Badge removal
Discussion in '3rd Gen Tundras (2014+)' started by ChristianEKR, Nov 5, 2017.
  1. Nov 5, 2017 at 9:55 PM
    ChristianEKR
    ChristianEKR [OP] New Member
    2017 Quicksand CrewMax SR5
    I odrdered OEM black badges for my front quarter panels and need to remove those (very) chrome badges. Any recommendations? I was thinking braided fishing like and a plastic spackle knife to pry them off?
    1UPPER likes this.
  2. Nov 5, 2017 at 10:29 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    I debadged my truck a few weekends ago. I used a heat gun and 30 lbs fishing line. I also used goo gone to get the rest of the residue off. I then gave the truck a wax job and it turned out pretty good.
    Krezz and htw_hawaii like this.
  3. Nov 5, 2017 at 10:38 PM
    ChristianEKR
    @Agitated1 thank you dude! Much appreciated! I’ve been looking at rims, but seeing your truck in your picture sold me on OEM TRD. what’s that rack you got going over the bed?!
  4. Nov 5, 2017 at 10:47 PM
    Agitated1
    Los Angeles
    No problem!! I’m actually looking to get the SCS Ray 10 rims when they come out. As far as cover, I’ve got the Truck Covers USA American roll cover with the Yakima rails.
  5. Nov 5, 2017 at 10:50 PM
    ChristianEKR
    @Agitated1 looks great dude! I don’t bike too much but maybe a Yakima or Thule basket would be cool?! I think I just mentally spent another g!
    htw_hawaii likes this.
  6. Nov 5, 2017 at 11:03 PM
    Agitated1
    Los Angeles
    Thanks man. When The bike rack is off I have a Yakima basket on. The mod bug gets pretty expensive. Lol. But it’s well worth it!!
  7. Nov 6, 2017 at 3:58 AM
    cch2a
    cch2a New Member
    I did exactly this and it turned out great. Took off the rear 4x4, pillar SR5, and side Tundra badges. I will eventually do the 5.7 badge too.
  8. Nov 6, 2017 at 6:24 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    Use some really small braided fishing line, pull it towards the badge and in a sawing motion. It will cut the adhesive close to the badge, and leave a thick adhesive on the paint. You can just peel the adhesive off the paint with your fingers easy peasy. Then I used turtle wax adhesive remover. Super easy. No heat needed, takes 2 seconds.
    htw_hawaii and Sunnier like this.
  9. Nov 6, 2017 at 7:09 AM
    Borgs
    Borgs New Member
    PA
    I did this exactly, a few weeks ago. The "5.7L" badge is a pain due to all the adhesive. The "TUNDRA" and "Limited" badges came off easily. It should go pretty well if you heat it up enough. I would not go at it with a plastic trim or spackle tool of any sort. Fishing line (20 or 30 lbs), heat, a little patience and perseverance, and you will get the job done nicely. Go Gone is a must, then careful surface prep for new badges.
    Ely010606, htw_hawaii and Sunnier like this.
  10. Nov 6, 2017 at 7:20 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Tampa Bay
    2015 Silver Tundra Double Cab SR5
    K&N Filter, Toyo Open Country 255/70/18s, LED interior swap, Truck Cover USA American Roll Cover, Bumper Mounted Flush LED Pods, LC7i, Infinity Components front/rear, Kicker 10" Shallow Mount Sub, MB Quart Amp, Crunch Amp for Sub, JBL sail panels, Bed Cargo Net, Beast Mode Always Enabled!
    I used 30lb braided line as it didn't break like the monofilament did and I didn't heat anything. The fishing line cuts through the adhesive like butter once you get it going back and forth (friction generates heat). No chance of scratching the paint. There is enough adhesive left on the paint that I rolled it with my fingers and pulled it right off with no residue left. Wash, wax, and done.
    Small tip, wrap the fishing line around a piece of plastic (cut a plastic coat hanger) to give you leverage and to minimize cuts on your fingers. It didn't bother my fingers but I could see where it would in some instances.
    mlucas555, Sunnier and htw_hawaii like this.
  11. Nov 6, 2017 at 8:03 AM
    Borgs
    Borgs New Member
    PA
    I should note that I did mine on a cool (50's) rainy day in Pennsylvania a few weeks ago. Probably not the smartest time to do this, so the heat gun made it a lot easier.
  12. Nov 6, 2017 at 8:07 AM
    fisherman951
    fisherman951 New Member
    Tony
    Riverside
    2017 crewmax 4x4
    3m has a adhesive removing wheel woorks great
  13. Nov 6, 2017 at 9:34 AM
    scpete24
    scpete24 Dude
    Orange County, CA
    2016 TRD Pro Super White
    CB shims, CB +3 shackles, tint, Spidertrax spacers, MattGecko Bed Lights, BFG's
    Like others have said - braided fishing line, goo gone, and elbow grease you will be set
    Sunnier likes this.
  14. Nov 6, 2017 at 9:37 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    I will be doing this when I get the chance and have the time. I like blacked out lettering, but that iForce 5.7 giant rectangle has to go...
    JRPro likes this.
  15. Nov 11, 2017 at 2:38 PM
    AlexWV
    Alex
    WV
    So I removed the SR5 emblems from my truck. Pretty cold here, but the first came off fine. The second one seemed to come off the same, but upon cleaning it up, it appears to have peeled the clear coat or something... Guess they may have to go back on to cover it.
  16. Nov 11, 2017 at 2:50 PM
    TundraTss
    TundraTss New Member
    Brandon
    2015 TSS 5.7 MGM
    Toytec 3/1 Boss SPC UCAs JL Audio upgrade Dirty Deeds budget dumped 35s
    Blow torch, crow bar and steel wool to get the residue off.
    Or fishing line and goo gone if Danger isn’t your middle name.
  17. Nov 11, 2017 at 3:29 PM
    AlexWV
    Alex
    WV
    I did fishing line and goo gone...:itllbuffout:
    geno0506 likes this.
  18. Nov 11, 2017 at 4:18 PM
    fisherman951
    Tony
    Riverside
    2017 crewmax 4x4
    Wax is ur friends
  19. Nov 11, 2017 at 9:35 PM
    TheBeast Dirtbag
    Long Beach
    2012 CM 4x4 TRD
    wax on wax off
  20. Nov 12, 2017 at 7:59 AM
    AlexWV
    Alex
    WV
    Do you think that will fix it?
  21. Nov 12, 2017 at 8:02 AM
    AlexWV
    Alex
    WV
  22. Nov 12, 2017 at 8:11 AM
    Sunnier
    Sunnier Agrees your truck is the second best colour
    San Diego, CA
    2017 Inferno Tundra DC TRD
    If I get a winch on my 2WD, can I overland with the BASTRDs and SGU?!
    Ooh, ouch. :popcorn:
    I'll be watching to see how this turns out, before doing mine. Good luck!
  23. Nov 12, 2017 at 8:42 AM
    AlexWV
    Alex
    WV
    I didn’t follow the rules of doing it in warm weather or with the heat applied. I thought that was just to make it easier, but maybe I was wrong. Eh worst case scenario I’ll just put them back on
    Sunnier likes this.
  24. Nov 12, 2017 at 3:13 PM
    Agitated1
    Los Angeles
    That’s how mine looked when I took it off. Just wax it and see how it looks afterwards.
    AlexWV and Sunnier like this.
  25. Nov 12, 2017 at 5:46 PM
    geno0506
    geno0506 GENO
    San Antonio, Texas
  26. Nov 12, 2017 at 8:33 PM
    nowayout
    nowayout New Member
    NY
    17 CrewMax MGM
    Baja Designs Squadron Sport fogs, HID retros, Pro Grill with painted color matched caps. Vled interior lights, AJT shift knob
    You can also use WD40 to take off residue. I've used it on 20 of our fleet vehicles at my job.
  27. Nov 13, 2017 at 3:26 AM
    AlexWV
    Alex
    WV
    Well I tried goo gone just like I did on the other side and it didn’t work, but I’ll try some other stuff again later. Thanks
  28. Nov 13, 2017 at 6:57 AM
    Agitated1
    Los Angeles
    Smiley likes this.
  29. Nov 13, 2017 at 7:00 AM
    AlexWV
    Alex
    WV
    So do you all think its still just crud from the adhesive? I can elbow grease that off if it's the case, but I really thought it looked like the clear coat had peeled
  30. Nov 13, 2017 at 7:35 AM
    Sunnier
    San Diego, CA
    I'm not an expert. But in the photo, it looks to me that the clear coat had peeled. If it looks that way in person than, yeah....
