Affordable LED suggestions
Discussion in 'Lighting' started by Toyoda Tundra, Oct 26, 2020.
  1. Nov 15, 2020 at 6:29 PM
    There are leds that are designed to work in a halogen reflector. Vleds Micros being one of them.
  2. Nov 22, 2020 at 7:47 PM
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    I just ordered a set of these and figured I'd pop on here to say thanks (we'll see how they look when they get here) and to mention that they were $4.00 off on Amazon just now as well incase anyone else is in the market.
  3. Nov 23, 2020 at 3:18 AM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    There are YouTube’s of the install. The rubber boot is tight but with a little patience and work it’ll go on without any cutting and seal the light. Make sure you fully seat the bulbs... I didn’t at first and the beam looked like crap on one side until I looked through the lens and noticed.
    it isn’t as good as TRDPros... but it’s a LOT cheaper and I’d say it’s 90% of them in any case. Let us know how it turns out, and good luck!
  4. Feb 23, 2021 at 2:33 PM
    two2cal
    two2cal New Member
    These boots sure are a PIA to get over the bulb. Good to know that it can be done without cutting. I've been at it for an hour and just about to break out the knife.
  5. Nov 22, 2021 at 9:57 PM
    Mgrv
    Mgrv New Member
    2004 tundra double cab v8
    I have an 04 tundra and installed some LEDs on it. I know a common issue was trying to turn on the fog lights, but it would turn on the high beams instead. A lot of people bought a load resistor and placed it on the passenger side to fix the issue (H4-RL650-M: H4 Connection Load Resistor).
    my question is, where is the best place to mount it and how? (Ie screw size, loctite glue? It’s all new to me.
