'17 Integrated Brake Controller
Discussion in 'Towing & Hauling' started by BraveDuke3, Mar 12, 2017.
  1. Mar 12, 2017 at 5:18 PM
    BraveDuke3
    BraveDuke3 [OP] New Member
    Shaun
    Rotterdam NY
    2017 CM Tundra SR5 MGM
    ProZ Bifold tonneau cover
    I have read about the issues with 2016's integrated brake controllers and I was wondering if this was still an issue with the 2017's? I will be getting my TT out of storage in a couple months and will be the first time towing it with my new Tundra. I do have my brake controller from my Tacoma I would put in if the issues are still present. Thanks.
  2. Mar 12, 2017 at 5:28 PM
    gosolo
    Ray
    NW Oregon
    Some people don't have problems, many people do. I would try it with your trailer in tow first. Be sure that you're testing where you get up to speed and can simulate a panic stop without any real traffic so nothing is at risk.
  3. Mar 12, 2017 at 5:36 PM
    BraveDuke3
    Shaun
    Rotterdam NY
    Ok, I will test it out and see how it goes. Thanks.
  4. Mar 12, 2017 at 5:50 PM
    gosolo
    Ray
    NW Oregon
    Post the results, many of us would like to hear what you find.
  5. Mar 12, 2017 at 5:52 PM
    BraveDuke3
    Shaun
    Rotterdam NY
    Will do. Probably won't be until early May at the earliest. Still getting snow here :(
    gosolo likes this.
  6. May 15, 2017 at 5:41 PM
    BraveDuke3
    Shaun
    Rotterdam NY
    Just wanted to give an update. This past weekend I pulled my TT out of storage and got it hooked up to my Tundra. The IBC didn't seem like it was working at first but after a while it seemed to work. I couldn't hear the trailer brakes make the clicking noise when they engage at first, but after a while of driving I started to back it into my driveway and I could hear the brake click when I hit the brake. My brother in law had a theory that the brake controller is working but only applies pressure according to the driving conditions such as going down a hill or speed. Not sure if this is the case for the IBCs in the Tundras or not. I didn't tow the trailer very far. I think I may tow it further next weekend to get a good feel for it and see if the IBC is indeed working this way.
    gosolo likes this.
  7. May 15, 2017 at 5:55 PM
    gosolo
    Ray
    NW Oregon
    Hope it works for you, interested to hear
  8. May 24, 2017 at 8:18 PM
    TundraPro406
    TundraPro406 New Member
    Montana
    Just tested mine oem IBC on my 17 CM Pro and everything was working properly. Setting was with Electric Over Hydraulic setting. Braking was even a bit over powering and had to lower to 4 or 4.5(@5 is default). Hopefully the 2017 model Toyota fix any issues with the IBC. Best of luck to the rest of you!
    NewImprovedRon likes this.
  9. May 24, 2017 at 8:21 PM
    gosolo
    Ray
    NW Oregon
    Thanks, this is good information. There's no apparent rhyme or reason about how or why some seem to work well and others don't.
