100,000 Mile Tune Up: What's needed?
Discussion in '2nd Gen Tundras (2007-2013)' started by DesertRoads, May 22, 2019.
  1. May 22, 2019 at 1:46 PM
    DesertRoads
    DesertRoads [OP] Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    Good day! I just rolled over 100,000 miles in my 2012 SR5. The dealer quoted me over $1,200 for a complete 100,000 mile tune up. So... how difficult is it to do the spark plugs? What's all recommended to keep my truck rolling on for another 100,000 + miles? Any direction would be greatly appreciated. Thank you!
    georgiey22 likes this.
  2. May 22, 2019 at 1:53 PM
    FirstGenVol Brake Czar
    2002 AC
    I would really like to know what all this includes. It sounds incredibly high.
  3. May 22, 2019 at 1:56 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Plugs are recommended @120k, flushing or drain and fill your transmission fluid is a good start. As far as changing plugs out, I would like to know myself. $1,200 is ludicrous. Just my .02:D
    Silverghost and Rica25 like this.
  4. May 22, 2019 at 2:55 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Engine coolant.
    Rear differential oil/fluid.
    Front differential oil/fluid.
    Transfer case oil/fluid.
    If you have polar bear anxieties then replace the gas cap.
    Y0TA PR0 likes this.
  5. May 22, 2019 at 2:59 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    @ARamirez73
  6. May 22, 2019 at 3:21 PM
    rons23 and Y0TA PR0[QUOTED] like this.
  7. May 22, 2019 at 3:54 PM
    TheBeast
    TheBeast The Beach
    serpentine belt ?
    Silverghost likes this.
  8. May 22, 2019 at 4:52 PM
    rons23
    Ron
    Kill Devil Hills
    @TheBeast, Haha good call:thumbsup:. I replaced my factory belt with a Goodyear Gator Back. Great reviews .
  9. May 22, 2019 at 8:38 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Grease drive shaft u-joints. Don’t forget front shaft if 4wd.
    Gotta get the wheels off the ground so you can rotate the drive shaft to get access to the zerk fittings.
    Make sure you wipe dirt off fittings first.
    Greg
    PolskaTRD likes this.
  10. May 22, 2019 at 8:57 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Are you happy with that belt?
  11. May 22, 2019 at 8:58 PM
    georgiey22
    Have a photo of your truck?
  12. May 23, 2019 at 2:18 AM
    rons23
    Ron
    Kill Devil Hills
    @georgiey22 Yes, well made. No problems, I've had it on 5 + years. I changed it out along with both pulleys.
    georgiey22[QUOTED] likes this.
  13. May 23, 2019 at 2:20 AM
    rons23
    Ron
    Kill Devil Hills
    @OR18TRD, yes it's been 5 + years. So is the continental the same belt?
    OR18TRD[QUOTED] likes this.
  14. May 23, 2019 at 4:04 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Good God seeing these prices makes me glad I’ve been doing peiodic fluid changes throughout my 90k. No fluids should need to changed at 100k. Spread it all out over the last 10 years so I’d be less likely to get hit with one huge service at around that time.
  15. May 23, 2019 at 7:19 PM
    FXFormat
    FXFormat New Member
    I'm a mechanic, at a 100K miles, this is what I would do to my truck
    Spark Plugs
    Cabin Filter/Air filter
    Serpentine belt
    Flush coolant/brake fluid/power steering
    Drain and fill trans, transfer case, rear diff oil.
    Grease all zerks on the driveshaft
    I check all bushings, tie rods, shocks/springs and replace if necessary
  16. Sep 20, 2019 at 9:20 PM
    spcbuzzard
    spcbuzzard New Member
    Dustin
    2011 Tundra 4.6L V8
    Just took mine in yesterday for 100,000 miles. Oil change, flush coolant system, and grease everything up. Cost $150 give or take.
    Rica25 likes this.
  17. Feb 18, 2021 at 7:49 AM
    2012RockWarrior
    2012RockWarrior New Member
    2012 Tundra Rock Warrior
    FXFormat Do you recommend the waterpump be changed when doing the serpentine belt?
  18. Feb 18, 2021 at 1:24 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I would plan to throw the water pump away at ~15 years of age if it hasn't started leaking, but for a 2012 truck I wouldn't worry about throwing it away. When you do the water pump, a new thermostat isn't a horrible idea either.
    After 100,000 miles, I would also toss a spare coil pack in the glove box just in case. When one coil pack goes, use that as an excuse to do them all.
  19. Feb 18, 2021 at 1:29 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Just a point of reference. My 1997 T100 (3.4L V6) is on its FACTORY original water pump. 265K miles.
    Silverghost and WILLINH like this.
  20. Feb 18, 2021 at 1:40 PM
    audiowize
    Paul B.
    Yeah, I put a ton of mileage on my V6 4Runner's water pump also and never had a thought about replacing it. Ditto to a family member's 4.7L equipped Lexus, which had about 230K on the original water pump before they sold the vehicle. There are enough people around talking about needing a new water pump here and there that you could certainly preemptively replace it.
  21. Feb 18, 2021 at 8:26 PM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    What all were they including in this service? I was at 90K and preparing for a drive from OK to AK pulling a TT. I did the tranny, front & rear diff, coolant flush, brake flush, and maybe even power steering. My next "big" item will be spark plugs at 120k.
  22. Feb 19, 2021 at 7:27 PM
    Silverghost
    Silverghost New Member
    13 tundra 4x4
    GREAT TRUCKS ,LOVE THE T100
    Malinois38 likes this.
  23. Feb 26, 2021 at 4:57 PM
    Tundramaster15
    Tundramaster15 New Member
    Darrin
    Another reference. I been doing recommended maintenance and I have 420,000 miles. The valve cover gaskets are leaking just now. So I’m changing them and spark plugs since I’m already there.
  24. Feb 26, 2021 at 6:38 PM
    koditten
    koditten New Member
    I emptied the ashtray...
    Leo's first and newguy like this.
  25. Feb 26, 2021 at 9:02 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    420k?!?
    do what ever this guy has been doing!
    Junior 88, Kung and TheBeast like this.
  26. Feb 28, 2021 at 8:40 AM
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    at 100k, I replaced plugs, brakes, tires, shocks, trans/transfer/diff fluids changed, and flushed radiator and brake fluid. The valve covers were leaking, so I had them change those too. The shocks made a wonderful change, the rest I haven't noticed anything of course. I have pulled a 6500 lb boat/trailer long distances with this truck with no issues.
  27. Mar 1, 2021 at 5:16 PM
    GreatBallsOfFire
    GreatBallsOfFire "I wanna go fast" - Ricky Bobby
    Seth
    Fairbanks, AK
    2017 Pyrite Mica Sequoia Limited
    What is considered recommended maintenance? Just whatever the dealership says to do?
  28. Mar 1, 2021 at 5:48 PM
    Kung
    KG, VA
    I dunno, but whatever he's been doing, it's working. LOL
