Mountun Goat’s Anatomy Thread
Discussion in '2nd Gen Builds (2007-2013)' started by Mountun Goat, May 6, 2018.
  1. Nov 19, 2020 at 11:09 AM
    #421
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Dang, that’s very nice of you! Thanks :)
  2. Nov 19, 2020 at 11:29 AM
    #422
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    :fistbump:
  3. Nov 22, 2020 at 6:27 PM
    #423
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    In an effort to quiet the beast, I plasti-dipped the goat lock shackles.
  4. Nov 23, 2020 at 6:33 PM
    #424
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I added a battery isolator today. This setup is more just a prolonged battery isolator than a hidden switch. Although, I’m sure this would still leave most scratching their heads... I work one week at a time and it sits with all its battery robbing jewelry and kills the battery in freezing temps, so here’s my fix.
    I started by drilling a 3/4” hole in the inner fender skins and roughing in the switch location.
    Then I crimped a 1’ long-0 gauge welding cable for the positive circuit extension. Bolted this from switch side (-) side of the switch to the positive battery lug.
    Oh right, I decided to upgrade the oem battery lugs for some generic brass lugs as the factory’s were getting stretched and loose.
    Decided to keep all the factory cables/lugs in tact incase I suck at wiring haha. So, I re-routed the winch and oem positive lug cables to (+) side of the switch and taped the hell out them to form a harness.
    Then, I added a power-tap, for future electrical panel upgrade and stereo. I started with a 1’ long-4 gauge cable tied to an old Phoenix Gold single 4 gauge to quad 8 gauge power splitter. Bolted the splitter to the top/rear of the oem fuse panel lid.
    That’s bout it. :hattip:
  5. Nov 23, 2020 at 6:53 PM
    #425
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    Great mod! Ive been thinking of doing the same thing. I work week on/week off and worry a dead battery when i get home, especially in winter.
    Mountun Goat[OP] likes this.
  6. Nov 23, 2020 at 7:04 PM
    #426
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Do it!
    Y0TA PR0 likes this.
  7. Nov 24, 2020 at 9:24 AM
    #427
    70m4h4wk
    70m4h4wk New Member
    Vancouver Island
    23 Silverado LT, CCSB, 2.7L Turbo
    0/2 Level
    That's really cool. Any particular reason you didn't put the switch inside the cab?
  8. Nov 24, 2020 at 11:09 AM
    #428
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks. Pretty hard to unlock a power lock door without power ;)
  9. Nov 24, 2020 at 12:16 PM
    #429
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Nice!
    Nice and hidden from thieves :thumbsup:
  10. Nov 24, 2020 at 12:27 PM
    #430
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks! Yessir it is safer :)
    Y0TA PR0[QUOTED] likes this.
  11. Dec 3, 2020 at 4:20 PM
    #431
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’m back in tha lab with some more crazy goat shyt :D
  12. Dec 3, 2020 at 5:44 PM
    #432
    Yzed608
    Yzed608 New Member
    Wisconsin
    Is that acrylic?
  13. Dec 3, 2020 at 6:13 PM
    #433
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Plexiglass with the protective shields in place:hattip:
  14. Dec 3, 2020 at 6:30 PM
    #434
    Yzed608
    Yzed608 New Member
    Wisconsin
  15. Dec 3, 2020 at 8:16 PM
    #435
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Those are pretty rad! I’m not gunna tell yet, don’t you know how I roll by now? Haha
  16. Dec 3, 2020 at 8:21 PM
    #436
    TheBeast
    TheBeast The Beach
    and I'm assuming frozen door handles
  17. Dec 3, 2020 at 9:05 PM
    #437
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha true
  18. Dec 16, 2020 at 6:16 PM
    #438
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Well, here is my plan. I want to make a ceiling light feature. Then I thought goat horns would look cool. Figured you masel see them from outside the truck too so I set the dimensions up so the horns hug the outer edges of the rear view mirror. I’ve gotten this far without wrecking any of it and am nervous af to start cutting letters out with a jig saw haha. I’ll use the red led strips posted in #431. Anyway what ya think?
  19. Dec 16, 2020 at 7:01 PM
    #439
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
  20. Dec 16, 2020 at 8:02 PM
    #440
    Yzed608
    Yzed608 New Member
    Wisconsin
    That makes more sense than what I was thinking with the PC panel, as you can still see the light on the perimeter and the logo. Could get one of those sound activated light strips and make your truck a snowplow rave :taco::rockband::bananadance:.
  21. Dec 16, 2020 at 8:02 PM
    #441
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha yes I should do that ha
  22. Dec 17, 2020 at 9:13 AM
    #442
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    This all stemmed from me wanting to add an auxiliary switch panel FYI. Got the switches mounted this morning. It’s starting to look functional, not just over the top haha
    MTRock, drobb, Yzed608 and 4 others like this.
  23. Dec 17, 2020 at 8:37 PM
    #443
    Yzed608
    Yzed608 New Member
    Wisconsin
    Nice! Will that light be ran on a switch or are you tying it into the map lights? I never realized 2nd gens had 2 of those flip compartments.
    Mountun Goat[OP] and Tundra2 like this.
  24. Dec 17, 2020 at 9:59 PM
    #444
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks, I’m planning to tie it into the gauge dimmer switch so it dims with the gauges. I broke one of the horns off tonight so it’s just gunna be a rectangle now haha.
    Rica25 and Tundra2 like this.
  25. Dec 21, 2020 at 9:13 AM
    #445
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I added a steering wheel spinner... the goat is a tractor now after all.
    But honestly, the next best upgrade since the plow. If you have a plow, you need a wheel spinner too.
  26. Dec 21, 2020 at 9:14 AM
    #446
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Oh, the goat also shedded its rack. Need to make some mods to the rack. I also plan on building a rear spare tire mount. I will fab a frame-to-bed mount bracket that runs to each bed/frame bolt at the rear of the bed floor. I’ll weld a nut to receive the spare wheel retainer key in the center on the bracket and call it a day.
    Overall, I hope to gain some rear weight ballast for plowing and winter driving.
  27. Dec 22, 2020 at 7:35 AM
    #447
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I drilled some holes in my roof yesterday.. Installed m4 nutserts for a factoryish install of these amber leds. Started wiring, I got 12 wires pulled from under dash (enough tail to clear firewall and make the relay box) up to the newly added overhead console switch panel. More to come as the wiring continues.
    Ps: I used the right stuff again in this job, I ran a bead around the bottom edges and also the screw heads.
  28. Dec 24, 2020 at 11:08 AM
    #448
    gipsyfetus
    gipsyfetus Royale with Cheese
    KY
    2013 Radiant Red Tundra 4x4 Double Cab 4.6L
    Tinted windows, Roof Rack, Rage Cage, Slim Toolbox, LED Ditch Lights, Bug Deflector, Tube Side Steps
    Do the spacers work with the wheel caps on? I just had my leveling kit installed and the shop mechanic told me they only had three threads left. So they did not install my spacers.
  29. Dec 24, 2020 at 12:18 PM
    #449
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Actually, I’ve never owned dust caps for my oem rims. Spacers worked well for those and my newbies...
    gipsyfetus[QUOTED] likes this.
  30. Jan 5, 2021 at 2:12 PM
    #450
    RepeatPete
    RepeatPete New Member
    Pete
    2008 Tundra SR5
    How do you like that Ebay grille - did it fit okay?
    I'm probably about to pick up the same one.
