Thunk when pulling forward
Discussion in '2.5 Gen Tundras (2014-2021)' started by greg8765, Nov 20, 2020.
  1. Nov 20, 2020 at 9:05 AM
    greg8765
    greg8765 [OP] New Member
    Grant
    Utah
    2021 Cement Tundra
    Hey all,
    After going in reverse and pulling forward about ten feet or so, I hear a thunk under my truck. It didn't start happening until the lift, wheels and tires went on. I think it's happening somewhere under the drivers seat area. I've had it back to the dealership who installed my setup twice and they can't figure out what it is.
    Has anyone had a similar problem?
  2. Nov 20, 2020 at 9:08 AM
    sharkmango
    sharkmango New Member
    2014 Tundra TRD 4x4 White
    Yeah man. Big problem!
    You just ran over me and I’m stuck under the truck. Help! I’m hung up in the suspension!
  3. Nov 20, 2020 at 9:08 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    Are you sure it's not the ABS self test?
  4. Nov 20, 2020 at 9:22 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This needs to be run-to-ground before we go any further.
  5. Nov 20, 2020 at 9:30 AM
    Corranhorn4406
    Corranhorn4406 New Member
    Brad
    2015 Black Tundra SR5
    I hear the same on my truck and have always wondered what it was. Never tried to diagnose though.
  6. Nov 20, 2020 at 9:51 AM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    I have no idea. I rode around with one of the mechanics and showed them and they said, yes, that's a problem. I would assume they would know what an ABS test is and that it's normal? At the same time, it never happened before we messed with the truck. So I don't effing know...
  7. Nov 20, 2020 at 9:51 AM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    do you have a lift on it?
  8. Nov 20, 2020 at 10:07 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    What is your lift and is the rear lifted as well? Folks have mentioned the ABS self test can be similar to what you are experiencing but that would have also been happening when the truck was stock. If you lifted the rear did you install a carrier bearing drop?
  9. Nov 20, 2020 at 10:08 AM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    i don't know. the dealer installed it all. I'll have to find out.
  10. Nov 20, 2020 at 12:28 PM
    Corranhorn4406
    Brad
    Negative. But I always notice a thunk somewhere underneath shortly after taking off
  11. Nov 20, 2020 at 12:29 PM
    Corranhorn4406
    Brad
  12. Nov 20, 2020 at 12:35 PM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Sounds like the ABS test clunk. They all do it.
  13. Nov 23, 2020 at 9:09 AM
    mkeegan27
    mkeegan27 New Member
    CT
    2018 platinum crewmax
    everytime you start your truck there is a clunk at 5 mph(ABS Test).......if it happens anytime after that its something else.
