
    Ross
    2018 SR5 w/TRD Off-Road.
    2018 SR5 - Bolo Mark XXb - Unit DNE of the Line. "Denny"
    Just stumbled across this product while doing a web search for a folding step, and it looks to me like a better alternative. For me, anyway.
    A year and a half later, how do you like it, Tao?
    Or maybe I'll just bungie one of these to the bed rail. Hmm.
    https://www.amazon.com/Louisville-F...,p_72:1248909011&rnid=1248907011&s=hi&sr=1-13
    Ol' Salty Dawg likes this.
  17. Mar 10, 2021 at 2:39 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Used mine to get lost for a few hours today.5D771119-E774-4FB5-8E0E-60C022D8F539.jpg
  18. Mar 10, 2021 at 2:45 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Have the SA show you the video. That is the ONLY way to prove that they changed the oil.
  19. Mar 10, 2021 at 2:46 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    What was the dog looking at in the third picture? Lol
  20. Mar 10, 2021 at 2:59 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    When I take it back to have them rotate the tires, I'm going to ask to see the video.
  21. Mar 10, 2021 at 2:59 PM
    Oerterg
    Oerterg New Member
    2020 MGM sr5 sport crewmax 4x4
    2B8421AE-581A-405E-891C-BA1D3C29D2BD.jpg Installed the meso Red TRD start stop button. I swear i feel a 20 ho gain.
  22. Mar 10, 2021 at 3:10 PM
    Unstable_Trip
    Unstable_Trip New Member
    Tom
    North MS
    '14 Blue Ribbon SR5 DC 4x4
    I probably laughed at this way harder than I should have. I mean I'm glad you found the root of your issue and can start to get it resolved, but just that image is way too funny to me.
    FlyingWolfe[QUOTED] likes this.
  23. Mar 10, 2021 at 3:32 PM
    PKFan
    2018 Inferno! DC SR5 4x4
    Fargin bastages!
    CappyKD and FlyingWolfe[QUOTED] like this.
  24. Mar 10, 2021 at 3:32 PM
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    Got my maintenance wash done with a ceramic booster. Interior was cleaned too.
    NSp1wPNp3XhOC-m3TxH8U52lvUw8cZOlwy39mSKM_74da5bc5bf2e77532b8b593b4ab0ca3d87457bbf.jpgGmkrdgG8VB5XmF6VOTyGzCsaop3BUzC_1Q3h-x_6_8ffeaae6fbc408fdfcd857ba8b49578cafd7a5bd.jpg
  25. Mar 10, 2021 at 3:33 PM
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    Put in my new Husky xact contour floor mats. So much better than the Toyota ones.
    x3sVccCbnHnlOtWfsWVZ8xxqTHkmA9luctxDpxPM_41f63013962ec8cdf86505c5bb2cce140ca8e07e.jpgxrPF-vLtnk88qrmETUjvEYN_qATV5lmUryl9tCSk_c3ef43d17a889d395e8a45931dc9d9cd06287160.jpg
  26. Mar 10, 2021 at 4:36 PM
    Guerrilla
    Guerrilla New Member
    13 Black Tacoma
    :rofl:What are the odds....
  27. Mar 10, 2021 at 4:54 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    A 20 HO gain....damn, now I wish had push button start again.....:rofl:
    WFD473 likes this.
  28. Mar 10, 2021 at 5:30 PM
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    Posed in the Southern California rain.
  29. Mar 10, 2021 at 5:30 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    20210310_130655.jpg 20210310_130705.jpg 20210310_105515.jpg 20210310_110409.jpg Did a couple of things today. Installed a front and rear dash cam. I went with tha Apeman c860. Got it for a good price. Then i found some Chemical Guys Hard water spit remover and clean my windows.
    GAknight, WILLINH, YotaBro and 5 others like this.
  30. Mar 10, 2021 at 5:44 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Think you found your culprit :thumbsup:
