How Do I Remove Exterior Toyota Badging?
Discussion in '1st Gen Tundras (2000-2006)' started by Glock 40, Dec 2, 2020.
  1. Dec 2, 2020 at 2:33 PM
    Glock 40
    Glock 40 [OP] I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I'm going to black-out my chrome badging (sides and tailgate). It's about the last of the chrome tidbits left on this thing. The door trim will be pretty easy. I can black out the badging while in place but it'll be a lot of work. I'd rather pop them off and prep them in the blast cabinet (hand protector unit box), then reattach. Did the yota gods make these accessible and removable or am I just better off hand-prepping them in place?
    [​IMG]2020-12-02_03-19-59 by GhostCreekMine, on Flickr
    [​IMG]2020-12-02_03-20-09 by GhostCreekMine, on Flickr
  2. Dec 2, 2020 at 2:36 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
  3. Dec 2, 2020 at 2:39 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    What? They're just glued on? Sounds too easy. :monocle:
  4. Dec 2, 2020 at 2:47 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    The badges will pop off from glue, and maybe even break upon removal. Getting glue residue off will be the bigger issue. It all depends on how stubborn they want to be.
  5. Dec 2, 2020 at 2:50 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Are they made of plastic or metal?
  6. Dec 2, 2020 at 3:00 PM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
  7. Dec 2, 2020 at 3:01 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Hair dryer for a few minutes to soften le glue then fishing line to slice behind the emblem and separate the glue. Then some Goo Gone or similar to cleanup ye olden glue residue.
    jImmegart, LS3, N84434 and 6 others like this.
  8. Dec 2, 2020 at 3:04 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    ^^^ DITTO
    Works like a charm
    FIRST thing I did to my 18’ on first day of ownership- CLEAN & MEAN !
  9. Dec 2, 2020 at 3:07 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Dang... then no blast cabinet for prep. I'm gonna have to think about it. I'd be pist if I broke one or more of them. I have heat guns, that's not a problem. They've gotta be somewhat brittle after 20yrs. I'm sure a replacement set of badges isn't a cost effective option. Leaning toward prep-in-place now. Super tedious.
  10. Dec 2, 2020 at 3:16 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I successfully removed my badges off my tailgate with some gift cards. They are thin, yet stiff enough (she said) to push through the gooey adhesive that holds them and don’t scratch the paint. I cleaned and goo gone’d the crap out of the areas getting off the adhesive yet was unsuccessful in removing the ‘footprint’ which didn’t matter as I was painting the tailgate anyways so I sanded that down.
    Since you’ll be reinstalling I think you’ll be ok with reinstall back over the footprint. Its easy to remove them with the heat. Just takes time.
  11. Dec 2, 2020 at 3:20 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Alright, I won't be a puss. I'll try getting them off. Heat gun, fishing line, playing cards, goo be gone. Check.
    Might have time to fiddle with it this week. Thank you gentlemen, glad I asked about this.
  12. Dec 2, 2020 at 5:54 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
  13. Dec 2, 2020 at 6:05 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    What, nobody suggested a credit card?? Why ruin a good deck of playing cards? Oh, I see PHM did...
    If you take you time it's not as hard as you might worry. Just clean 'em good and light scuff, paint and don't forget 'emblem adhesive' and use strategically and sparingly.
    I haven't blacked out mine yet, but my plan is to remove the LIMITED badge only and do the rest in place.
    Good luck! Slow and easy...
    Edit: P.S. Warm plastic isn't brittle, but don't overheat 'em.
  14. Dec 3, 2020 at 4:14 AM
    Fred
    Hand Protectors
    Yeah the Gift Cards are thinner than a CC about the same thinness as a Playing Card. Those high quality Vinyl Playing Cards would work well.
    I used FuzeIt Adhesive to set my emblems back in place. Needed to temporarily tape them for about 30 minutes until the Mojo set.
    Glock 40[OP] likes this.
  15. Dec 3, 2020 at 4:44 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I used dental floss and a 3M eraser wheel.
    Glock 40[OP] and Hooptytrix like this.
  16. Dec 3, 2020 at 5:51 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I used an old CD to shave off the badges, and then various non-abrasive cleaners to remove the glue left behind.
  17. Dec 3, 2020 at 5:53 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Whatever you do, make sure you use a very soft microfiber rag when you goo gone the remaining adhesive, anything else scratches the paint a bit. Sure it can usually be buffed/waxed back to normal but why even go through the pain?
    Stuck in the '00s likes this.
  18. Dec 3, 2020 at 5:59 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Fishing line or dental floss. Trim pry tool and orange cleaner/bug and tar remover for the adhesive residue. Then clay bar, rubbing compound, buff and wax.
  19. Dec 3, 2020 at 6:41 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I pulled some side panels off my Dads truck . . . I used 3M aerosol spray adhesive remover afterwards to get rid of the leftover adhesive . . . that stuff worked INSANE . . . safe on the paint too. Highly recommended.
  20. Dec 3, 2020 at 7:06 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
  21. Dec 3, 2020 at 11:11 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Anyone with a Phantom Gray 1st Gen with blacked out emblems have a pic to share?
    I’m considering doing the same...
  22. Dec 3, 2020 at 11:18 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    I'd leave them on if I had a 2000 truck. Your paint will probably be faded and you will see the same decals, just in bright paint.
    Or, you could just paint them and put them back on that brighter paint. Good reading on my part. When I did this, I used a low texture bedliner with good results.
  23. Dec 3, 2020 at 1:58 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Having just removed baked on shit residue from removal of all badges and the stupid rocker trim piece.....
    Best thing ever.
  24. Dec 7, 2020 at 6:40 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Ok, you guys have me 'sold' on the eraser wheel. I own an orbital buffer and figured that would be fine but this is a good addition to my tool selection, for a variety of things. :thumbsup:
    They kinda want a small fortune for the 3M brand so I cheaped-out and ordered this one https://www.amazon.com/ABN-Rubber-Eraser-Adapter-1-Pack/dp/B018WG2XYE/ref=sr_1_4?dchild=1&keywords=3m+03612&qid=1607351345&sr=8-4
    It's about 1/3 the price and has great reviews. Unfortunately for me... I picked up the Kung Flu on Dec 3rd so have suspended all Jeep and Yota work until this crud is gone from my system. My symptoms weren't too bad and I'm at the tail end of it now. Mild flu symptoms for two days, no cough, O2 levels remain in the mid-90s, but no taste or smell... that's only the symptom I still have and it's driving me nutz, really annoying not to have taste or smell. Appetite is strong but zero taste or smell. So strange. I expect to be back in action soon.:fingerscrossed:
